Stratagus 2.4.2
    Cool_amigaN
    Posts: 772 from 2011/11/30
    Hey, I have downloaded beworld's Stratagus port from MorphOS Storage and for the last 2 hours I am trying to install WarCraft II TOD (Wargus) without any success :(
    First of all, I take for granted that my BattleNET edition still isn't fully supported, right? Because initially I was getting the same error as described by OP here: https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6799&forum=10#130660
    I proceeded into installing a DOS ISO version on Win7, extracted the data from Wargus win version, copied them on MorphOS but the result was the same. BTW, according to snoopium the path is automatically created at progdir:home/wc2 so, placing the data set to any other destination resulted into fail even though I had ammended the -d option on the script. So, correct code seems to be:
    stack 2097152
    stratagus -d PROGDIR:home/wc2 >stratagus.out *>stratagus.err
    Then, I re-run the installer on Windows and asked for the Alloena data set. Copied some extra sound set (neutral and human) from Win to MorphOS but still the following errors persist:
    Can't open file 'orc/units/teron_gorefiend/acknowledgement/1.wav'
    Can't load the sound 'orc/units/teron_gorefiend/acknowledgement/1.wav'
    Can't open file 'orc/units/dentarg/acknowledgement/1.wav'
    Can't load the sound 'orc/units/dentarg/acknowledgement/1.wav'
    Can't open file 'orc/units/grom_hellscream/acknowledgement/1.wav'
    Can't load the sound 'orc/units/grom_hellscream/acknowledgement/1.wav'
    Can't open file 'orc/units/deathwing/acknowledgement/1.wav'
    Can't load the sound 'orc/units/deathwing/acknowledgement/1.wav'
    Can't open file 'orc/units/korgath_bladefist/acknowledgement/1.wav'
    Can't load the sound 'orc/units/korgath_bladefist/acknowledgement/1.wav'
    Can't open file 'orc/units/deathwing/selected/1.wav'
    Can't load the sound 'orc/units/deathwing/selected/1.wav'
    Can't open file 'orc/units/dentarg/selected/1.wav'
    Can't load the sound 'orc/units/dentarg/selected/1.wav'
    Can't open file 'orc/units/grom_hellscream/selected/1.wav'
    Can't load the sound 'orc/units/grom_hellscream/selected/1.wav'
    Can't open file 'orc/units/korgath_bladefist/selected/1.wav'
    Can't load the sound 'orc/units/korgath_bladefist/selected/1.wav'
    Can't open file 'orc/units/teron_gorefiend/selected/1.wav'
    Can't load the sound 'orc/units/teron_gorefiend/selected/1.wav'
    Can't open file 'orc/units/deathwing/annoyed/1.wav'
    Can't load the sound 'orc/units/deathwing/annoyed/1.wav'
    Can't open file 'orc/units/dentarg/annoyed/1.wav'
    Can't load the sound 'orc/units/dentarg/annoyed/1.wav'
    Can't open file 'orc/units/grom_hellscream/annoyed/1.wav'
    Can't load the sound 'orc/units/grom_hellscream/annoyed/1.wav'
    Can't open file 'orc/units/korgath_bladefist/annoyed/1.wav'
    Can't load the sound 'orc/units/korgath_bladefist/annoyed/1.wav'
    Can't open file 'orc/units/teron_gorefiend/annoyed/1.wav'
    Can't load the sound 'orc/units/teron_gorefiend/annoyed/1.wav'
    Unsupported tag: CanGroundAttack
    stack traceback:
    [C]: in function 'DefineUnitType'
    [string "PROGDIR:home/wc2/scripts/human/units.lua"]:154: in main chunk
    [C]: in function 'Load'
    [string "PROGDIR:home/wc2/scripts/units.lua"]:499: in main chunk
    [string "PROGDIR:home/wc2/scripts/stratagus.lua"]:484: in main chunk
    src/unit/script_unittype.cpp:1107: CclDefineUnitType: Unsupported tag: CanGroundAttack
    I even checked at Wargus trunk over at GitHUB but these files (.wav) seems to be missing. Note that the game launches and plays fine on Wargus/Stratagus Windows with my current installation that was transferred to MorphOS.
    So, to sum up:
    1) After 4 different downloaded versions that failed (both DOS and Win 95), can anyone point to a valid ISO that will work? Even, better how about an HD rip or just lha the files missing up above? Do you actually need the Alloena files to play the game?
    2) Port instructions not clear if you can go with CD or MIDI music during Windows installation before copying the files to MorphOS.
    3) Snoopium also reported some SDK links but now that I re-run the script they don't appear somehow..
    [ Edited by Cool_amigaN 27.02.2018 - 21:19 ]
  • »27.02.18 - 18:17
    beworld
    Posts: 664 from 2010/2/10
    In dead BattleNET edition isnt supported
    Ok place your data to progdir:wc2
    Edit the script :
    stack 2097152
    stratagus -d wc2
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »28.02.18 - 04:40
    Cool_amigaN
    Ok, thanks for confirming the BattleNET edition.
    However, it still isn't clear, does your port support midi or cd music?
    Also, any ideas regarding the the error up above I posted? Can you check your folders whether the include the .wav files in question? Because my folders are empty.
  • »28.02.18 - 11:11
    beworld
    Yes it's support sound and music.
    But you need data from Windows or linux (Wartool)
    no idea, but when i test, i use my wartool port (not include in this archive) and next i copie music and sound from Windows version.
    I check that when i finish my next port (Wrymnus) (actually i test it)
    And i found some fix in engines that i can apply in stratagus :-) (working Network, some paths bug....)
    My MOS ports
  • »28.02.18 - 13:11
    Cool_amigaN
    Ok, let me clarify a bit more, the sound set missing, is part of Aleona Tales - not from Warcraft 2. I am not sure why your recent port of Stratagus requests it, but on Windows, it gets ignored.
    Extra title set of Aleona can be installed from Windows' Wargus installer during the options menu or from here.
    However, the orcs sound set is missing even on both aforementioned sources. Perhaps this is an old dependency that should be removed?
    Can you check in your progdir:wc2/sounds/orc/sound/teron_gorefiend | dentarg | deathwing | korgath_bladefist | grom_hellscream if you have the .wavs installed or are your drawers empty as well? If yes, can you lha/upload them or can you point where you found them?
  • »28.02.18 - 16:55
    beworld
    I don't have this sound in my MOS install
    wc2 / sounds / orc / , i have :
    - basic_voices (dir)
    - buildings (dir)
    - peon (dir)
    - ships (dir)
    - units (dir)
    - act.wav.gz
    - capture.wav.gz
    - rescue.wav.gz
    Just one thing, i use ISO french version :
    Warcraft2 BTDP (iso found in abandon abandonware
    and Warcraft2 TOD
    My MOS ports
  • »28.02.18 - 17:10
    beworld
    I re-upload a version with more things and explication.
    I put wartool into.
    Normally network game working... i dont test
    My MOS ports
  • »01.03.18 - 12:16
    Solo_Kazuki
    Posts: 182 from 2006/7/23
    Hello
    I'm trying to run Warcraft data from PC version War1gus 2.4.2 (same version). Whilst on PC campaign works, on MorphOS when i'm trying begin campaign after first animation of map i get exception error:
    >>> Exception 3 <Illegal Data Access at 00000000 DSISR 0a000000, Store is not allowed because of protection modes>
    Quark Thread TID 0000000010020010 Name ABox
    SRR0 0x101162a4 SRR1 0x0200f030
    LR 0x1cc93e30 CTR 0x10116228
    CR 0x82002244 XER 0x20000000
    GPR[00] 00000100 1ed1c240 1ed1c870 fffffec2 00000001 10116228 1e3635c8 00000010
    GPR[08] 1e44b554 00000000 1e44b550 1ed1c250 28000244 1c9bad90 1eb2ffe0 1d396264
    GPR[16] 00000000 00000040 1cd30000 1c954c98 1c954c70 1eb2ffe0 0002b110 00004000
    GPR[24] 1e44b572 00000001 00000000 1ed1c278 ffffffff 00000001 1e3635c8 14001948
    FPSCR 43efff0000104040
    FPR[00] 4030000000000000 0000000000000000 1e49307800000000 0000000500000000
    FPR[04] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[08] 0000000000000000 4330000000000384 3f76c16c20000000 433000008000001e
    FPR[12] 403e000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[16] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[20] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[24] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[28] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    VSAVE 00000000 VSCR 00010000
    VPR[00] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[02] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[04] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[06] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[08] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[10] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[12] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[14] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[16] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[18] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[20] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[22] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[24] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[26] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[28] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[30] 00000000000000000000000000000000 00000000000000000000000000000000
    IABR 00000000
    DABR 00000000
    MMCR0 00000000
    MMCR1 00000000
    MMCR2 00000000
    PMC1 00000000 PMC2 00000000 PMC3 00000000 PMC4 00000000
    SIA 00000000
    SDA 00000000
    >>> Quark Thread Stack History
    StackFrame[ 0].LR[0x1cc93e30] -> LIBS:powersdl.library [Hunk 1 Offset 0x00026e48]
    StackFrame[ 1].LR[0x1cc93764] -> LIBS:powersdl.library [Hunk 1 Offset 0x0002677c]
    StackFrame[ 2].LR[0x1cc93398] -> LIBS:powersdl.library [Hunk 1 Offset 0x000263b0]
    StackFrame[ 3].LR[0x1cc72c98] -> LIBS:powersdl.library [Hunk 1 Offset 0x00005cb0]
    StackFrame[ 4].LR[0x1dba6cc4]
    StackFrame[ 5].LR[0x1dab02ac]
    StackFrame[ 6].LR[0x1cc7f230] -> LIBS:powersdl.library [Hunk 1 Offset 0x00012248]
    StackFrame[ 7].LR[0x1cc94a1c] -> LIBS:powersdl.library [Hunk 1 Offset 0x00027a34]
    StackFrame[ 8].LR[0x10290ed4] -> dos.elf [Hunk 0 Offset 0x0000fbbc]
    StackFrame[ 9].LR[0x10290cfc] -> dos.elf [Hunk 0 Offset 0x0000f9e4]
    StackFrame[10].LR[0x10290fc8] -> dos.elf [Hunk 0 Offset 0x0000fcb0]
    >>> ABox State
    ExecBase: SysBase 0x14001948
    SysFlags 0x8000 AttnResched 0x0000 IDNestCnt -1 TDNestCnt 0
    ThisTask 0x1e3635c8 TaskReady 0x1417c2a0 TaskWait 0x14010ad8
    ResModules 0x14003ff8
    TaskTrapCode 0x10120b2c TaskExceptCode 0x10120b34 TaskExitCode 0x10120b90
    TaskSigAlloc 0xffff TaskTrapAlloc 0x8000
    IdleCount 33300 DispCount 269972
    Quantum 4 Elapsed 4
    VBlankFrequency 50 PowerSupplyFrequency 50 EClockFrequency 709379
    MainTID 0x10020010 SchedulerTID 0x10020012 SchedulerSig 0x80000000
    OldSRR0 0x0
    ConfigServerTID 0x10000013
    LastIntObject 0x1417c25c
    LastIntObject 0x1417c25c <Not Valid ptr>
    Code 0x1045b8dc Data 0x1408e8b0
    Int0: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int1: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int2: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int3: iv_Code 0x1012603c iv_Data 0x14003b30 iv_Node 0x00000000
    Int4: iv_Code 0x1012603c iv_Data 0x14003b50 iv_Node 0x00000000
    Int5: iv_Code 0x1012603c iv_Data 0x14003b40 iv_Node 0x00000000
    Interrupt 0x1403319e <graphics.library>
    Code 0x1018855c Data 0x14033154
    Interrupt 0x19c35950 <ixemul timer interrupt>
    Code 0x19c32b08 Data 0x00000000
    Int6: iv_Code 0x10188564 iv_Data 0x14033154 iv_Node 0x140331ca
    Int7: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int8: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int9: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int10: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int11: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int12: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int13: iv_Code 0x1012603c iv_Data 0x14003b60 iv_Node 0x00000000
    Int14: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int15: iv_Code 0x1012603c iv_Data 0x14003b70 iv_Node 0x00000000
    >>> Running Task
    Task 0x1e3635c8 Name 0x1e3646ac <SDL subtask> Type 13 Pri -1
    Flags 0x8 State 2 IDNestCnt -1 TDNestCnt -1
    SigAlloc 0x0000ffff SigWait 0xc0001000 SigRecvd 0x00000100 SigExcept 0x00000000
    ExceptCode 0x10120b34 ExceptData 0x00000000 TrapCode 0x10120b2c TrapData 0x00000000
    Switch 0x00000000 Launch 0x00000000 UserData 0x00000000
    SPLower 0x1e3636ac SPUpper 0x1e3646ac SPReg 0x1e364648
    MemList 0x1e448400 Entries 0x1
    Address 0x1e4a9ec0 Size 0x20
    MemList 0x1e42bff8 Entries 0x1
    Address 0x1e3635c8 Size 0x10f0
    ETask 0x1e49e2cc
    MemPool 0x1cbbecf0 PPCLibData 0x00000000
    PPCSPLower 0x1eb344ec PPCSPUpper 0x1ed1c960
    PPCTrapMsgPort 0x00000000 PPCTrapMessage 0x1e40a2bc
    PPCRegFrame 0x1ed1c480
    Private[] 0x00000000 0x00000000 0x00000000 0x00000000
    EmulHandle 0x00000000
    EmulHandle 0x1ed1c870 Type 0x00000004 Flags 0x00000001
    SuperHandle 0x10001000 Type 0x00000000 WaitMask 0x00000000 SyncMask 0x00000000
    USP 0x00000000 SSP 0x14003790 VBR 0x1400e128
    SFC 0x00000000 DFC 0x00000000 CACR 0xa0808000 TC 0x00000000
    ITT0 0x00000000 ITT1 0x00000000 DTT0 0x00000000 DTT1 0x00000000
    URP 0x00000000 SRP 0x00000000 BUSCR 0x00000000 PCR 0x04310501
    >>> Task Registers Frame
    VPR[00] 1133b996000000080000000178300000 11330000000000001a1a1a1a1b1b1b1b
    VPR[02] 1c1c1c1c1d1d1d1d1e1e1e1e1f1f1f1f 1000d970000432b41e1e1e1e0000000a
    VPR[04] 10290fc811394765000000000000fcb0 1133b9341133b93414001b5c1133b884
    VPR[06] 14003ef01d1d1d1d1e1e1e1e1f1f1f1f 10127fd8000432b40000000000000000
    VPR[08] 1000d97011006bb41139476500000aa1 10290fc81000d9781000d97c1000d980
    VPR[10] 14001948000000000000000000000000 1000d9601000d9780000000000000030
    VPR[12] 1000d9700001175c1000d8d800000000 1000d980000433d40000000000000000
    VPR[14] 1000d9c000043b802002488413131313 1000d9a0151515151000d9f00000000a
    VPR[16] 1000d9b00001175c1e1e1e1e0000000a 1000d9c00001175c1000d9f000000000
    VPR[18] 1000d9d0000433d4000000001000dad0 1000da50000444640000000178300000
    VPR[20] 00000000000000000000000000000000 30003000336237300000000000000000
    VPR[22] 00000000000000000000000000000000 1133b848000000000000000000000000
    VPR[24] 11339968000000001a1a1a1a1b1b1b1b 1c1c1c1c1d1d1d1d1a1a1a1a1b1b1b1b
    VPR[26] 1c1c1c1c1d1d1d1d1e1e1e1e1f1f1f1f 1000daf0000432b40000000000000000
    VPR[28] 0000000100b120080000000a00001680 1133a34800b1368f0000000000000000
    >>> Task Stack History
    SRR0[0x101162a4] -> exec_of_604e.elf [Hunk 0 Offset 0x000162a4 Function ObtainSemaphore]
    CTR[0x10116228] -> exec_of_604e.elf [Hunk 0 Offset 0x00016228 Function ObtainSemaphore]
    Stack: 0x1ed1c240
    0x1ed1c220[-0x20] 1c9b2f58 1ed1c248 00000064 1e37f148
    0x1ed1c230[-0x10] 1ed1c240 1cc94154 1e37f17a 1e37f176
    0x1ed1c240[0x000] 1ed1c270 101162e4 00000000 ee3b56a3
    0x1ed1c250[0x010] 1e44b554 00000000 1e3635c8 1ed1c278
    0x101162e4 -> exec_of_604e.elf [Hunk 0 Offset 0x000162e4 Function ObtainSemaphore]
    >>> Full PPC mode: Last saved 68k context
    PC 87654321 SR 0008
    Dn[0] 0000001f 00000033 1e410f0c 1e3eeb48 1ee0ca10 00004000 00000000 00000000
    An[0] 1e44b540 00000000 00000000 00000000 00000000 00000000 14001948 1e3646a8
    Stack: 0x1e3646a8
    0x1e364688[-0x20] 00000000 00000000 00000000 00000000
    0x1e364698[-0x10] 00000000 00000000 00000000 1133ec40
    0x1e3646a8[0x000] 00001000 53444c20 73756274 61736b00
    0x1e3646b8[0x010] 1e3635c0 00000411 14000034 14000034
    0x1e3646c8[0x020] 00000408 00000000 fcf8f000 f4e02000
    0x1e3646d8[0x030] d0c01c00 a88c1000 5c300000 00000000
    0x1e3646e8[0x040] 6c6c6c00 00000000 00000000 00000000
    0x1e3646f8[0x050] 00000000 00000000 00000000 00000000
    0x1e364708[0x060] 00000000 00000000 00000000 00000000
    0x1e364718[0x070] 00000000 00000000 00000000 00000000
    >>> Last saved PPCThread State
    SRR0 0x1011fca0 SRR1 0x0200f030
    LR 0x1010ee98 CTR 0x00000000
    CR 0x88440882 XER 0x20000000
    GPR[00] 1dab032c 1ed1c1e0 1ed1c870 1ed1c328 ffff8000 00007fff 1e3635c8 1eb2ffe0
    GPR[08] ffffffff 00000000 00000000 00000000 28000884 1c9bad90 1eb2ffe0 1d396264
    GPR[16] 00000000 00000040 1cd30000 1c954c98 1c954c70 00000000 00004000 00000004
    GPR[24] ffffffff 14001af0 14001aec 00000000 ffffffff 88440842 14001948 1e3635c8
    SRR0[0x1011fca0] -> exec_of_604e.elf [Hunk 0 Offset 0x0001fca0]
    LR[0x1010ee98] -> exec_of_604e.elf [Hunk 0 Offset 0x0000ee98 Function Wait]
    StackFrame[ 0].LR[0x10115fc4] -> exec_of_604e.elf [Hunk 0 Offset 0x00015fc4 Function ReleaseSemaphore]
    StackFrame[ 1].LR[0x1cc94154] -> LIBS:powersdl.library [Hunk 1 Offset 0x0002716c]
    StackFrame[ 2].LR[0x101162e4] -> exec_of_604e.elf [Hunk 0 Offset 0x000162e4 Function ObtainSemaphore]
    StackFrame[ 3].LR[0x1cc93e30] -> LIBS:powersdl.library [Hunk 1 Offset 0x00026e48]
    StackFrame[ 4].LR[0x1cc93764] -> LIBS:powersdl.library [Hunk 1 Offset 0x0002677c]
    StackFrame[ 5].LR[0x1cc93398] -> LIBS:powersdl.library [Hunk 1 Offset 0x000263b0]
    StackFrame[ 6].LR[0x1cc72c98] -> LIBS:powersdl.library [Hunk 1 Offset 0x00005cb0]
    StackFrame[ 7].LR[0x1dba6cc4]
    StackFrame[ 8].LR[0x1dab02ac]
    StackFrame[ 9].LR[0x1cc7f230] -> LIBS:powersdl.library [Hunk 1 Offset 0x00012248]
    StackFrame[10].LR[0x1cc94a1c] -> LIBS:powersdl.library [Hunk 1 Offset 0x00027a34]
    StackFrame[11].LR[0x10290ed4] -> dos.elf [Hunk 0 Offset 0x0000fbbc]
    StackFrame[12].LR[0x10290cfc] -> dos.elf [Hunk 0 Offset 0x0000f9e4]
    StackFrame[13].LR[0x10290fc8] -> dos.elf [Hunk 0 Offset 0x0000fcb0]
    SegList 0x0792a7b0 GlobVec 0x14028294
    StackBase 0x078d8dab StackSize 0x00001000
    TaskNum 0x00000000 Result2 0x00000000
    CurrentDir 0x079043ac CIS 0x0792b68d
    COS 0x06892905 CES 0x00000000
    ConsoleTask 0x00000000 FileSystemTask 0x142c12c4
    CLI 0x00000000 ReturnAddr 0x1e3646a8
    PktWait 0x00000000 WindowPtr 0x00000000
    HomeDir 0x07903628 Flags 0x0000004a
    ExitCode 0x00000000 ExitData 0x00000000
    Arguments 0x00000000 ShellPrivate 0x00000000
    >>> End of Exception State Dump
  • »27.04.19 - 07:48
    beworld
    Hey,
    i just port stratagus 3.3.3, anyone can test ? (PM plz)
    My MOS ports
  • »19.04.25 - 09:03
