What i need for run UAE?
  • ocs
    ocs
    Posts: 47 from 2004/4/3
    Hello, I try for run UAE but not screen apperar and in the readme no writte the sofware/libs requeriments.
    I have install for run UAE?
    p.d.Sorry for my english
  • »09.04.04 - 05:57
    DJBase
    Posts: 745 from 2003/4/6
    Try this package http://www.pegasosforum.de/load.php?id=12
  • »09.04.04 - 07:10
  • ocs
    ocs
  • »09.04.04 - 07:23
    Wishmaster
    Posts: 342 from 2003/6/29
    The GUI needs muirexx.
    Install muirexx or start UAE by hand in the shell and when you have figured out the correct aprameters put them into an IconX script.
    Pegasos PPC
  • »09.04.04 - 09:33
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    You also need the right icon.mcc. On aminet there are two. You need the older one IIRC.
  • »09.04.04 - 13:00
    MorphDelf
    Posts: 274 from 2004/2/20
    Can someone here set up a workguide for uae for morphos?
    That would be nice,...
    Regards,
    Michal
  • »10.04.04 - 08:44
