SmartJoy under MorphOS
    XzIt
    Posts: 250 from 2005/1/19
    I just got my Smartjoy from Liksang.
    But when i insert the Smartjoy, it overrides the Mouse in MorphOS, why?
    Do i have to config the smartjoy to get it to work???
    Plz, help :-?
    XzIt of Apathy :-D
  • »08.01.06 - 15:17
  • Ex-Member
    Posts: 74 from 2004/6/15
    Very old version of the hid.class (prior to Poseidon V2.2 release) installed.
    Bye...
    Chris Hodges
  • »08.01.06 - 21:44
    XzIt
    What is this?? :-?
    Im i suppose to get this older Hid.class???
    Or delete if it's present under MorphOS?
    XzIt 8-)
  • »09.01.06 - 15:35
  • Ex-Member
    You asked for the reason why the joystick starts acting like a mouse. This is due to an ancient version of the hid.class you have installed on your machine, that will generate default actions on joypad axis for mouse movement, which cause the mouse to be centered as soon as you plug in the pad.
    Deleting the hid.class will solve the problem of the malfunctioning, but you will not be able to HID devices except for keyboards and mice any longer.
    The correct solution would be to upgrade your poseidon version to the last V2.x version (in the ISO of V1.4.5) or the new V3.2, but *DISCLAIMER* beware some users have problems with this version.
    Bye...
    Chris Hodges
  • »10.01.06 - 06:49
    XzIt
    Thanks.. Im going too try it and reply back here.
    Hope this works :-D
    XzIt 8-)
  • »10.01.06 - 15:38
