Posts: 1619 from 2012/11/9
It seems this MorphOS 3.3 update is being a lot more trouble than it's been worth, well maybe not exactly, but is it possible to release an uninstall script on the update ISO/CD, with future MOS releases?
So, if difficulties occur a user can run the UNINSTALL script to remove the problematic update, and re-instate the previous stable MOS, instead of having to start to re-install the OS bit by bit by hand to get it back to the previous version that had been installed.
