Posts: 683 from 2010/2/10
I test to disable/enable music.. quit restart etc..., i test on my MacMini clean install, and on my PM G5 dev environement.. no problem here.
Some ideas :
- Have you something in log (console) ?
- What is your hardware ?
- Have you a last SDL2 package ?
- Have you a "HOME" file in your ENV: / ENVARC: ? if yes, delete it
- Try to delete sw.cfg
- check with Snoopium if sw.cfg is in current directory and when you quit check if "Modify = OK" on sw.cfg
Thanks
My MOS ports
