Return to the Roots (Settlers 2.5)
    Lord76
    Posts: 81 from 2014/8/31
    Great now it works :-) thx Beworld & BSzili for your work
    offtopic:
    a port auf UFO AI 2.5 and settlers 3 where on my wish list :-) is there any chance?
    Powerbook G4 A1138/39
    Powermac G5 2.7ghz / G5 11.2 2.3ghz
    Amiga1200 V1200/Pistorm
  • »19.03.17 - 10:21
    beworld
    Posts: 669 from 2010/2/10
    Settlers 3 : http://osgameclones.com/ ... java clone :( so not possible
    UFO.... maybe with Fab1 's source.
    IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »19.03.17 - 14:48
    Lord76
    Hello again,
    my beloved Game Settler2 works not more with Morphos 3.15.
    Only Sound works, what i see is Black Screen or Strips, have an G4 Powerbook A1138 from 2005, other Games has no Problems.
    Can anyone fix this, an a other Question: the Port availble is from 2017 , can anyone upgrade this to newer Version?
    thanks
    [ Editiert durch Lord76 24.04.2021 - 15:52 ]
  • »24.04.21 - 11:52
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    I can confirm the same issues as Lord76 on my PowerBook G4. The current port only opens a windows with graphics glitches and 100 % CPU-Load. The G4 needs a reboot after that.
    @beworld: Can you perhaps have look at the issue? Current RttR also got lots of bug fixes and performance improvements since your port from 2017.
  • »01.05.21 - 09:09
    Lord76
    @Beworld
    Any news or Bugfixes? Greetings
  • »15.02.22 - 08:19
    beworld
    for information, i work on last s25rttr.. and good new ^^ i can build it and working... need some love ;-)
    My MOS ports
  • »15.04.26 - 12:21
