New SAM460EX
    Posts: 1516 from 2003/2/24
    1280x1024 is not okay for my 24" TFT which does 1920x1200 ;-) Lack of 3D support also suggest it lacks lot of 2D acceleration... for embedded use it wont matter of course.
  • »05.04.10 - 11:39
    Posts: 12079 from 2003/5/22
    > +1 for ATi embedded cpu
    ATI/AMD do Power Architecture CPUs? ;-)
  • »05.04.10 - 11:56
    jcmarcos
    Posts: 1178 from 2003/3/13
    Yes, but I've red that link that Andreas provided, about the graphics and audio subsystem, and it can still do some clever tricks. I feared it was worse.
  • »05.04.10 - 13:58
    1280x1024 is fine by me. I like to be able to read text without eye strain.
    And the 502 can be supplanted by a Radeon PCI video card (PCIe cards aren't supported yet).
    And Andreas is right, they do appear to have Amiga OS 4.1 video drivers written for the 502. While the reference he posted mentions that the display was generated by a SAM440, it apparently was equipped with a PCI 502 video card.
    So the board is likely to support Amiga OS and it does feature a faster processor (than Acube's earlier products).
    It's still a little underwhelming (and overpriced), but its an improvement (over the SAM440).
    [ Edited by Jim on 2010/4/5 17:54 ]
  • »05.04.10 - 16:54
    In the A-Eon Q&A #3 on amigaworld.net 3 days ago the X1000 is said to come with an R700 family gfx card. That means that OS4 must support that card when the X1000 comes out. As the Sam460ex is supposed to be released after the X1000 an R700 family PCIe gfx card might be supported by the time the Sam460ex comes out.
  • »05.04.10 - 21:41
    kolla
    Posts: 105 from 2003/4/22
    Krashan wrote:
    (+ it has no serious SSH client).
    Same for MorphOS.
    [ Edited by kolla on 2010/4/5 23:43 ]
    -- kolla
  • »05.04.10 - 21:42
    pampers
    Posts: 1061 from 2009/2/26
    That's weird. I'm using remoteshell and I cannot see any difference for myself between putty on pc and remoteshell on morphos.
    MorphOS 3.x
  • »05.04.10 - 21:57
    Production of the R700 family is winding down. Many models of the HD4XXX series are hard to find. It would be nice to have a more up to date GPU on a PPC based system, but how are you going to get the documentation to write the drivers? ATI has never completely documented their GPUs.
  • »06.04.10 - 03:27
    kolla
    That's because you're not being serious. ;-)
    [ Edited by kolla on 2010/4/6 7:31 ]
    -- kolla
  • »06.04.10 - 05:30
    Krashan
    Posts: 1107 from 2003/6/11
    @kolla
    Same for MorphOS.
    SSHCon fits my needs. AmigaOS 4 has nothing comparable.
  • »06.04.10 - 06:24
    kolla
    Well, it was you who wrote "serious", how was one to know that all you meant was "fits your needs"? :)
    -- kolla
  • »06.04.10 - 06:43
    jcmarcos
    Sure, it's a shame. Just like new models being completely incompatible with previous ones. I guess GPUs suffer dramatic changes through different generations.
    It would be great if a couple of tweaks in an old driver were enough to drive a new model, even if it doesn't use at all any new features.
    Just because old models will be completely unavalaible some day... Going back to the scrapyard age that many amigans had to suffer for years is too hard to take at this age.
  • »06.04.10 - 08:47
    > are hard to find.
    R700/HD4xxx is just one generation behind the most recent ATI/AMD GPU family. Where I live all HD4xxx series cards are still everywhere to buy.
    That would only be R800/Evergreen/HD5xxx series.
    I don't know how Hyperion are planning to accomplish this. Work on supporting R700/HD4xxx series cards in OS4 is going on by 3rd party devs (RV710/HD4350):
    http://hdrlab.org.nz/radeonhd-chip-radeon-hd-4350-pci-vga-output-is-working/
    http://hdrlab.org.nz/radeonhd-driver-hardware-compatibility/
  • »06.04.10 - 15:55
    Posts: 2976 from 2003/3/5
    @kolla:
    Any features you'd like to see in SSHCon ?
  • »06.04.10 - 16:47
    In this US, higher end 48XX cards are disappearing. Many lower end R700 cards are still common. Frankly, I think the R700 is a better thought out design than the R800. Nice small die.
    The 4350 doesn't really cut it for me. At bare minimum I'd want to see a 4650 or 4670 (and a 4770 would be better still).
  • »06.04.10 - 19:08
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 25.04.2011 - 07:21 ]
    Pegasos2 G3, 512 megs RAM
  • »06.04.10 - 20:17
    magnetic
    Posts: 2129 from 2003/3/1
    Dreamcast
    Ummm actually Nvidia is much better supported in Linux than ATI atm.... there are even open source kernel drivers for Nvidia boards in Ubuntu 10
  • »06.04.10 - 23:57
    I didn't know that Nvidia provided enough information to build a decent driver. How does its performance compare to their proprietary drivers?
    I'd like to add a note about my negative comments on the Silicon Motion SM502. I've looked over Silicon Motions offerings and contacted their tech support. Considering that the company provides relatively complete documentation for their products, perhaps the choosing them isn't such a bad idea for alternative operating systems.
    After reading about the struggle to get ATI's 4350 to provide just VGA output (with no 2D or 3D acceleration) under AOS 4.1, I can see the advantage of picking a company that is more forthcoming on the technical specifics of there products (even if their potential performance might be lower).
    Being able to easily write a fully functional driver beats "potential performance" any day.
  • »07.04.10 - 17:03
    BTW - Did anyone else look at the posting Andreas mentioned? They're hoping to get hardware acceleration on the R600 series working soon (under AOS 4.1).
    That would give them the 2900 and possibly the 38XX cards.
    AOS is clearly inferior to MorphOS, but their video card support is getting pretty impressive.
    With Acube and A-EON providing new PPC hardware for AOS, its not hard to feel jealous.
    [ Edited by Jim on 2010/4/7 21:06 ]
    [ Edited by Jim on 2010/4/8 0:29 ]
  • »07.04.10 - 20:06
    Velcro_SP
  • »07.04.10 - 21:15
    kolla
    jacadcaps wrote:
    @kolla:
    Sure, plenty.
    * merge the server "bookmarks" with /progdir/conf/config (or whatever it is), gui for all the options (X11, port forwarding, compression, keepalive etc)
    * creation and management of user keys through the gui
    * management of known_hosts via the gui
    * unicode input methods, and improved unicode support in general - I have yet to see it work properly
    * ssh-agent - allow user to open keys and have promptfree logons without storing any passwords in config files (probably impossible to implement on amiga systems)
    * hook scp and sftp into ambient, browsing and filemanagement of remote filesystems
    SSHCon is not an ssh client thought, it is just a wrapper around openssh, openssh is ok for "serious" stuff, but a lot of it doesnt make sense on amiga systems. Tunnelling should be possible though, I suppose, nice for those that need something akin to VPN.
    -- kolla
  • »07.04.10 - 22:20
    > Any previously-owned Mac mini PPC will [...] run twice as well.
    In case "well" also includes "fast":
    I think it's a save bet to say that the X1000 will run faster than Mac mini PPC.
    > And not be a pain in the butt with system building and set-up
    According to A-Eon, the X1000 will only be sold as complete system, i.e. full setup including OS4 pre-installed.
  • »07.04.10 - 23:12
    I'm not worried about the X1000 processing capability. It's the PCIe video slot and the support for newer video cards (then we have) that bothers me.
    I'm sure if I bought a 2.0 GHz 7448 processor for my Powermac, it wouid esily outperform the X1000 (at a lot lower cost).
    I'm just hoping we can keep up with AOS in terms of video support.
    Oh, BTW, I have an XMOS based development board and I see no advantage to the implementation they're making with the X1000 (Xena). XMOS processor are better suited to creating devices that, in the past, would have required specialized chips. I'm currently working on a improved intelligent UART and PIA design to update an older controller board I have. I don't understand A-EON's intent (with their XENA design).
    [ Edited by Jim on 2010/4/8 0:39 ]
  • »07.04.10 - 23:38
    > I'm not worried about the X1000 processing capability. [...] I'm sure if I bought a 2.0 GHz
    MPC7448 @ 2.0 GHz (overclocked) vs. one core of PA6T-1682M @ 2.0 GHz would be an interesting comparison. It might not come out as clearly as you think, maybe even the opposite way :-)
    > [...] I don't understand A-EON's intent (with their XENA design).
    Here I'm completely with you. XCore/Xena on Nemo makes no sense to me. Their intention might be to offer something they can pretend to be resembling the old Amiga custom chips in philosophy (see Hyperion stating that Xena, "in true Amiga tradition, provides the AmigaOne X1000 with a custom chipset"), which I consider misleading.
  • »07.04.10 - 23:56
    @ kolla
    As for merging and extra options, it can certainly be done. Also the creation of user keys. known_hosts management would require changes in the OpenSSH itself, which I'd pretty much would like to avoid. As for Unicode input - there are places to ask for help if you cannot get it to work yourself (mzone, mailing lists).
    I don't see how ssh-agent would be impossible, it just wouldn't be as safe as on *nix. That doesn't really belong to the SSHCon project though. Same goes for scp/sftp - this is totally unrelated to SSHCon itself. And finally, same goes for tunneling / VPN.
  • »08.04.10 - 09:33
