Need a good startup command line for UAE
    TheMagicM
    Posts: 1220 from 2003/6/17
    086b and 086c...
    Works good so far.. I have the screen at -M 640:480:d but it looks kinda weird..too big...anyone have and better startup lines for UAE?
    thx
  • »11.08.03 - 14:01
    Spidey
    Posts: 568 from 2003/2/24
    Hello TheMagicM,
    I'm using the following commandline:
    uae.elf -H 1 -S 0 -x -O 704:566:d -J Ma -m Spidey:OS31 -n i -C 3 -c 4 -Z 32 -0 wb.adf
    Spidey
  • »11.08.03 - 15:29
    TheMagicM
    how do you exit UAE if you're playing a game and cannot jump
    back to the MOS desktop?
    Also, I xferred WB 1.3 to a directory on my MOS hd, but
    it does not boot? Is this not enabled yet?
  • »11.08.03 - 16:07
    Spidey
    Funny, softreset works now :-D
    I was trying UAE and pressed ctrl-amiga-amiga, because until now it didn't work in Ambient!
    Ok, I wrote a lot of stuff before resetting the whole bunch, now you'll get a summary :-)
    Resetting UAE in my case is simple because everything is playing in a window in Ambient. So I only have to push the quit-button of the screen and in the CLI-window I type "q" and press the Enter-button to quit UAE completely.
    The harddrive doesn't work. I just copied some files on it from within the emulation, but after restarting UAE the files are crippled or so. It just doesn't start.
    Whole directories copied to the harddrives becomes just one big file, very strange.
    Spidey
  • »11.08.03 - 17:13
    TheMagicM
    yea, your command line works great. So I guess I shouldnt try making a hardfile to see if it will boot huh? If not thats cool, at least now I have it working decent! Thanks Spidey..and damn, I wish I knew how to get your genesis working cause it works fine here though.
  • »11.08.03 - 17:19
