Dink Smallwood port ? ;)
    Frostwork
    Posts: 302 from 2003/4/18
    Hi all!
    Two days ago I found Dink Smallwood - a free modular rpg
    with full source available.
    The linux-sources (windemere) are available, too here, although nobody seems to have found them yet:
    http://www.dinknetwork.com/display.cgi?action=File&ID=521
    I think a MOS-port before an offical linux-build wouldn't be the
    badest thing - the dependencies should be all already on mos.
    PS: There also was a sourceforge-project from the same author of the above code, but it's closed...
    With some minor glitches within openal-dependend parts
    it builds fine under linux-ppc, but unfortunately these sources
    from above use a special PAK File System & I was not able to
    make a compatibel PAK from the game-data.
    (I found somewhere a prog called par-0.0.3.01 which
    creates quake-PAKS, but unfortunately it doesn't seem to
    be compatible :( )
    Would be really cool to see this very famous game rocking on a peg!
    cheers
    frostwork
  • »15.07.06 - 12:32
