Quake 2 installer?
  • ocs
    ocs
    Posts: 47 from 2004/4/3
    Hello.
    I try to install A Quake 2 ppc original, a freeze in the 2cond disc.
    How to install this great game in morphos 1.4.2?
    (the same question in Shogo and freespace ;))
  • »29.05.04 - 10:34
    Posts: 1932 from 2003/10/19
    I've had the same problems with those games. I can no longer find my Amiga Quake 2 CD, but i never did get it working on the Pegasos.
    If anyone know knows how to get these working please post a reply. I am sure several people have had this happen to them.
  • »29.05.04 - 12:28
    Jupp3
    Posts: 1193 from 2003/2/24
    afaik, Shogo doesn't work on Radeon boards (endianity problem)
    And for Quake2, can't you just copy the amiga executable manually and copy "baseq2" drawer from PC Quake 2 CD?
    (Note, I don't know how Hyperion put their Q2 port on CD)
  • »29.05.04 - 13:01
    roschmyr
    Posts: 210 from 2003/2/20
    i did my installation in my Mos-UAE and copied the Files to my
    Games-dir :-) or you installed it on your old AMIGA and copy it then
    to the Pegasos.
  • »29.05.04 - 13:34
  • HAK
    Posts: 225 from 2003/2/24
    Quake2:
    Back when I got my Pegasos I only transferred an already installed Quake2 from my Amiga to my Pegasos.
    Later I heard that people had problem when installing Q2 on the Pegasos. I found out that the installation script stalls at the part where it tries to unpack the pak-files (problem of the tool that is used for unpacking those files).
    However, it should be possible to edit the install-script that - instead of unpacking the pak-files - it only copies them to the baseq2-directory. The only drawback should be that loading takes some more time when playing because Q2 has to extract the data from the pak-files instead of an already unpacked directory structure.
    Shogo:
    Hm, can't remember that I had problems when installing this one.
    It also works with both my gfx-cards (PCI-Voodoo3 3000 and AGP-Radeon 7000/VE).
    The only funny thing I encountered was, that when playing with software renderer (either Voodoo or Radeon) I get an error message that Shogo can't initialize the sound system when loading and I get no sound during the game.
    This does not happen when I'm using the Voodoo with hardware rendering where everything works OK.
    Freespace:
    Sorry, haven't tried this one yet - lack of time - as I first had to finish my "tests"  :-D with Heretic II.
    Bye HAK
  • »29.05.04 - 15:26
  • ocs
    ocs
    More Thanks :)
    Ya me va el q2 pero no se como lo he hecho :D
    regards.
  • »29.05.04 - 18:51
    Trizt
    Posts: 17 from 2003/6/1
    It's not difficult to pack up the pak-files, as those are just "normal" zip archives.
  • »01.07.04 - 17:49
  • HAK
    Unfortunately, this is not correct for QuakeI and QuakeII pak-files which uses their own format.
    However, AFAIK it is true for QuakeIII pak-files.
    Bye HAK
  • »02.07.04 - 09:08
