Timidity install for SDL
    beworld
    Posts: 667 from 2010/2/10
    Hi all !
    Just a stupid question..
    How install timidity on MorphOS. (http://www.libsdl.org/projects/SDL_mixer/timidity/timidity.tar.gz)
    For EasyRPG for example.
    I try to compile another SDL game with midi music.
    Thanks
    [ Edité par beworld 05.01.2019 - 09:00 ]
    IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »05.01.19 - 06:22
    BSzili
    Posts: 570 from 2012/6/8
    EasyRPG has WildMidi built in, so just extract that archive next to the executable. For the rest I have no idea, I don't know if SDL_mixer in PowerSDL is built with Timidity enabled.
  • »08.01.19 - 13:50
    beworld
    ok thanks
    For SDL_Mixer, i dont think., i dont find any doc for that.
    My MOS ports
  • »08.01.19 - 13:52
