Openmohaa
    beworld
    Posts: 683 from 2010/2/10
    Working very nice now !
    I could path it with french language :-)
    Thanks again
    My MOS ports
  • »19.11.24 - 15:27
    Posts: 110 from 2020/12/24
    @Skateman
    Change to windowmode by disabling r_fullscreen in config and see what's going on the shell. Also by setting developer mode (+set developer 1) for more clues.
    It looks like textures aren't loaded properly (or missing from paks): I've seen those black/white wireframes when I disabled on purpose "multitexture" and some of the drawings on scene were missing (only some of them) but not like the pictures you showed.
    The multiple unaligned array of stripes are suspicious too. Gfx driver issue ?
    Note: For a while SDL2 2.30.9 library was not working properly and 2.30.7 was needed. Today I see a new 2.30.9 uploaded. Will try later.
    [ Edited by Cowcat 22.11.2024 - 07:26 ]
  • »22.11.24 - 06:21
    Posts: 54 from 2020/10/11
    Cowcat wrote:
    @Skateman
    Thanks, i will try your settings.
    I did try other games like ioq3, bugdom etc to see if this problem has to do with the system config, but all these games work fine.
    Made a quick video showing the system is game capable and ends with OpenMohaa texture stuff.
    https://youtu.be/FVlX1oUNZ60
  • »22.11.24 - 14:03
