SDL and SDK
    Tcheko
    Posts: 539 from 2003/2/25
    Hello,
    I am playing with SDL but can't link with the SDL static library.
    Anyone have ever tried to compile the given example in the SDL 1.2.6 archive with static lib?
    Regards,
    Tcheko.
  • »10.02.04 - 09:57
    Posts: 1520 from 2003/2/24
    PowerSDL might help. It is a shared SDL library for MorphOS, but not ready yet and subject to change.
  • »10.02.04 - 17:45
    Tcheko
    Hello Itix,
    what do you mean with :
    - not ready yet
    - subject to change ?
    Tcheko.
  • »11.02.04 - 07:39
    I mean it is still changing and getting better. For example I just compiled new and better version (not available yet, tho) with less bugs, thanks to LouiSe. But it is still improving and perhaps there will be a shared SDL library with GL support too ;-)
    Lot of things to do there... But I suggest you at least try my powersdl.library; you don't have to recompile everytime libSDL gets fixed/improved :-)
  • »11.02.04 - 19:43
    Posts: 48 from 2003/5/13
    Hi Tcheko !
    I compiled the example with the Gabriele's library without any problem if I remember well.
    Maybe this could help :
    http://www.guru-meditation.net/main.php3?root=292
    Last, I am waiting for error messages on your thread on MDC. Then I would explain what does not work if I know :)
  • »12.02.04 - 06:20
    Tcheko
    Hello Corto,
    I will post the error I get this week end.
    And I will try Gabriele's lib this we too (and it will certainly solve all my linking trouble...)
    Have a nice day.
    Tcheko.
  • »12.02.04 - 09:29
    Hi Tcheko,
    I certainly will be here this week-end, so I will visit the #amigaimpact channel, if it could help.
  • »12.02.04 - 10:58
    Tcheko
    Corto,
    I expect to spend some time tweaking my peg this week end (at least 4h saturday afternoon).
    I will do a jump to #ai.
    I'd like to use the SDL lib for doing some gfx stuff without bothering about OS (open screen, install an input event handler, do double buffering etc etc... boring.)
    See you on saturday.
    Tcheko
  • »12.02.04 - 12:34
