Warp3D games, what ones have you got running?
    Posts: 56 from 2003/3/16
    Hi all,
    Now that i can take a break for awhile from "PegXLining"
    I wanted to try the new Morphos 1.4 and its warp3d support.
    The only game i cant get running is shogo:demo
    Does anyone have an idea why?
    Can people post what games they have running full or demos
    thanks
    david
  • »17.08.03 - 21:34
    Posts: 1075 from 2003/3/24
    I have all Hyperion Games(Heretic2, Shogo, Freespace and Quake2) running on my Voodoo3 in Hardware Renderer, no problems. Maybe you need the lowlevel.lib?
  • »17.08.03 - 22:16
    serge
    Posts: 725 from 2003/2/20
    Hello David,
    I have glquake, descent freespace, heretic 2 demo, wipeout, all running fine. My only problem is shogo :) it doesnt start after the launcher. Do you use the RGB16BE=YES tooltype on voodoo driver ?
  • »18.08.03 - 04:25
    serge
    Hello ThePlayer,
    I dont understand why my shogo doesnt work on mos 1.4. It worked fine in softrender on mos1.3, but since I updated ....
    I dont understand why shogo needs a voodoo4 driver "snoopdos" my card is a voodoo3 2000.
    In past I installed a voodoo4.
    Did you do something special to run shogo? Or is it the simple installation?
    Did you reinstalled an old complet Arexx, or only the arexxsys.library ?
  • »18.08.03 - 04:32
    On MOS1.3 Shogo dosen't work for me, since MOS1.4 and W3D Support it's working now. I didn't change nothing it was a simple installation. Did you use Voodoo4 under 1.3 and then switched to Voodoo3 with 1.4, or what? Maybe try it with the Voodoo4.
    "Did you reinstalled an old complet Arexx, or only the arexxsys.library ?" I have copied the arexxsys.libs to MOSSYS:Libs
  • »18.08.03 - 06:40
    serge
    YES ! SO GOOD ! Shogo is running now.
    The solution ?
    It was avoiding the POPUP tooltype on shogo executable ;-p
    Thank you very much McGreg
    Now are working fine Shogo demo, heretic II demo, descent freespace, GlQuake and wipeout 2097 all in hardware render mode.
  • »18.08.03 - 15:18
    hi serge,
    So what was the soloution then?
    What do i have to change or install?
    to get shogo running
  • »18.08.03 - 16:39
    serge
    For me, the problem was the launcher.
    The launcher seems to work , but it does not.
    So, on launcher's tooltypes , you can avoid the POPUP tooltype. Then shogo runs normaly in software render. Then I could change options from shogo menus, and switch to hardware render.
    Dont know if it is very important, but I have the RGB16BE=YES tooltype on my voodoo3 driver in sys:morphos/devs/monitors/
    Shogo is very very funy
     :-P  :-P
  • »19.08.03 - 04:56
    Posts: 261 from 2003/3/13
    Ill try that at Home,
    But did any of you encounter slow downs in rendering with wipeout in any other level but the first one (easy). ?
    Felix.
  • »19.08.03 - 09:02
    serge
  • »19.08.03 - 09:13
  • »19.08.03 - 10:10
    Hi serge,
    I set the voodoo3 monitor settings to rgb16BE=yes, still no change
    Unset the popup in the launcher tooltype, still shogo doesnt load.
    Im using the demo from AMiga active CD
    Where did you get the demo from?
    Another thing i 've notice is that the hardware renderer comes up with
    no screenmodes?
  • »19.08.03 - 11:38
    Check your GFX Drivers Maybe something is wrong because i can see all Screenmodes availble in Shogo Launcher
  • »19.08.03 - 17:43
    magnetic
    Posts: 2129 from 2003/3/1
    HI DJB
    I am running Freespace (though it crashes sometimes) Wipeout 2097 (havent made it past first level) Quake2 (runs nicely in 1.3 havent cant run in 1.4)
    mag
    EURO Demos run well though.. Like Encore and MadWizard stuff
  • »19.08.03 - 20:22
    magnetic
    Serge
    Freespace in HW render freezes in the same mission in the same place..Mission 2 whenever wingmen talk to me the screen blacks except for them and then after we kill first wing of enemy it crashes.. almost same point everytime...
    please help
    magnetic
    @Player Quake2 worked great for me in 1.3 now with 1.4 when I load it I only get a grey screen..
  • »19.08.03 - 20:25
    @ Magnetic: Quake2 worked for me with 1.3 and 1.4 and Hardrender support without problems. I had only one chrash when i started Shogo first time after upgrade to MOS1.4.
    Now i' ve got a litle problem with Quake2, i have to set Hardrender manualy in Quake2 evry time.
  • »19.08.03 - 21:01
