Games that use analogue USB joysticks
    Posts: 3339 from 2003/3/5
    Could you guys name a few games that use the analogue mode of USB joysticks? Any games that support the rumble of some USB pads? I have added a backwards compatibility mode for the Xbox pad into lowlevel.library but need to test it with some games that use these features.
    I know PowerSDL games can use the analogue mode - the question is: which ones?
  • »14.04.14 - 10:04
    guruman
    Posts: 462 from 2003/7/21
    It has been almost 10 years since I last tried an analog joystick on MorphOS (mmmh, time flies!). Anyway, VirtualGP2 supports for sure analog wheels and IIRC should also support analog USB sticks... Give it a try!
    Among SDL ports, I would place my bet on TORCS and Speed Dreams. If they do not support analog input they should be updated to do so, but I think they do since the controls are "fully analog".
    Kind regards,
    Andrea
  • »14.04.14 - 20:49
    Posts: 1102 from 2004/9/23
    BoulderDäsh V5 is supporting rumble via lowlevel.library.
    http://www.geit.de/eng_boulderdaesh.html
    Geit
    [ Edited by geit 15.04.2014 - 02:03 ]
  • »14.04.14 - 21:02
    BSzili
    Posts: 570 from 2012/6/8
    Neither Speed Dreams nor TORCS use SDL for the joytick input, but they do support analog input via lowlevel.library and sensors.library.
  • »15.04.14 - 17:03
    Jupp3
    Posts: 1193 from 2003/2/24
    Many games supported by MAME support analog controls.
    -EDIT-
    If you need specific game, Thunderblade supports 3 analog axis (but I guess only 2 can be used with lowlevel.library)
    [ Edited by Jupp3 16.04.2014 - 14:27 ]
  • »15.04.14 - 18:47
    Thanks for the replies!
  • »16.04.14 - 06:43
    Yasu
    Posts: 1724 from 2012/3/22
    I've just bought myself an XBox 360 controller, but I need some tips on which game I can try it on with. So far I've found none.
    My MorphOS blog
  • »21.04.14 - 14:46
    TORCS. But it will also work on current MorphOS betas with all games that use lowlevel.library.
  • »22.04.14 - 14:40
    Yasu
    @jacadcaps
    I'll try TORCS. But which other games would that be, that use lowlevel.library that is? Can you name a common one?
    My MorphOS blog
  • »22.04.14 - 19:10
