Posts: 1619 from 2012/11/9
First of all, thanks for your quick reply,
Quote:ASiegel wrote:
First of all, if you are concerned about security, you should not be running Windows XP anymore. Period
Windows XP is a good, and probably the best, Windows OS to-date, though I much prefer MorphOS, but there are many things that I, and probably you too, cannot do in MorphOS, as yet, that you need or want to do, so have to use some alternative OS, and Windows XP is one of those OS's I use that fills that gap.
I wish that was not the case, but some tasks I just cannot do with MorphOS, due to the lack of available software for it, more's the pity.
Additionally, Windows does have, and needs, readily available virus protection software/applications, which MorphOS does not have, though which it could probably do with, for everyone's safety/security.
Seeing as Windows XP was handling the majority of the world's business and other ystems for a good few years I don't think it's fair pointing the finger of security concern at it, at this stage. Additionally, as it is still currently supported by Microsoft any security leaks are still being fixed as they arise.
Quote:Secondly, users of anti virus programs may encounter "false positives" every now and then. Prototype.js is a fairly well known open source javascript framework and the version used here can also be found at:
prototypejs.org I agree, and that is what I considered it would most likely be, but thought it best to mention it, to bring it to the attention of those that might need to know - just a concern, as the title read.
AVG (virus protection software) sometimes errs on the side of caution, but I believe it is better to be made aware of a problem, than to have to fix a system failure, or viral proliferation, don't you agree?
The Prototype version was upgraded from 1.5.x to 1.7.x now. Perhaps this will solve your problems with AVG...
That's very quick action, and more than I expected, so ... many thanks for that.
