Rookie questions about game installations
    WeiXing3D
    Posts: 327 from 2012/6/13
    I have a rookie question about the installation of Aliens vs Predator Classic using the Steam download. I am totally new to Steam so I have never used a game downloaded from there to install any games in Morphos.
    So how do I use the data. I found the folder containing all the data files? I downloaded the game in my PC.
    On a related game question: where do I find the download link for Wipeout 2097?
    Thanks.
  • »05.09.14 - 01:14
    analogkid
    Posts: 722 from 2004/11/3
    Wipeout 2097 is a commercial game, and isn't legally downloadable.
  • »05.09.14 - 04:27
    Posts: 12553 from 2003/5/22
    From the Readme file:
    "Installation:
    Just run the game and let the installer do the work. It will ask for the location of the original data files and copy them to the correct location. Alternatively, you can simply just copy the original game files into the main drawer yourself before starting the game.
    Doesn't this work?
  • »05.09.14 - 10:52
    WeiXing3D
    dude
    Bought the game from Amazon. I need the link to the Morphos port.
    [ Edited by WeiXing3D 05.09.2014 - 09:06 ]
  • »05.09.14 - 15:46
    BSzili
    Posts: 570 from 2012/6/8
    Wipeout 2097 has no MorphOS port, especially not a freely downloadable one. There is a commercial port to classic amigas with PPC accelerators, which is playable on MorphOS too.
  • »05.09.14 - 17:14
    diezi7
    Posts: 167 from 2005/7/25
    And maybe you'll need this patch to make it work?
    Wipeout-Loader
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »05.09.14 - 17:59
    WeiXing3D
    Got it. Thank you all.
  • »05.09.14 - 18:36
    Jupp3
    Posts: 1193 from 2003/2/24
    I think you meant "Works on MorphOS systems with Warp3D compatible gfx card"
    (One of about five games, so not high priority to fix)
  • »18.09.14 - 14:25
    David70
    Posts: 1 from 2014/10/14
    watson
  • »14.10.14 - 11:02
  • vox
    vox
    Posts: 616 from 2003/11/24
    Its not like there is MorphOS executable and PC data files.
    Its Amiga version of Wipeout 2097 that runs on MorphOS.
    So no steam/Amazon PC purchases will help.
    This kind of CD will do.
    http://www.vesalia.de/e_wipeout.htm
    http://amigakit.leamancomputing.com/catalog/product_info.php?products_id=186
  • »14.10.14 - 18:59
