3D Game Tutorials Wanted
    Nitro
    Posts: 106 from 2003/8/24
    Ok we got 3D and IT`S GREAT, but I think it would be cool if some folks put up tutorials of what they did to make them work. Such as when I installed Descent Freespace. I had to change the player folder from read-only to write, so I could save my player. WipeOut 2097 installed easy, but the computer locks up in the second track. With Shogo, I had to disable the movies to have in game sound. I still haven`t got Heretic2 to work, or Quake2 or even Quake3. The installer will copy the pc files, but after says not installed run the installer.
    I think it would be a good idea to have tutorials on how to install these kinds of programs. It would help some of us that just can`t figure these things out, or instead of goings through pages forums looking for the answers.
  • »28.09.05 - 11:29
    CISC
    Posts: 619 from 2005/8/27
    You have to get the WipeoutLoader here...
    Are you sure it downloads and installs the updates as well? If that fails, or is aborted it won't work...
    - CISC
  • »28.09.05 - 11:42
    Nitro
    Ok on Quake3, that`s the problem I can`t go online at home right now so it won`t update, Thanks CISC I`ll try it with the Wipeout loader
  • »28.09.05 - 12:55
    Posts: 47 from 2004/4/11
    Hm, doesn't work here.
    Aminet-Demo is with Sound.
    Original Version has no Sound. (only the intro has sound when i enable movies)
    Any other tips for Shogo to have ingame Sound?
    Peg2 / Radeon 9000-64MB AGP / OnBoard Sound
    Bye
    TriMa
  • »29.09.05 - 12:50
    CISC
    Works fine here, just make sure you select an AHI unit that's configured to use a ++ mode...
    - CISC
  • »29.09.05 - 13:58
    Selected AHI Unit is a ++ mode, i've tried 8Bit ++, 16 Bit ++ and 16Bit Hifi ++ Modes.
    All i get is a short scratching noise.
    Its really weird because the demo-version has sound.
    And yes, it's set on AHI not Paula. :/
    Bye
    TriMa
  • »29.09.05 - 15:38
    Toto
    Posts: 268 from 2003/4/20
    Shogo, Heretic II, Freespace, Wipeout and Quake2 all work fine here.
    Wtih Q2 I had the most problems, couldn't install from cd so I copied Q2 from my A4000 to my Peg. Also had a lot of fun installing Q2 on my Amiga
    With some games the installers wouldn't install on large partitions. I installed these games on my scratch partition wich is 4GB. When the installation was done I moved the games where I wanted them in the first place. You have to edit some env vars for this to work.
    With Quake 3 I have no problems, only when I use mod files. The game begins good but after a few minutes the textures are all wrong.
    [ Edited by Toto on 2005/9/29 18:48 ]
  • »29.09.05 - 16:47
