MorphOS
    cd32
    Posts: 18 from 2003/8/16
    is worth switching too i like the looks and the applications that are avalible i also been told that uae is at good speed on mophos os
    I don't see the amigaone for what im going for can people tell is uae at good speeds for emulation :-D
    Thanx
    CD32
  • »17.08.03 - 13:59
    DJBase
    Posts: 745 from 2003/4/6
  • »17.08.03 - 14:29
    Spidey
    Posts: 568 from 2003/2/24
    @cd32:
    Do you have your Peg or are you looking for one? :-)
    @DJBase:
    It happens that I made a quick guide for Coder a few days ago, but it's in Dutch.
    What is exactly the problem?
    Perhaps we can solve the problem you're having now.
    Spidey
  • »17.08.03 - 18:14
    realstar
    Posts: 298 from 2003/2/24
    Well, I can't speak for others but I have personally purchased a
    Pegasos and am very happy with it. MorphOS 1.4 is very stable
    at this point (compared to classic Amiga OS) and has many new
    features in addition to the incredible speed advantage of running
    all your PPC and 68K software on modern hardware.
    The most important part about the Pegasos is the great developer
    community and support offered by Genesi too. It's great to work
    in a constructive atmosphere where progress is being made. If
    you need more information about the Pegasos platform I suggest
    viewing the gallery here at MorphZone and see
    http://www.pegasosppc.com and http://www.morphos.net
    I haven't tried UAE myself, there is enough software to
    keep me busy for now and nearly all "system-friendly" apps and
    games run fine. :)
  • »17.08.03 - 19:05
    cd32
    ok i looking for 1 but will i not be worth waiting for the g4 peogos to come out what games do u have running does it have usb support
  • »17.08.03 - 19:23
  • Targhan
    Posts: 2833 from 2003/2/8
    Well, e.p.i.c. does a lot of ports (and original game publishing too). As far as USB, I have the Knights and Merchants demo on my Belkin USB pendrive, AND I played it several times under MorphOS FROM that pendrive! :-D :lol:
    :idea:Targhan
  • »17.08.03 - 20:42
    DJBase
    @ Spidey
    UAE 0.8.22 always freezes the whole System.
    UAE 0.8.6 does always give me a black screen or window.
  • »17.08.03 - 20:53
    cd32
    when the g4 due im i not worth waitin ng for that
  • »17.08.03 - 21:27
    Spidey
    @DJBase:
    Stick to the 0.8.6 version.
    I'll make a quick English translation of the guide and will put it in this thread today :-)
    Spidey
  • »17.08.03 - 23:06
    realstar
    I wouldn't worry too much about waiting for the
    G4 systems. It seems that the G3 and G5 models
    will be the focus and the G3/600 system is more
    than fast enough for most uses. You may want to
    wait for PegII though since the faster ram etc.
    will make a more noticable difference than just
    changing the cpu alone and the availability should be
    better by then too. :)
  • »18.08.03 - 04:53
    Stany
    Posts: 26 from 2003/4/28
    @ Spidey
    send the Guide to my in Dutch ;-)
    stan01@wol.be
  • »18.08.03 - 07:31
    serge
    Posts: 725 from 2003/2/20
    DJBase wrote:
    @ Spidey
    same problem for me since I updated to mos1.4. UAE 0.8.22 and 0.8.6 worked fine on mos1.3 :-?
  • »18.08.03 - 08:49
    cd32
    how fast is it with sound
    1.. what processer does it support
    2.. does it does hardrives
  • »18.08.03 - 12:31
    Spidey
    @cd32
    Sound : not yet tested by me
    Processor : at least 68020
    Harddrives: sort of. You can assign a drive, but it doesn't work.
    Spidey
  • »18.08.03 - 23:02
    Spidey
    @everyone:
    Download UAE0.8.6.lzx here
    Download MUIRexx_3_0a.lha
    Just install UAE.
    Install MUIREXX.
    Don't install icon.mcc with the installscript. Install it by hand to SYS:Classes/MUI
    Make sure REXXMast works. See the FAQs-button on the left :-)
    Make sure to have a kick.rom in the UAE-dir.
    In the UAE-dir you have a REXX-script called: uaewb.rexx.
    Start this script with the command: muirexx uaewb.rexx.
    (Or make a project-icon)
    You should see the GUI and can make adjustment and start UAE.
    Spidey
    (yes I know it is a very quick guide :-))
  • »18.08.03 - 23:14
    DJBase
    I forgot to start it over the rexx script. Now also uae 0.8.22 works extremly fast.
    http://www.djbase.de/privat/bilder/ambient_17.png
    UAE 0.8.22 playing Fire&Ice 8-)
  • »19.08.03 - 00:15
    DJBase
    I have tried to load harddrives in UAE. But both HDF and Directory wont work.
  • »22.08.03 - 14:10
    Spidey
    HI DJBase,
    I tried that too and I noticed files aren't recognisible and whole directories are turned into 1 file with the size of the whole directory.
    Spidey
  • »22.08.03 - 20:57
    DJBase
    After testing and testing it seems only UAE 0.8.6c is working here. I tried also 0.8.12 WOS Version but no luck. It has always wrong colors. For me 0.8.6 isnt fast enough to play smooth.
  • »23.08.03 - 02:05
    DJBase
    Ok, wrong colors are on Screens with 24bit. Now it works also with harddrives but has no GUI to change adf diks.
  • »23.08.03 - 10:31
    Coder
    Posts: 296 from 2003/3/5
    I am in the process of getting UAE to run. Still not been able to start a game. Some errors I got. But what bothers me a bit is that there is a lack of information about how to get UAE to run. Spidey allready did a manual for me for it. That I will put up on the website. But I was thinking maybe it would be a good idea to have a UAE MOS section on my website. With everything about it. So that people for starters will know how to get it run and furthermore a lot of tips and bugs etc. Any thoughts to this?
    Coder
  • »23.08.03 - 10:47
    DJBase
    I have startet to make a more userfriendly UAE 0.8.6c Package for MorphOS.
    UAE 0.8.6c MOS
    Comments are welcome. Maybe there will be someone outthere to make a new GUI for UAE with more functions.
  • »23.08.03 - 11:35
    Coder
    @DJBase
    Nice!
    I got tons of space left on my site so if there is any support out there I can always set something up. :-)
    Coder
  • »23.08.03 - 11:44
