Quake 3 Loading Times
    diezi7
    Posts: 167 from 2005/7/25
    Well, running Q3, it´s damm slow when loading or
    selecting some option in the main menu. The game
    takes at least 10 minutes to start running.
    I use a Peg II G4 with enough RAM (512), and
    a Radeon 9250 GPU.
    I added AddBuffers command to speed up HD reads.
    Once game is loaded, it runs fine.
    Any suggestion ?? Thanks in advance.
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »09.09.05 - 19:09
    zukow
    Posts: 661 from 2005/2/9
    on ffs partition q3 is extremely slow, copy it to the sfs partition
  • »09.09.05 - 20:26
    CISC
    Posts: 619 from 2005/8/27
    More buffers (I'm sure bigfoot tested this with FFS, maybe he can tell you how many buffers he has)?
    ..other than that, all I know is that it's fairly snappy on PFS atleast...
    - CISC
  • »09.09.05 - 20:57
    Posts: 1932 from 2003/10/19
    Its very fast here on my pfs partiton, I havent tested it on the FFS partition since I only use that for the boot image.
  • »09.09.05 - 21:59
    diezi7
    Using Addbuffers 7000 on that FFS partition.
    It helps a lot, but anyway it´s quite slow
    when it has to deal with big files.
    I wonder if SFS is part of MorphOS or do I need
    to download and install by myself.
    System settings has an SFS section.
    I suppose I´ll need to back up
    the whole partition before doing anything ;-D
    Thanks for all your kind replys, and hope to enjoy
    Q3 soon ;-D
  • »10.09.05 - 01:41
    Posts: 34 from 2004/4/8
    You can start wondering, SFS is a part of MorphOS :)
  • »10.09.05 - 05:29
    diezi7
    Hummm, I could have read pegasos manual first :)
    My system came preinstalled from Vesalia and
    they made two FFS partitions Sys and Work.
    It´s time to backup
    Do I have to clear my Work partition and create
    a new one using SFS, or would it be possible to
    change it´s filesystem from SCSI.Config without
    deleting it first?.
    8^)
  • »10.09.05 - 12:42
    tokai
    Posts: 1289 from 2003/2/25
    @diezi7: when u compiled yourself, then make sure u install latest libnix update before you link the binary.
    Else, try on SFS or increase buffers. ;)
    Here it loads _very_ quickly too (from SFS partition).
    regards,
    tokai
  • »10.09.05 - 13:49
    diezi7
    Increasing buffers beyond 10000 in FFS and it runs
    very nice at last.
    This Q3 is an impressive port.
    thanks ;-D
  • »10.09.05 - 14:43
    Crumb
    Posts: 738 from 2003/2/24
    You can try to increase the blocksize of the partition to 2KB (or 4KB if you don't care much about the space... NTFS on WinXP machines uses 4KB). It will also give you better speed.
  • »03.11.05 - 20:01
