Flare 0.18
    amyren
    Posts: 219 from 2010/5/15
    The Flare 0.18 port was mentioned in Amiga Future 134.
    I downloaded the archive and extracted it. There was no installer, no program icon, and I did not find any MorphOS release notes either.
    Launching the executable will open a console output window telling that joystick have been found, and a black application window. After a short while this window shows the application is meditating message.
    Anyone got this game to run?
    I ran it on a MacMini with 64mb vram and 512mb ram, are perhaps the requirements higher than that?
  • »14.09.18 - 15:28
    NewSense
    Posts: 1619 from 2012/11/9
    My observations are the same, and I see there is also a comment on the MorphOS Storage download to a similar effect. :-(
  • »15.09.18 - 02:46
    beworld
    Posts: 683 from 2010/2/10
    hello
    Have you edit settings.txt and modify hwsurface=0
    I check if i can update-it
    [ Edité par beworld 15.09.2018 - 11:09 ]
    My MOS ports
  • »15.09.18 - 05:47
    amyren
    Thanks for the input.
    hwsurface=0 did not work, but setting fullscreen=1 did make it work
  • »15.09.18 - 18:06
    tolkien
    Posts: 585 from 2013/5/29
    I have used
    fullscreen=1
    hwsurface=0
    doublebuf=0
    in settings.txt and now it works "correctly" (some issues with sound)
  • »16.09.18 - 13:42
    amyren
    I also have some noise in those audio effects.
    Other than that I did not change those hwsurface and doublebuf settings, they are both set to 1 here.
    Also I did change the resolution to 800x600 and the game seem to run quite well.
    There is a small graphis glitch at the start when selecting your character, the window will not show the character, only a square purple filled area. The same is the case for what I asume is suposed to be a preview when selecting a saved game to load.
  • »16.09.18 - 15:51
    tolkien
    Yes...I have all those glitches in audio and video but seems the game can be played.
  • »16.09.18 - 17:13
