REminiscence-0.1.9
    Jupp3
    Posts: 1193 from 2003/2/24
    Hi!
    I just compiled the latest REminiscence to MorphOS. The archive is available here
    For those who don't know, REminiscence is an open source engine for running game "Flashback". It requires data files from PC version, and optional mod files from Amiga version (if you want music, that is)
    Read the provided readme files!
    And also note, that switching between window and fullscreen does NOT work currently!
    Project homepage
    [ Edited by Jupp3 on 2007/7/28 17:29 ]
  • »28.07.07 - 15:03
    tokai
    Posts: 1289 from 2003/2/25
    Hmm.. flashback.. that are memories. :-)
    btw., there was also an open source engine for another world which probably could need an updated MorphOS port too. ;-)
    regards,
    tokai
  • »28.07.07 - 16:26
    Jupp3
    You mean the one, that was canceled on request of the author of the original game? No much/any progress on that project obviously...
    There was a "hires patch" which I managed to locate and compile. The game basically works, but the graphics are quite buggy in many places, and it's pretty obvious that it was not designed for higher resolutions, as shapes of many objects (such as guns) look way too simple (like a triangle, for example) when in lores they were just... Well, lores.
  • »28.07.07 - 16:43
    Posts: 186 from 2003/10/23
    maybe we can push the original author to put the source of the reedited version of AW in a "trusted programmer" 's hands and sell the shareware game to the mos community
    [ Edited by raistlin77it on 2007/7/29 1:07 ]
    I'm nerdy in the extreme
    And whiter than sour cream
    White&Nerdy 2006 Al Yankovic
  • »29.07.07 - 00:13
    Godd answer (for me at least )
    tomorrow i will'move on :D :D
  • »30.07.07 - 00:00
    Jupp3
    I tried with the latest powersdl, and switching between window and fullscreen seems to work again. Good work, itix!
    To get the speech working, you need to copy voice.vce file from sega cd version to your data dir.
  • »06.08.07 - 09:36
    Phantom
    Posts: 381 from 2004/9/7
    Does anybody knows where to find the speech files from the Sega CD version?
    BTW, I liked this game and I play it even now through this port. Excellent work, thanks. ;-)
    Oh! I almost forgot. Does anyone knows how they chose that name (REminiscence?). I'm really curious :-P
    [ Edited by Phantom on 2007/8/7 15:06 ]
  • »07.08.07 - 13:03
    Jupp3
    You can always try googling for what you need:
    reminiscence voice.vce
    All voices are in one file, that's called voice.vce
    Also note that many things are NOT spoken, most notably videos. Becouse of that I thought that I still had done something wrong, as there was no voice in data cube sequence in the beginning (as that's the first "I assume this would have speech, let's try it" spot in the game)
  • »08.08.07 - 12:50
