Searching for an AGS Interpreter running under MOS
    defender
    Posts: 249 from 2011/4/24
    I wanted to play Zak Mc Kracken 2. It doesn't run on ScummVM and under DosBox there comes a message that I have to get an AGS Interpreter for DOS. As far as my research has gone the DOS version
    does not exist anymore. But maybe there is a way around this. Has anyone a good idea for me?
    greets
  • »25.04.15 - 17:58
    Posts: 12577 from 2003/5/22
    > As far as my research has gone the DOS version does not exist anymore.
    Download AGS 2.6.2 from http://agsarchives.com/engine.html
    This was the last version with MS-DOS support.
    Btw: https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9873&forum=12&start=7
  • »25.04.15 - 19:33
    defender
    Danke, für den Link Andreas. Ich denke das Programm funktioniert unter DOS. Das Spiel jedoch kann
    man nicht auf DOS umbasteln. Das hätte der Autor machen müssen- no reverse enginering possible.
    What a pity. I don't want to play on a windows PC inside a virtuel enviroment (XP).
  • »28.04.15 - 17:18
