MOSNet
    Posts: 408 from 2004/7/15
    killlbilll wrote:
    (SSHCon: 1:one must press enter three times before you get the login. 2:one cannot force a disconnect (ie close the window while ssh is running)).
    Looks like you have old usergroup.library somewhere in your system. Upgrade to recent one (4.6). It's its bug.
    iPod, iBook, iMac,... iRobot?
  • »03.03.06 - 10:40
    Posts: 1068 from 2003/3/24
    Is it possible to use GelbesPanel with MOSNet?
  • »03.03.06 - 11:11
    Miky060
    Posts: 694 from 2003/2/24
    Yes, many of us use it.
    It is also explained in MOSNet README, read it. Remember to add/remove gebelspanel components adding lines in MOSNet generl.config file! ;)
  • »03.03.06 - 12:27
    Thanks for your advise to RTFM :-D now gelbespanel works :-)
  • »03.03.06 - 16:33
    VooDoo
    Posts: 189 from 2005/8/24
    yupi yeee.. :) I`am again..but now i connect my Amiga whit MosNet
    1.0..
    and work great..I config and strat mosNet in 2 min..
    again tnx for this great app!
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1 :-D
    Warp croatian Amiga portal :
  • »03.03.06 - 17:38
    killlbilll
    Posts: 95 from 2004/5/19
    Sonic: I totally overlooked the usergroup.library, thanks for letting me know! Everything seems sweet now =)
    [ pegasos ii / g4 | morphos1.4.4 ]
  • »03.03.06 - 18:30
    Hey Pavel what is the status of that MacOS Bootloader?
    And if i donate a SATA Controller would you make a SATA Driver for MOS?
    When i use gelbespanel with MOSNet i get after some minutes many litle yellow dots on the screen, it starts first on one screen and then i get it on all opened screens.
    [ Edited by ThePlayer on 2006/3/4 2:43 ]
  • »03.03.06 - 18:38
    Posts: 1914 from 2003/10/19
    So far the latest 1.0 release seems to work fine for me. One odd thing though is when I enter a web addres the first time there is a pause of about 3 seconds before it goes to the site. Any one else have this issue or know what caused it? I am using the internal ethernet on the Pegasos and have the IP set to DHCP. MiamiDX does not do this.
  • »04.03.06 - 16:50
    Gelb
    Posts: 148 from 2003/3/4
    Here too, except you can't DCC anything anymore using AMIRC. Everything looks normal, but DCC never starts and you notice something is wrong when the traffic in the channel is 0 even after the normal idle time of several days of everyone.
  • »04.03.06 - 20:11
    poundsmack
    Posts: 1346 from 2003/6/8
    wow thanks a ton sonic! hey by the way any of you guys want to show some puport on OSnews for this? i was one of 4 and they tanked my raiting down. so go post on os news and show your suport to show MorphOS still has a following. andplease for god sakes voke me back into positive numbers while u are there http://osnews.com/comment.php?news_id=13862&threshold=-5
    :lol:
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »05.03.06 - 01:02
    Framiga
    Posts: 363 from 2003/7/11
    Thank you very much, Sonic! :-)
    It works very well with MOS-PuP and x-surf NIC.
    Time to tweak with settings to optimize speed! (already ok anyway)
    A question: i've noticed that the TCP/IP stack is seen by the system as Miami (Scout) . . is this correct?
    Thanks again.
    EDIT- is this due miami.library? and miami.library is used by MiamiPanel only?
    [ Edited by Framiga on 2006/3/14 13:40 ]
  • »14.03.06 - 12:38
    Yes, it is. This is because of miami.library.
    No. It is used also by syslog viewer and DHCP client.
  • »20.03.06 - 09:08
    Framiga
    OK Sonic, thanks :-)
  • »20.03.06 - 09:59
    Posts: 888 from 2004/1/24
    @Sonic
    OpenTTD doesn't seem to work with MOSNet. According to Tokai, the problem lies with MOSNet. Any ideas?
  • »20.03.06 - 10:11
    Stevo wrote:
    @Sonic
    Can i reproduce the problem being not on the network?
  • »21.03.06 - 06:29
    amiades
    Posts: 231 from 2005/6/2
    After configuring it, everything seems to go well in my LAN, but I can't have access to anaything outside it. It's even more extrange, that I can't even ping to 192.168.0.1 (IP where I have my router). I can ping and even browse and whatever to anything else in my LAN.
    Do I have to make anything special to tell MOSNet my router is in 192.168.0.1? I have modified the static-routes file... anything else? ;)
  • »21.03.06 - 15:39
    Hmmm... Everything should go well. In fact you should be able to ping 192.168.0.1 even without it since it's inside your subnet.
    What is your interface definition (IP/netmask)?
  • »22.03.06 - 06:50
    amiades
    The IP of my peg is 192.168.0.7, and the submask is set to 255.255.255.0 (and when I do a ifconfig, I can see that netmask 0xffffff00 which is correct).
    I'm sure it must be any kind of mistake made by me, but I can't find what it is...
    With the same parameters, Miami works correctly.
  • »22.03.06 - 11:54
    I'm still not happy with the way the config files are done or at least documented in MOSNet. Its not that clear for a lot of people what needs to be edited and what does not. The docs need a bit more work still. The stack itself is fantastic though.
    I still have troubles using DHCP and web sites taking a few seconds to start loading. Its like its looking for the address and then finds it shortly after. Something that doesnt happen with Miami using all the settings I could figure out and move over to MOSNet.
  • »22.03.06 - 15:03
    merko
    Posts: 328 from 2003/5/19
    I also have the problem with a few seconds delay when looking up a
    DNS.
    Another problem I have happens when using BT with a popular torrent,
    maybe it's related to having too many connections (just a bad guess
    probably). I get the following errors (on "debug" level):
    Level Process Event
    error kernel m_clalloc:max amount of memory already used (1045312 bytes).
    error kernel sana_read (eth): not enough mbufs
    These two are repeated about 20 times each, then the network
    connection simply stops working. If I go offline/online in the panel
    it mostly starts working, sometimes not. Is there any way to increase
    this "max amount of memory"? :)
  • »23.03.06 - 03:26
    Jupp3
    Posts: 1193 from 2003/2/24
    I remember those errors on Genesis too. Happens, when there's too much traffic. Setting memory buffers to max (but not over the max!) helps, but only a bit.
    Don't know if / how that can be done with mosnet, I don't use it.
  • »23.03.06 - 07:37
    Framiga
    @merko
    are you using the latest MosNET 1.0?
    Which values of TCP_Sendspace and recv?
    @Acill
    try in general.config:
    USENS=NO
    (or USENS=FIRST) and check to have the right domain and nameserver in resolv.conf (i'm not using DHCP here)
    @Sonic
    what do you mean by "local database"? (in the README "USENS" option)
    [ Edited by Framiga on 2006/3/23 11:21 ]
  • »23.03.06 - 09:57
    merko
    Yes, MosNet 1.0. Cant't find anything about TCP_Sendspace in any doc
    or config file so I can't answer that.
  • »23.03.06 - 13:23
    About delays in DNS lookups: check your default domain name in resolv.conf. Or if you don't have one or don't know what is it and how to set it up, jusr remove it.
    The problem in fact is: when you try to resolve a name MOSNet first tries to append a default domain to it. This results in something like morph.zone.my.local.domain. If my.local.domain is not actually configured in your local network it takes time for the DNS to find out that it doesn't exist.
  • »24.03.06 - 07:45
    Framiga wrote:
    @Sonic
    hosts, networks, etc local files.
  • »24.03.06 - 07:47
