which files are used by MOL
    serge
    Posts: 725 from 2003/2/20
    Hello,
    I'm searching which files are used by MOL, because I must uninstall it and would like to control which files will be delated to save them before.
    I'm afraid to couldn't re-install it later.
    Maybe, there is an install-log file somewhere, or a command building this liste of files, but which?
    Thanks
    Serge
  • »22.04.04 - 07:56
    dholm
    Posts: 296 from 2003/9/1
    It would of course help to know which Linux distribution you are using.
    If you are using Gentoo you can find a listing of which files it have installed in /var/db/pkg/app-emulation/mol/CONTENTS you can also run "quickpkg mol" which will put all the installed files in /usr/portage/packages/All/mol-<version>.tbz2 which you can emerge at a later time.
  • »22.04.04 - 08:58
