Quake III
    Amigaz
    Posts: 121 from 2005/6/11
    Anyone installed Quake III recently? it seems you can't finish the install since the server it want's to d/l the linux Quake files from isn't accepting a login :-o
    MorphOS PowerUP powered Amiga 4000
    Pegasos II G4 1ghz
    Radeon 8500 128mb
    Soundblaster Live 5.1 Digital
    Realtek 2139B 100mbit
  • »07.08.07 - 17:17
    dOpus
    Posts: 42 from 2005/7/30
    I have installed Quake III a cople months and works....
    Meantime i change my graphic card and Quake III appears too big on my screen how to get resolution settings? i try in Quake setting but don work
    G4/1GHz,1GB DDRam,Ati Radeon 9250 128Mb
    MorphOS 2.0 demo
    Molk with MacOSX 10.4.9 Tiger
    iMac 27" 2007 2,16 MHz,1,5 Gb Ram OSX 10.6.5
    AppleTv 40Gb with external 160Gb HDD
  • »07.08.07 - 18:27
    Amigaz
    The update actually worked now after giving it another try
    Also had the resolution prob but got a working screen size after fiddling with the other display settings like billinear/trilinear
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »07.08.07 - 19:03
    keropi
    Posts: 131 from 2006/11/11
    when I installed it, it just searched through servers until one worked and actually downloaded the update...
    about the res prob, I did not have it , and I had a 9250 and now a 8500. works perfect.
    have u both applied the 3D update on MOS?
    A4000D CS-PPC/G-Rex4000D
    A4000D CS-PPC/Zorro
  • »07.08.07 - 21:03
    Amigaz
    Yesss....the MorphOS3DUpdate_R2
    Using a Radeon 9250
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »08.08.07 - 05:02
    Posts: 108 from 2005/4/3
    Quake III is installed. However, how to play ? I shoot another person that seems a friend person... I'am shoot down quikly after the game starts, there's heavy fire on me, but don't know where's come from. The game freezes when i'am lost..
    Grts, Amigaharry
    http://www.angelfire.com/amiga/ex
  • »09.08.07 - 05:26
    Daff
    Posts: 243 from 2003/4/5
    @amigaharry : I think you're in the 1st level. The "friendly person" is your opponent. Shoot him 4 or 5 times and you will pass to the next level.
    If Q3 freeze, check your RAM : you need more or less 250-300 Mo of free RAM for certain level.
    http://obligement.free.fr
  • »11.08.07 - 19:35
    Bots, i understand, are other players played by the computer. You can add more or remove them. Played another Quake 3 start level, when i was lost, then i started the game again and again. The enemies are strong ! Only loading Quake 3 files takes time.
    Grts, Amigaharry
  • »12.08.07 - 12:19
