Posts: 2794 from 2006/3/21
So, from those test results, it would appear that for many every day actual tasks the 1.42GHz MDD is actually faster than the 1.8GHz 7447A Sonnet accelerated Quicksilver, or Digital Audio PowerMacs.
I don't know what everyone has been paying for their Sonnet upgrade accelerators, but the prices I have seen have been higher than the prices I have seen for complete 1.42GHz MDD PowerMacs, so at least where I live, the better "bang for the buck" would be to buy a 1.42GHz MDD PowerMac.
For bragging rights, having a 1.8GHz PowerMac sounds better than any actual speed advantage, over having a 1.42GHz PowerMac, unless the 1.8GHz accelerator happens to have a 7448 G4, instead of a 7447A G4 CPU. (are 7448 G4 accelerators available for any model of G4 PowerMac? Which manufacturers use the 7448 G4 @ 1.8GHz in their accelerator cards? Which G4 cpu model is available @ 2.0GHz and is it compatible with MorphOS2.x?)
For me, I think it would be better to stick with what I have, unless I can swap my dual 1.25GHz G4 cpu module (in my non-FW800 MDD) with a dual 1.42GHz G4 cpu module without losing my ability to run MacOS9.2.2, which I need to run the version of Media Composer that works with my Avid Meridien PCI cards and break-out boxes.
A dual 1.42GHz G4 module over-clocked to 1.5GHz, or maybe 1.67GHz to match the buss speed, would likely be the fastest G4 PowerMac for me. But I don't know how, or if it is even possible to use the later dual 1.42GHz G4 cpu modules on the earlier, non-FW800, dual 1.25GHz G4 motherboards, even though they look the same physically.
Thanks for the www.barefeats.com comparisons Andreas.
[ Edited by amigadave on 2010/12/27 9:01 ]
