MiniSlug - Beworld port issues
    Posts: 1362 from 2004/2/8
    I'm having some issues running the latest MiniSlug ported by Beworld. Can anyone confirm the same behaviour of the game?
    1. The main menu backgroung gfx seem to be broken - covered by gray field from the right, only part of background is visible.
    2. Configuration of keyboard is OK, but then the cfg program recognizes joystick (that I don't have connected) and tries to configure it afterwards. As I have none - it's just endlessly waiting for my joystick input, and the configuration process cannot be finished.
    3. The game when launched in fullscreen mode (F10 if I'm not mistaken) runs with broken colours.
    4. After finishing the first stage nothing happens (I cannot skip to the second one).
    Running on Dual G5 2,7 GHz, Radeon X850XT.
  • »13.02.18 - 07:24
    Posts: 12577 from 2003/5/22
    I'm not at my MorphOS machine currently so can't verify but this is what I (don't) remember from when I tried it last weekend:
    Issue #1: Either not happening here or didn't notice.
    Issue #2: I used default keyboard config, so didn't notice.
    Issue #3: Fullscreen colours are fine here.
    Issue #4: I can definitely confirm this.
    Running on dual-G5 2.3 GHz, Radeon 9600.
  • »13.02.18 - 07:52
    beworld
    Posts: 683 from 2010/2/10
    #1 --> yes animation (GIF file) doesnt working.... i disabled it in next version.
    #4 --> i confim, i fix that
    I re-upload archive
    thanks
    BeWorld
    My MOS ports
  • »13.02.18 - 10:12
    I re-upload archive
    thanks
    BeWorld
    Thanks for a quick reply. Issue #1 fixed, issue #2 and #3 - no (I guess that you don't have such problem on your config? I can take a screenshot/photo/video if it's needed)
    Now for the Issue #4 - the game lets you play level 2, but something strange happens when entering second part of mission 1 (entering the jungle) a window appears saying: "Fin de mission Transit2D_InitClosing" and you have to quickly click the main game window, because it's not active anymore - first soldier will surely kill you before you take game control back.
  • »13.02.18 - 14:36
    Cool_amigaN
    Posts: 777 from 2011/11/30
    Guys, does the port has sound/music enabled? The 68k port that I am using does but beworld's port does not. Can anyone confirm this?
  • »13.02.18 - 15:32
    There's no music, but sound works well here.
  • »13.02.18 - 15:39
    beworld
    yes i know that, i disabled sounds....
    i check if i can enable it
    My MOS ports
  • »13.02.18 - 16:54
    But I do have sounds here - maybe it's because I've switched the config file with the one from 68k version?
  • »13.02.18 - 17:01
    beworld
    no, i disable music only (YM atari files),... sorry
    [ Edité par beworld 13.02.2018 - 19:02 ]
    My MOS ports
  • »13.02.18 - 17:01
    Oli716
    Posts: 16 from 2011/9/18
    Dear Beworld.
    great job on the port, I like the game very much.
    Any chance to get the config program and the animated gif title fixed?
    Thanks for your efforts.
    Best regards,
    Oli
  • »13.02.18 - 17:22
    beworld
    gif no chance (glich total).... config program, it's present in lha archive.
    Music crash game :(.... working a little... but music it's very very ATARI lol (bad)
    My MOS ports
  • »13.02.18 - 17:41
    Oli716
    config program is broken, it displays joystick although I don't have connected a joystick.
    Therefore I can't save the configuration.
    Sorry to bother you ;)
  • »13.02.18 - 17:45
    beworld
    it's just a port :( sorry but i can't modify config.
    Yan can't put anything in joystick ?
    My MOS ports
  • »13.02.18 - 18:07
    Oli716
    yes, I have no joystick connected so no chance to make an input.
    Game still runs with standard configuration though.
    Thanks for your quick response :)
    No issue if you are not able to fix the problems, maybe someone else can do, keep the ports coming, they are very welcome!
  • »13.02.18 - 18:29
    Get the 68k version, run config there and save it. Then just transfer the .cfg file to your MorphOS port directory. Voila, you have working, personalized settings!
  • »13.02.18 - 19:13
    Oli716
    great idea, I will copy the config from my OS4 version over to MorphOS.
  • »13.02.18 - 19:30
    Cool_amigaN
    Yeap, that's what I did as well. Anyhow, music should be enabled because we are losing a lot of fun without the game's soundtrack.
  • »13.02.18 - 19:36
    beworld
    in my test, music work fine in game but doesnt in menu... :(
    I try to deactive in menu, but i dont found....
    For GIF animation, i chack that this week-end.
    My MOS ports
  • »14.02.18 - 05:00
    Oli716
    Thank you very much beworld :)
  • »14.02.18 - 06:16
    beworld
    ok i update with last Ymlib and music working !!
    I upload an update : http://www.morphos-storage.net/?page=Games%2FPlatform&file=MiniSlug.lha
    I check for the last bug : GIF (endian reverse...) this week-end with help (thk HunoPPC) (normally)
    My MOS ports
  • »14.02.18 - 15:42
