Amiga version of Heretic II working now!
    Rabel1
    Posts: 10 from 2004/2/20
    I just upgraded to MorphOS 1.4.5 on my PEG 2 and then added the 3d support. After installing the Hyperion Amiga version of Heretic II the game works well. I had to switch the soundcard to "AHI" but that was all. I'm running at 640x480 resolution right now.
  • »04.09.05 - 16:23
    MarK
    Posts: 641 from 2004/1/25
    here it works smoothly also in 1600x1200 :-) i will probably try to finish this game again ;-)
    bye, MarK.
  • »05.09.05 - 07:42
    Posts: 108 from 2005/4/3
    Hi all,
    Copy my old (updated) Heretic II to my Pegasos II, the game freezes.
    How to turn on the AHI ? All it does is the startup GUI, where i can't
    find the sound options. Maybe i must do a fresh installation again.
    Shogo (updated with archive "missing.lha") works smoothly, i wasn't
    able to run the game with my Amiga1200 with Picasso96 graphics.
    Payback goes very slow, unplayble, seems AHI needed. Quake with Frank
    Wille's MOS port plays smoothly.
  • »05.09.05 - 09:05
    hooligan
    Posts: 1948 from 2003/2/23
    Strange... it works very fast on my R9100 .. but it has doublebuffer-problems and the flickering is killing me, and as you mentioned, indeed it needs AHI for maximum pleasure.
  • »05.09.05 - 09:19
    Posts: 1084 from 2003/3/24
    I am playing Heretic2 in 1280x1024 and i have on top and
    bottom bars that are flickering, and making me and my eyes mad.
    How can i get rid of them?
  • »05.09.05 - 18:03
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    you can edit the config file manually (text format):
    search for amisnd.dll and replace it with ahisnd.dll .
    Couldn't try it myself as the demo version doesn't support AHI (-> game works fine but no sound then...)
  • »06.09.05 - 06:20
    MarK
    perhaps you should try 1280x960, as it's ratio is 4:3, not 5:4 (like 1280x1024), this should avoid those flickering borders...
    bye, MarK.
  • »06.09.05 - 10:07
