Quake2 on a G5 2.0 with Radeon 1950 Pro
    gothor
    Posts: 33 from 2011/4/6
    i installed Quake2 and it starts too. Unfortunately, the graphic does not work. The sound is there and I also hear the sounds and can navigate by the Menu, but the graph looks destroyed. Someone an idea?
    Thx
    Christoph
  • »16.03.22 - 10:10
    waldiamiga
    Posts: 95 from 2007/7/25
    Which game port are you using? Bigfoot or BSzili?
    You'll find both here.
    https://www.morphos-storage.net/?find=Quake
    MorphOS.pl
    Alienware 15 R3|WinUAE 5.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 9.x.x
  • »16.03.22 - 13:24
    gothor
    thx for your answer, both version has the same issue.
    Gothor
  • »16.03.22 - 16:59
