Posts: 2720 from 2003/2/24
Not been having any issues myself to speak of, only a few observations and suggestions:
1. In the info about the Mac Mini network driver, there is a copyright notice that "ends" on 2009 (I think) and just some lines under it, the latest version is listed to be from 2012. Maybe there are such inconsistencies on other version/copyright info's as well? Maybe you should go through them all and make a quick check? Totally unimportant in practice, but inconsistencies never *look* good IMHO.
2. In the preferences you can specify "Open URL" for WWW, E-mail and FTP. Now when there is an FTP client built-in, I think this should be put there as standard instead of an empty and dactivated box?
3. The menu/contextmenu behavior using the right mouse button has two "modes". Hold the button, and the menu will close when you release it. A quick click on the button will make it stay open until the user makes a selection or clicks outside the menu. But this "click-time" is a bit too short for my liking, and there seems to be nowhere to adjust it? Would it be possible to add to mouse preferences, where left button click time is set, also a "right button hold time" to adjust this? Or is it there but I missed it?
And thanks for a great MorphOS release!
MorphOS is Amiga
done right! MorphOS NG will be AROS
done right!
