GLQuakeMOS
    jdryyz
    Posts: 127 from 2004/4/9
    I am running this under MOS 1.4.5 and it works great, however, I can only launch using the command line and I must always set the desired video resolution and color depth. The starter config file appears to be ignored.
    Also, what is the purpose of needing a host name? I use "-ip" and a dummy IP adress and it appears to be accepted, but I don't know where this is being used. Perhaps the resulting error message after the icon start is why the Starter config file is not working.
    [ Edited by jdryyz on 2006/4/14 9:42 ]
  • »12.04.06 - 06:31
    jdryyz
    bump
  • »14.04.06 - 18:42
    Posts: 1520 from 2003/2/24
    Never tried GLQuake but you can create startup script which you run from an icon using IconX.
  • »14.04.06 - 19:15
