crispy-doom-5-8-0
    Korni
    Posts: 473 from 2006/2/23
    http://korni.ppa.pl/meow/crispy-doom-5-8-0.lha.xz
    - Uses software render only (but should work with accelerated as soon as SDL2.library gets it).
    - Mid playback does not work, timidity not tested, sc-55 music packs work.
  • »04.05.20 - 19:07
    beworld
    Posts: 683 from 2010/2/10
    Thanks for first use of SDL2 porting :-)
    To be sur, i re-test SDL2_mixer with MIDI, and it's working well.
    My MOS ports
  • »05.05.20 - 11:08
    Korni
    No, thank you :). Crispy handles mid a bit different than in chocolate (it worked there), also it didn't work in previous crispybased on sdl1, so I borked something there with paths probably.
    Anyway I suggest using sc55 recordings as they sound really nice. Unfortunately available only for selected music. No recording for sigill for example. Though there is also a separate soundtrack not midi based which should work fine with crispy.
  • »05.05.20 - 15:33
