Iris - An upcoming E-Mail client blog
    Cego
    Posts: 712 from 2006/5/28
    hey jacadcaps,
    first of all thanks for the release. i had a quick look at it and i had my mail account running 20 seconds after i copied it over to my harddisk. fantastic work!
    i have a question though. How can i activate the icon toolbar? there are icons stored in the icon drawer. i assume they are supposed to act as toolbar buttons, right?
    [ Edited by Cego 29.03.2018 - 22:21 ]
  • »29.03.18 - 22:21
    Posts: 2995 from 2003/3/5
    There is no toolbar in the main window. The images you’ve seen are used by the New Email window.
  • »29.03.18 - 23:10
    Debaser
    Posts: 161 from 2005/7/12
    So far working well with my gmail account. Enjoying the ability to work with emails well with Morphos. Well done jacadcaps! Thank you Thank you :)
    Looking forward to seeing this application progress.
  • »30.03.18 - 03:21
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    @jacadcaps:
    I find a problem with iris. Iris can't get the settings from the mailserver. It was hostet on "Deutsche Glasfaser AG".
    This problem exists on any other clients, whitch try to get the settings automaticly.
    The problem: The server needs this hostname: mail.dg-email.de not imap.dg-email.de
    I can't set this my selfe.
    2. The login: Iris presume as login "carstensiegner", but i use a different login. The same in the login from smtp.dg-email.de
    After some trys, iris can't conect to the mailserver : (
    [ Edited by pegasos-sigi2 30.03.2018 - 11:46 ]
  • »30.03.18 - 10:38
    Well, that’s the fault of the admins of the said server. Once autoconfiguration fails you can adjust all the settings by hand and try again. Let me know if anything is unclear in the settings - there is a switch to show more options there that you probably need to use.
    Worst case scenario - make an email accout for me on that server and I’ll have a look. This is generally advised for everybody having problems at this point.
    [ Edited by jacadcaps 30.03.2018 - 09:11 ]
  • »30.03.18 - 14:10
    defender
    Posts: 248 from 2011/4/24
    Thank you for the Beta of IRIS.
    Freenet: imap receiving Works fine :-)
    Freenet: imap Sending - doesn't work
    Googlemail: imap receiving - Works fine :-)
    Googlemail: sending ... doesn't work
    deleting mails works fine :-)
    [ Editiert durch defender 31.03.2018 - 00:47 ]
  • »30.03.18 - 23:43
    For freenet: I guess you just need to tweak the settings.
    Google sounds interesting... what email address did you use?
    Btw. you can run Iris with a TRACE arguent when starting from shell. This effectively dumps most of the network traffic to the system log.
  • »31.03.18 - 00:17
    defender
    My fault in both mail accounts:
    for gmail sending: Authentication should be default not OAuth2 (I missunderstood the readme in that case)
    and I had to enable Iris as a 3rd party app in google mail
    for freenet sending: the account name must be the same as the email adress?! (however, it works now!)
    again, thanks for Iris
  • »31.03.18 - 21:23
    It should be OAuth, actually. You still didn’t tell me what email address you’ve used - was it from some domain different than gmail.com?
  • »31.03.18 - 21:37
  • ASiegel
    Posts: 1370 from 2003/2/15
    @ jacaDcaps
    In Germany, Google gave out googlemail.com addresses for many years due to a trademark dispute regarding "Gmail".
  • »31.03.18 - 21:49
    defender
    I tried my freenet account for sending a mail to gmail
    and the gmail account for sending a mail to freenet.
    @ASiegel
    I didn't know that this was a german exclusive change, thank you for clearing.
    [ Editiert durch defender 31.03.2018 - 23:04 ]
  • »31.03.18 - 21:52
    Intuition
    Posts: 1110 from 2013/5/24
    ASiegel wrote:
    @ jacaDcaps
    Was same in UK too. Was it an EU-wide thing?
  • »01.04.18 - 01:32
  • ASiegel
    Intuition wrote:
    ASiegel wrote:
    @ jacaDcaps
    "GoogleMail" has been used due to trademark issues in Germany, Poland, Russia, and the UK.
  • »01.04.18 - 07:39
    NewSense
    Posts: 1478 from 2012/11/10
    I've tried it on MorphOS v3.9, where it is supposed to work, but it won't start/display any window/GUI - anyone else have similar observations with MorphOS v3.9? :-(
    [ Edited by NewSense 03.04.2018 - 06:31 ]
  • »03.04.18 - 06:30
  • ASiegel
    It is absolutely not supposed to work on v3.9. Iris requires several key new features of v3.10 to run.
    The developer has clearly mentioned in this very discussion thread that he had to wait for 3.10 to be released before he could finally publish a beta version.
  • »03.04.18 - 07:53
    Boingmax
    Posts: 13 from 2014/10/3
    Works great so far ... thanks !
    Missing:
    Toolbar
    Pinting / Save as PDF
    Copy & Paste - in Yam and Simple Mail Copy & Paste is SHIT!!!
    http://boingsworld.de Podcast "roundabout" Amiga
  • »03.04.18 - 13:40
    The README.txt clearly states that 3.9 is unsupported.
  • »03.04.18 - 15:04
    Thanks!
    Missing:
    Toolbar
    Toolbar - maybe if Jobbo delivers an icon set like the one in Flow Studio :) I actually like the minimalist interface with no buttons.
    Printing - to be done.
    Copy & Paste - it's supported. rcommand + c/v should work just fine in email reader/writer.
  • »03.04.18 - 15:06
    beworld
    Posts: 592 from 2010/2/10
    My little test :
    - Missing Context menu (to Reply, transfert, delete ?!) or indeed toolbar
    - When Iris is checking IMAP server, it's impossible to read a email (multi task)
    IMac G5 2.1,PowerBook G4 1.5,MacMini 1.5, PowerMac G5 2.7 died !!!
    My MOS ports
  • »03.04.18 - 16:24
    All the options are available in the main menu, w/ hotkeys.
    Yeah, that will be mitigated in the next beta. Local storage will also solve that problem.
  • »03.04.18 - 17:26
    beworld
    cool :-) thanks
    My MOS ports
  • »03.04.18 - 17:39
    The next beta (23) is currently being tested. If all goes well I'll make it public in a couple of days...
    Changes:
    - Reworked job priority queue to avoid situations where one has to wait for email contents for too long
    - Folder full sync jobs can now be done in steps (unlocks email reading while syncing)
    - Fixed email counts in the folder tree for IMAP
    - Reworked autoconfiguration for OAuth2 providers
    - Cut text (cmd+x) shortcut added to the email writer
    - Revamped transport security settings - now a switch between TLS, STARTTLS and opportunistic STARTTLS
    - When replying or forwarding mail, an appropriate flag on the source email is set
    - Fixed: quick folder synchornization would call Close on a fh twice if ChangeMode() failed
    - Fixed: Removing an account did not kill the entry from the settings list
    - Fixed: After an account was removed but not removed from the list, collecting properties for the non-existing account threw exceptions
    - Fixed: there was a rather nasty race condition in the main Session class
    - Fixed: after adding a message to a folder and synchronizing the folder, each time it was synchronized, the message would duplicate in the index
    I've added support for Yahoo OAuth2, but that is still pending until Oath enables access for Iris.
    [ Edited by jacadcaps 16.04.2018 - 11:18 ]
  • »16.04.18 - 16:17
    zbysiuk
    Posts: 51 from 2006/8/4
    Thank you very much :)
  • »19.04.18 - 05:25
    tolkien
    Posts: 502 from 2013/5/29
    Thanks! I'm enjoying Iris in its current state. Ill try it tonight. Great!!
  • »19.04.18 - 05:59
