Flow Development Studio - File Search
  • MDW
    MDW
    Posts: 453 from 2003/7/26
    I noticed something strange in Flow Development Studio.
    If I use function "File Search" (RCmd+u) and try to search string "round(", I don't have any results. Path is properly set to sources directory. I have in several files something like this:
    round(something)
    so I should get several results.
    In LogTool I see almost one hunderd logs:
    1846.643| &D?Xp: Error in search pattern: Missing ')'
    If I search "round" with selected option "Whole Word" I have correct results, so this is not a big problem.
    Could someone tell me if the behaviour is a bug or a feature? :) Maybe I can't use '(' and ')' in search string because these characters are reserved for an advanced search query.
  • »24.04.24 - 14:35
    Posts: 2984 from 2003/3/5
    The search uses regular expressions. round\( should work.
  • »24.04.24 - 15:36
  • MDW
    MDW
    It works perfect.
    So this is feature, not a bug. :) The search is more advanced than I expected. Great! :)
    Thank you.
  • »25.04.24 - 18:15
