Zangband
    Posts: 157 from 2003/3/3
    After some testing (thanks to Piru) Zanband 2.7.2 works on Pegasos.
    With default configs it does not display game area at all. Editing
    zangband272/user/settings.prf like shown here it'll work ok. I do hope
    when someone makes port of 2.7.3 (latest) they take consideration to
    retargettable gfx users (currently it defaults to aga gfx).
    Original (and source!) can be downloaded from www.zangband.org
    (note .. only beginning of conf file shown.. rest can be left as is,
    unless you want to change font etc..)
    ANGMAN.name ZAngband
    ANGBAND.version 0
    ANGBAND.gfx N
    ANGBAND.sound N
    ; Screen options
    SCREEN.mode 0x99000
    SCREEN.name Workbench
    SCREEN.use custom
    SCREEN.width 640
    SCREEN.height 240
    SCREEN.depth 5
    SCREEN.overscan 1
    SCREEN.blankmouse Y
    SCREEN.menus Y
    SCREEN.aga N
    http://somequicknotes.blogspot.com/index.html
  • »30.08.03 - 22:13
