Joysticks on Pegasos2 with MorphOS
    XzIt
    Posts: 250 from 2005/1/19
    Really need some help 2 find out what kind of joystick 2 use..
    Need it 2 play Mame, Snes, Nes, Sega, SegaGenesis. 8-)
    Anyone got a Joystick/JoyPad they could recomende???
    Should it be USB or GamePort?
    Plz, help  :-o
    XzIt of Apathy  :-D
  • »05.12.05 - 11:14
    BatteMan
    Posts: 290 from 2003/2/24
    I use a PS2's joypad via an USB adaptator. It's a SmartJoy and I found it on Liksang. It has 10 buttons, perfect for SNes9X or Mame.
    You can find it in a supermarket, if you have some chance.
  • »05.12.05 - 11:44
    Jupp3
    Posts: 1193 from 2003/2/24
    Watch out when buying PS2 adapters, as not every model is compatible...
    For gameport pads, I don't know if more than 4 buttons are supported (Which I think is the "standard maximum", but there were some ways of adding more)
    Also the X-arcade stick seems to work quite nicely.
  • »06.12.05 - 01:28
    Posts: 1082 from 2003/3/24
    I use the Logitech Wingman Precision USB-Joypad,
    it has 6 Buttons and works great with all Games that support Joypads.
  • »06.12.05 - 06:10
    XzIt
    Thanks guys/girls...
    I'll check it out.
    XzIt of Apathy
  • »09.12.05 - 11:19
    FLComputer
    Posts: 22 from 2005/9/26
    Hi XzIt,
    You can try this one too :
    http://www.flcomputer.com/Catalog/product_info.php?cPath=90_135&products_id=364
    And don't forget that you can order products with Paypal on our website now !
    Thanks
    Faranheit
    F.L. Computer : YOUR Pegasos 2 and Amiga One Reseller for France and Luxembourg !
    WebSite : http://www.flcomputer.com
    Mail : contact@flcomputer.com
    I.M.M. Informatique : YOUR Efika Reseller for France, Luxembourg and Belgium !
    Mail : laurentz@informatique-imm.lu
    Site : http://www.informatique-imm.lu
    ICQ : 81617715
    Skype : faranheit57
  • »09.12.05 - 17:38
    XzIt
    I just got my Smartjoy from Liksang, it works in a way, the problem is movment, i can't move the Character, just like i Tap the direction button, when i press them to eatch side...
    in snes9x the Fire button is fine i quess...
    What the problem????
    How can i Configure the SmartJoy???
    XzIt Of Apathy  8-)
  • »16.01.06 - 16:22
    BatteMan
    If you use Poseidon 2.2, you need to activate the "analog".
    If you are on Poseidon 3.2, take a look in Poseidon prefs, the answer is near here ;) (look my config' : http://batteman.free.fr/amiga/hid3.2.png ).
    PS : It's BatteMan and not Battleman.
    [ Edited by BatteMan on 2006/1/16 13:52 ]
  • »16.01.06 - 18:39
    XzIt
    Sorry Batteman  :-?
    Im going to try this when i get home, thanks for the help.
    X  8-)
  • »16.01.06 - 19:19
    BatteMan
    XzIt :  Good luck ;-)
  • »17.01.06 - 04:28
    XzIt
    Would really be nice if you could share your hid.class?
    Since i can't get mine to work, when i choose "Analog" it says not supported yet. or something???  :-?
    Now the "Digital" works, but the "Analog" does not..  :-x
    Why?
    XzIt Of Apathy  8-)
    PegasosII G4 @ 1Ghz MOS 1.4.5
    512MB DDR-RAM, Radeon 9200
    2x Western Digital 200GB HD
    Soundblatser Live!, Samsung 19"
    LCD Syncmaster 913V TC099 Silver
  • »23.01.06 - 13:31
    BatteMan
    XzIt : I use Poseidon 3.2 here. The Smartjoy works with the hid.class 2.2 of Poseidon 2.2, but you need to activate the "analog" button of your PS2 pad to use the the pad (with the four direction, not the mushroom).
    Analog only works with Poseidon 3.2.
  • »23.01.06 - 14:44
