failed to load bullet.library
    defender
    Posts: 249 from 2011/4/24
    Hi there,
    i have scrolled the Best of MorphOS November-December 2013 library
    for games and thought "2 pairs to furious" sounds funny.
    Well that might be true but - nothing happens.
    I got this from snoopium:
    [1] [Background CLI] [Open] [shellppc.prefs] [Lesen] [Fehlgeschlagen]
    [2] [T:HollywoodPlayer] [Open] [PROGDIR:Catalogs/deutsch/Sys/libs.catalog] [Lesen] [Fehlgeschlagen]
    [3] [T:HollywoodPlayer] [Open] [MOSSYS:LOCALE/Catalogs/deutsch/Sys/libs.catalog] [Lesen] [Fehlgeschlagen]
    [4] [T:HollywoodPlayer] [Open] [LOCALE:Catalogs/deutsch/Sys/libs.catalog] [Lesen] [Fehlgeschlagen]
    [5] [ramlib] [Open] [MOSSYS:LIBS/bullet.library.elf] [Lesen] [Fehlgeschlagen]
    [6] [ramlib] [Open] [MOSSYS:LIBS/bullet.library.elf] [Lesen] [Fehlgeschlagen]
    [7] [ramlib] [Load] [MOSSYS:LIBS/bullet.library.elf] [] [Fehlgeschlagen]
    [8] [ramlib] [Open] [MOSSYS:LIBS/bullet.library] [Lesen] [Fehlgeschlagen]
    [9] [ramlib] [Open] [MOSSYS:LIBS/bullet.library] [Lesen] [Fehlgeschlagen]
    [10] [ramlib] [Load] [MOSSYS:LIBS/bullet.library] [] [Fehlgeschlagen]
    [11] [ramlib] [Open] [LIBS:bullet.library.elf] [Lesen] [Fehlgeschlagen]
    [12] [ramlib] [Open] [LIBS:bullet.library.elf] [Lesen] [Fehlgeschlagen]
    [13] [ramlib] [Load] [LIBS:bullet.library.elf] [] [Fehlgeschlagen]
    [14] [ramlib] [Open] [bullet.library.elf] [Lesen] [Fehlgeschlagen]
    [15] [ramlib] [Open] [bullet.library.elf] [Lesen] [Fehlgeschlagen]
    [16] [ramlib] [Load] [bullet.library.elf] [] [Fehlgeschlagen]
    [17] [ramlib] [Open] [LIBS:bullet.library] [Lesen] [Fehlgeschlagen]
    [18] [ramlib] [Open] [LIBS:bullet.library] [Lesen] [Fehlgeschlagen]
    [19] [ramlib] [Load] [LIBS:bullet.library] [] [Fehlgeschlagen]
    [20] [ramlib] [Open] [bullet.library] [Lesen] [Fehlgeschlagen]
    [21] [ramlib] [Open] [bullet.library] [Lesen] [Fehlgeschlagen]
    [22] [ramlib] [Load] [bullet.library] [] [Fehlgeschlagen]
    [23] [ramlib] [Open] [PROGDIR:LIBS/bullet.library.elf] [Lesen] [Fehlgeschlagen]
    [24] [ramlib] [Open] [PROGDIR:LIBS/bullet.library.elf] [Lesen] [Fehlgeschlagen]
    [25] [ramlib] [Load] [PROGDIR:LIBS/bullet.library.elf] [] [Fehlgeschlagen]
    [26] [ramlib] [Open] [PROGDIR:LIBS/bullet.library] [Lesen] [Fehlgeschlagen]
    [27] [ramlib] [Open] [PROGDIR:LIBS/bullet.library] [Lesen] [Fehlgeschlagen]
    [28] [ramlib] [Load] [PROGDIR:LIBS/bullet.library] [] [Fehlgeschlagen]
    After that i thought, ok go and get the required library.
    I ended up in a linux trap (at least it felt so).
    On aminet there is a Bullet library for Morphos.
    But, this should be build first.
    This is not linux - and I do not know how to do this at all.
    Could someone switch the light on for me?
    thanks a lot!
  • »17.01.14 - 18:44
    defender
    ok I took the bullet.library from my os3.9 cd.
    this seems to take some time:
    [5] [T:HollywoodPlayer] [Open] [PROGDIR:Catalogs/deutsch/Sys/libs.catalog] [Lesen] [Fehlgeschlagen]
    [6] [T:HollywoodPlayer] [Open] [MOSSYS:LOCALE/Catalogs/deutsch/Sys/libs.catalog] [Lesen] [Fehlgeschlagen]
    [7] [T:HollywoodPlayer] [Open] [LOCALE:Catalogs/deutsch/Sys/libs.catalog] [Lesen] [Fehlgeschlagen]
    [8] [T:HollywoodPlayer] [Open] [ENV:guigfx/autoditherthreshold] [Lesen] [Fehlgeschlagen]
    [9] [T:HollywoodPlayer] [Open] [ENVARC:guigfx/autoditherthreshold] [Lesen] [Fehlgeschlagen]
    [10] [T:HollywoodPlayer] [Open] [ENV:guigfx/usescalepixelarray] [Lesen] [Fehlgeschlagen]
    [11] [T:HollywoodPlayer] [Open] [ENVARC:guigfx/usescalepixelarray] [Lesen] [Fehlgeschlagen]
    [12] [T:HollywoodPlayer] [Open] [ENV:guigfx/usewpa8] [Lesen] [Fehlgeschlagen]
    [13] [T:HollywoodPlayer] [Open] [ENVARC:guigfx/usewpa8] [Lesen] [Fehlgeschlagen]
    [14] [T:HollywoodPlayer] [Open] [PROGDIR:Catalogs/deutsch/Sys/libs.catalog] [Lesen] [Fehlgeschlagen]
    [15] [T:HollywoodPlayer] [Open] [MOSSYS:LOCALE/Catalogs/deutsch/Sys/libs.catalog] [Lesen] [Fehlgeschlagen]
    [16] [T:HollywoodPlayer] [Open] [LOCALE:Catalogs/deutsch/Sys/libs.catalog] [Lesen] [Fehlgeschlagen]
    [17] [T:HollywoodPlayer] [ToolType] [SIZEABLE] [] [Fehlgeschlagen]
    [18] [T:HollywoodPlayer] [ToolType] [MODEID] [] [Fehlgeschlagen]
    [19] [T:HollywoodPlayer] [ToolType] [BACKFILL] [] [Fehlgeschlagen]
    [20] [T:HollywoodPlayer] [ToolType] [HIDETITLEBAR] [] [Fehlgeschlagen]
    [21] [T:HollywoodPlayer] [ToolType] [DEPTH] [] [Fehlgeschlagen]
    [22] [T:HollywoodPlayer] [ToolType] [PUBSCREEN] [] [Fehlgeschlagen]
    [23] [T:HollywoodPlayer] [ToolType] [FPSLIMIT] [] [Fehlgeschlagen]
    [24] [T:HollywoodPlayer] [ToolType] [MASTERVOLUME] [] [Fehlgeschlagen]
    [25] [T:HollywoodPlayer] [ToolType] [PRECALCULATION] [] [Fehlgeschlagen]
    [26] [T:HollywoodPlayer] [ToolType] [FIXED] [] [Fehlgeschlagen]
    [27] [T:HollywoodPlayer] [ToolType] [NOSOUND] [] [Fehlgeschlagen]
    [28] [i2s.audio Config Process] [Open] [i2s.audio] [Lesen] [Fehlgeschlagen]
    [29] [« Requester Slave »] [Open] [muidebug] [Lesen] [Fehlgeschlagen]
    [30] [2p2f] [Delete] [T:HollywoodPlayer] [] [Fehlgeschlagen]
  • »17.01.14 - 19:38
    Posts: 12499 from 2003/5/22
    As you probably know by now, http://aminet.net/package/dev/lib/bullet has nothing to do with the AmigaOS font rendering bullet.library. The name alikeness is just coincidence.
  • »17.01.14 - 21:40
    Jambalah
    Posts: 820 from 2008/3/30
    Hi!
    To make this game work you need:
    - bullet.library (and that's done)
    - ptahiplay.library (you find here inside Don Simon game, same authors)
    - Helvetica font (look inside your 3.9 cd)
    When I installed bullet.library game seemed to run but then a request asked for ptahiplay.library. Searched and found it on Aminet inside Don Simon, installed and another request asked for Helvetica font. Installed and game started without problem. It seems to be a little slow when you try to be "furious" after a double select. I'm not sure but it's like a short break occours.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »18.01.14 - 09:48
    defender
    @Andreas
    Yes i found the right one.
    @Yambalah
    Which Version is your ptahiplay.lib ?
    Because the game complains about
    General AHI error
    Check your AHI Installation & settings!
    Mine is 2.0 Form 15.03.2005
    No sound option does work -
    I have re installed AHI from Aminet - that does not change the problem.
    Thank you!
    greets
    [ Editiert durch defender 18.01.2014 - 22:04 ]
  • »18.01.14 - 19:11
