Display resolution issues with game installations
    WeiXing3D
    Posts: 327 from 2012/6/13
    For reasons I don't understand, games that used to play well and its own small window, in my previous Morphos 3.1 installation, don't play well with MorphOS 3.3.
    I'm referring to games such as Eat The Whistle, Primate Plunge, Pipe Panic, DukeNukem3D, etc., which mornally play windowed, now open in a centered window on a black background scree with vertical white lines in both sides of the game window.
    I've been using Grunch with Pack Chryslais 3.3.1 to isntall these games.
    I have not changed any parameters in MUI or any other place. My installation of MorphOS 3.3 is about a week old. I have only installed a few applications this past week and they play well, in terms of resolution or display settings.
    I also noticed that the following error message opens when I try to run Hex-a-Hop: Cannot load font `Progdir:data//font.ttf'.
    Any suggestions?
    [ Edited by WeiXing3D 05.10.2013 - 21:43 ]
  • »06.10.13 - 01:29
    Posts: 12577 from 2003/5/22
    > installation, don't play well with MorphOS 3.3. I'm referring to games such as Eat The
    > in both sides of the game window. [...] Any suggestions?
    I notice that all these games are using SDL, so the following thread may be of help to you:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9530&forum=3
    That thread talks about a G5-specific SDL issue though, so it may or may not apply to what you experience on your G4 machine.
  • »06.10.13 - 08:19
    bash64
    Posts: 977 from 2010/10/28
    What kind of machine do you have?
  • »06.10.13 - 08:35
    Quoting from his signature:
    "Mac Mini G4 1.5GHz"
  • »06.10.13 - 09:00
    WeiXing3D
    Thank you afll for your help.
    These are the answers to your new questions:
    1. My computer is a Mac Mini G4 1.5 GHz (or 1.67. I'm not sure anymore since my computer was stored for 1 year).
    2. Interestingly enough, a look in Prefs: SDL revealed that Promote SDL Screens was unchecked in my case. Turning it on (checked) makes the game to work in their windowed version again. I'm confused by this, but hey it works.
    3. The most pressing point now is tha Hex-a-Hop still doesn't work; this is my missy's favorite game. I still get the error "Cannot load font `Progdir:data//font.ttf'."
    I will appreciate your help in solving sticky point 3 above.
  • »06.10.13 - 17:44
    WeiXing3D
    Clarification: Uninstalling and re-installing Hex-a-Hop doesn't clear the error, in fact it just remains the same.
    Any help?
  • »07.10.13 - 14:59
    Same problem here (PowerSDL v16.0). Not sure, but seems to be some SDL path handling issue.
  • »07.10.13 - 17:33
    WeiXing3D
    I hope someone could come up with a solution to calm my wife down :-)
  • »07.10.13 - 17:58
    BSzili
    Posts: 570 from 2012/6/8
    The path above looks bad to me, because it has two '/' in it, which means it actually tries to load the font from "PROGDIR:font.tff". You can try to copy it there, and see if the game runs.
  • »08.10.13 - 12:35
    defender
    Posts: 249 from 2011/4/24
    The Hex a Hop problem is easy to solve. Just cop the font.ttf to the Progdir:
    As the consol sayed it is searching in the parent directory of Progdir:data/
    Short: open Hex a Hop / Data. Copy font.ttf to Hex a Hop.
    For me, it works. :-)
  • »08.10.13 - 13:49
    defender
    Hoops sorry Bszili sayed that allready ;-)
  • »08.10.13 - 13:51
    Posts: 1521 from 2003/2/24
    That sounds like an error in path handling... I have to check powersdl_ttf.library and main lib =P
  • »08.10.13 - 17:29
    igracki
    Posts: 471 from 2003/2/24
    A quick fix for this is, to copy "font.tff" to the directory where hex-a-hop is.
    ok, others were faster;)
    [ Edited by igracki 08.10.2013 - 21:49 ]
  • »08.10.13 - 17:47
    WeiXing3D
    Guys, thank you for your responses and please forgive me for my ignorance, the result of being away from my computer for over a year, but are you saying:
    - Copy the _ttf folder in System: Fonts in Hex-a-Hop System:Games/Hex-a-Hop/Data?
    Please clarify using instructions fit for a "user back in training-wheels mode" :-}
    Thanks.
    [ Edited by WeiXing3D 08.10.2013 - 17:38 ]
  • »08.10.13 - 22:30
    Condor
    Posts: 101 from 2005/9/1
    No. Copy or move font.ttf from System:Games/Hex-a-Hop/Data into System:Games/Hex-a-Hop.
  • »09.10.13 - 05:38
    defender
    I think it would be best to copy the file ,just in case the SDL fault will be fixed.
    Copy font.ttf from System:Games/Hex-a-Hop/Data into System:Games/Hex-a-Hop.
  • »09.10.13 - 13:12
    WeiXing3D
    This fixed it, but has anyone noticed that the full screen toggle is not working? It just generates a black screen with random color lines.
  • »09.10.13 - 17:07
    This works here, on the same hardware as you have.
  • »09.10.13 - 17:47
    WeiXing3D
    May I ask what are your SDL preference settings?
  • »09.10.13 - 17:58
    They are as follows (some items are translated by me from German so might not match exactly):
    Startup options
    [V] Center window
    [V] Low CPU priority
    Window
    [V] Iconify button
    [V] Jump button
    Display options
    - Ambient
    - Default
    [_] Promote SDL screens
    Further options
    [_] Debug on
    Jump button
    (*) Jump to new screen
    (_) Send Alt+Enter
    Edit: corrected typos
    [ Edited by Andreas_Wolf 09.10.2013 - 23:37 ]
  • »09.10.13 - 18:12
    WeiXing3D
    They are as follows (some items are translated by my from German so might not match exactly):
    Startup options
    [V] Center window
    Window
    [V] Iconify button
    [V] Jump button
    Display options
    - Ambient
    - Default
    Further options
    [_] Debug on
    Jump button
    (*) Send Alt+Enter
    Thank you Andreas.
    I am perplexed though. The other day I unchecked [_] Promote SDL screens because other games (see above) were not opening right. Today, and following your settings, I unchecked that option again and Hex-a-Hop plays in full screen and the rest of other games (boulder dash, road warrior, eat the whistle) are playing normally too in their respective windowed versions.
    Here I'm scratching my head....uhmmm.
  • »09.10.13 - 18:59
