Deluxe Galaga
    Has anyone been able to get this Amiga game to work?
  • »08.01.14 - 13:58
    Jupp3
    Posts: 1193 from 2003/2/24
    No. Should work though.
    If it doesn't, what UAE config are you trying to run it under?
  • »08.01.14 - 14:21
    Right now, none.
    My last G4 lays in pieces, and the G5 I am moving to is about 200 miles from my current location.
  • »08.01.14 - 14:41
    Posts: 12577 from 2003/5/22
    It requires AGA or ECS (depending on the version), so can't work directly on MorphOS.
  • »08.01.14 - 14:57
  • vox
    vox
    Posts: 616 from 2003/11/24
    UAE with JIT :-)
    However, can anyone negotiate Warblade older versions going open source
    or being ported to MorphOS :-)
  • »16.01.14 - 17:59
    > UAE with JIT :-)
    ...I don't consider to be "directly". But yes, boxed approach via UAE should do, of course.
  • »16.01.14 - 18:26
  • HAK
    Posts: 227 from 2003/2/24
    Well, I asked EMW in 2005 about this, but back then he was not interested in releasing the source for Warblade.
    Maybe this has changed.
    Bye HAK
  • »16.01.14 - 21:15
    And Warblade uses a proprietary game engine that is not available for MorphOS.
    It would be neat to have it, but that is not happening.
  • »16.01.14 - 21:16
    analogkid
    Posts: 724 from 2004/11/3
    @vox:
    Deluxe Galaga doesn't need any JIT support, it runs happily with the long-time available E-UAE versions.
  • »17.01.14 - 05:55
  • vox
    vox
    As far as I am checking the progress, it will be abandoned to new
    improved Warblade MkII and might go open, or if we could raise
    money to fund the porting license even being closed port?
  • »17.01.14 - 14:37
