Hurrican controls
    amiga4001
    Posts: 454 from 2006/11/16
    I just tried out hurrican on my Peg2 again.
    To my surprise it is now high res on full size screen.
    I started the english joystick and ok the joystick works.
    What I really would like to change is the jump button which is L alt by default.
    I would like to have the joystick up be the jump.
    How do I change this if possible?
  • »06.02.16 - 04:58
    beworld
    Posts: 683 from 2010/2/10
    if HunoPPC port, you find a file "Hunojoy wrapper.cfg", edit it and find the good line ^^
    My MOS ports
  • »06.02.16 - 06:23
    amiga4001
    Yes it is the Hunoppc port.
    I found the config file.
    Not really sure what to change to get it to jump instead of lookup on joy movement.
    It says
    #Up signed integer on joystick1
    #-32768 to 32767
    #Joy1SignedIntegerRIGHT -8000
    And same line again later in the configfile except AXIS2 statement.
  • »06.02.16 - 18:52
    amiga4001
    [ Edited by amiga4001 06.02.2016 - 20:55 ]
  • »06.02.16 - 18:53
    amiga4001
  • »06.02.16 - 18:53
    amiga4001
    [ Edited by amiga4001 06.02.2016 - 20:54 ]
  • »06.02.16 - 18:53
