Saku 2017 MorphOS 3.10 preview
    koszer wrote:
    Jim wrote:
    Without anyone ever really addressing the elephant in the room, why are we not going to support the final, best PPC Mac?
    Because:
    1. The standard configuration contains incompatible gfx card, and we don't like flashing;
    2. Some additional drivers are required, mainly Ethernet;
    3. Some additional coding/hacking/reverse engineering the hardware is required, e.g. fan control, CPU voltage etc;
    4. Who needs another PPC anyway? x64 support is nigh!
    5. Did I say we don't like flashed gfx cards?
    (above points - well, except for the number 4 - are a summary of my correspondence with some of the MorphOS team members)
    Paying attention recently?
    We haven't had to use flashed graphic cards since the R500 drivers were introduced.
    All cards from the R500 up will rely on AtomBIOS calls, so flashed cards are not going to be required.
    Therefore, we would have a way of running cards BETTER than those Apple supported, in PowerMac G5 PCI-E models.
    Fan control and networking don't seem like a massive amount of work compared to the incredible amount of work Mark had to do for the original G5 port, or the work he has been doing over the last year or so enhancing the Radeon driver.
    IS X64 support close at hand?
    And if it is, why are we worried about the X5000?
    We have NO idea IF the X64 jump will be made OR when, but we DO currently support PPCs, and you haven't really addressed the question.
    Why not the best PowerMac PPC?
    @marmotta:
    Sorry, I should have read your post.
    Yes, you can use two video cards, and if you aren't interested in running the open firmware card under MorphOS you can make it something cheap like an Nvidia 6600.
    Tie that to the VGA input of your monitor and the Radeon HD card to the DVI input of your monitor, and you'll never miss not having Apple firmware on the Radeon card.
    [ Edited by Jim 10.10.2017 - 16:10 ]
  • »10.10.17 - 20:42
    Posts: 12080 from 2003/5/22
    > For not to go into competition with the X5000?
    I don't think the MorphOS team cares if a keyfile is issued for a license bought for an X5000 or for a license bought for a PPC Mac.
  • »10.10.17 - 21:10
    Posts: 2053 from 2003/6/4
    Two more weeks? ;-)
  • »10.10.17 - 21:22
    marmotta
    Posts: 32 from 2012/6/11
    I don't think for the keyfiles, but for diplomacy... (rightly) "amiga like" realities try to help each other. But it's just my thought
  • »10.10.17 - 21:22
    Posts: 1246 from 2004/2/8
    @Jim, @marmota:
    Hey, don't shoot the messenger. What I wrote was what I read in e-mails from the devs. That, plus "We already support too much hardware anyway". I wrote back that we could use dual gfx cards and so on, but I didn't get any reply, so I guess my list remains valid.
  • »10.10.17 - 21:51
    In reality, only a vanishingly small fraction of those who would buy a used PowerMac11,2 for 200 EUR or less to run MorphOS would instead buy an X5000 for ten times as much if MorphOS isn't available for the former. Just my thought, of course :-)
  • »10.10.17 - 21:55
    marmotta
    Yes, but the problem is the possible comparison.... This can demonstrate the superiority of the G5 on the x5000 and this resulting bad advertising for the new machine ;-)
  • »10.10.17 - 22:10
    This can also be done with the already supported PowerMac7,3. I'm not sure many people will pay tenfold just to have PCIe instead of AGP.
  • »10.10.17 - 22:21
    zukow
    Posts: 642 from 2005/2/9
    PCIe cards give big speedup of graphic handling. For example, scrolling in OWB is much more smoother. I got two times fps in Q3 than using R9600. Overlay works a bit better so more 1080p h264 can be viewed. Even WPA mode in MPlayer allows to watch 720p without frameskip.
    [ Edited by zukow 10.10.2017 - 23:39 ]
  • »10.10.17 - 22:39
    koszer wrote:
    @Jim, @marmota:
    I don't think we are likely to get dual Radeon because of the way the driver polls for cards, but you're list still isn't particularly valid.
    Even now we can use X1950 cards that haven't been flashed.
    Wait just a little longer, and you might get a demo of the new stuff. It's not quite ready for public consumption, but it's progressed far enough for that.
    And you know they don't generally answer inquiries about future releases.
    I'm not really trying to 'shoot' down your comments, but if we are about to support most of the Radeon cards prior to the GCN cards, wouldn't it make sense to support systems they can be installed in?
    After all, AGP will only get us up to the R600 and R700 cards. I can't see the SAM460 and X5000 being the only systems that support Radeon HD 5000-8000 series cards.
    [ Edited by Jim 10.10.2017 - 20:14 ]
  • »11.10.17 - 01:12
    Jim wrote:
    your list still isn't particularly valid.
    is, is and is. Now read that:
    Dev 1:
    1) Open Firmware compatible PCI Express Radeons are in short supply. Without a such, you'd have no access to the firmware, which makes installing and using the machine quite a hassle. Reflashed cards are not a solution either, as those cards tend to be misconfigured by the flashed firmware, leading to all sorts of trouble on the OS side.
    2) A lot of hardware is different from previous generations of Macs, and thus require completely different code to support. Ethernet and the cooling system are two things, but there's also things like processor frequency and voltage control, which also has to be handled by the OS. There are other things to deal with as well, and those would then have to be tested and adjusted for each revision of that Mac.
    3) PowerMac11s aren't so much better than the PowerMac7s to make up for the required effort
    Dev 2:
    There are still missing drivers including fan/cooling management. There is no onboard eth support and there are already way too many configurations we need to support.
    Late 2005 G5 PowerMacs also came with nvidia cards by default mostly which are not supported as well and require anyone interested in MorphOS to get a supported graphics card first which is not that easy to aquire if you still need OS X/OF working.
    I'm sure there a few people who don't really care about this issues and would still like to run MorphOS on such machine - even one in our team does - but this most likely doesn't account for a reasonable amount of users.
    As you can see both devs are stressing the gfx card issue (which is not such an issue for us, users, but who cares?). Who's right? Koszer's right! :)
  • »11.10.17 - 10:59
    Posts: 2240 from 2003/2/24
    Nah reality just align with you while you‘re still wrong by nature.
  • »11.10.17 - 12:05
    > Now read that:
    > Dev 1: [...]
    > Dev 2: [...]
    Both statements clearly ignore the possibility of keeping the stock Nvidia card installed for OSX/OF display and simply adding a supported off-the-shelf Radeon HD card for MorphOS display. Does that mean these two devs (or the entire MorphOS team) don't deem this solution technically possible?
    The two devs you quote claim it is an issue for the users ("[...] which makes installing and using the machine quite a hassle", "[...] this most likely doesn't account for a reasonable amount of users").
  • »11.10.17 - 14:11
    Thanks Andreas, they aren't issues for me.
    First, Apple Radeon X1900GT cards are not in short supply, and they are fairly cheap.
    I have already proven this in past posts and can produce listings for them any time any of you care to contest this.
    Second, I don't really care about firmware prompts, and if access to firmware is needed, in the past I have just swapped out video cards.
    Third, as pointed out repeatedly, a dual Nvidia/AMD video card settup eliminates this issue.
    So, again, with new video card support on the horizon, wouldn't it be nice to have an upgrade path that could use these cards other than the X5000 or a future X64 system?
    As I plan on buying an X5000/40 when available it's not vital for me. But, as I already own an 11,2 PowerMac, I can tell you from experience that these are better than our current G5s.
    So, once more, why aren't we planning to support the best PowerMac?
    Because the answer doesn't have to do with video cards.
    I already have an Apple Nvidia 6600 and a Radeon HD 6750 in mine (currently connected to two monitors, but I believe MorphOS could be implemented with one, or a switch).
    So if you guys want to wait to use Mark's Radeon HD drivers until we receive X64 support, that is up to you.
    I already have an option to do so, and will act on it.
  • »11.10.17 - 14:37
    @Jim
    All nice and candy....
    But you can't just hit ebay or so and find a PCIe G5 that will work out of the box (except the 20" iSight iMac, but that is rather rare).
    So the support would be like for Cube, read it works but not marketed that way.
  • »11.10.17 - 14:44
    I don't know. I wrote them both that I believe every MorphOS-interested Joe Average can buy a vanilla PC Radeon and stick it in x16 PCIe slot while retaining the nVidia (for all of his OF and OSX needs) in x8 PCIe slot (or any of the x4 slots), but I didn't get any reply since, and it's been like 3 weeks ago.
    On the other hand - I know a MorphOS developer that claims he's using a PCIe G5 with this kind of dual gfx card combo and it seems to works just fine.
  • »11.10.17 - 15:00
    > Apple Radeon X1900GT cards [...] are fairly cheap.
    As outlined a month ago, this depends on your location.
    I think most modern monitors have multiple inputs. (And I'm not sure what "MorphOS could be implemented with one [monitor], or a switch" means anyway.)
  • »11.10.17 - 20:25
    I see no problem listing the PowerMac11,2 as supported with a ****** comment saying that a supported graphics card must be installed.
  • »11.10.17 - 20:55
    So it's a non-issue apparently. Thanks for info.
  • »11.10.17 - 21:06
    guruman
    Posts: 461 from 2003/7/22
    All quite interesting, but what about Saku 2017 MorphOS 3.10 presentation? :-P
    Kind regards,
    Andrea
  • »11.10.17 - 23:47
    I'd settle for qualified support.
    As to Saku, I think we'll need to wait until demos start being presented for the public, not those focused on developers.
    I'm sure there were things said at Saku that are not intended for general consumption.
  • »12.10.17 - 13:52
    I don't think the MorphOS 3.10 presentation at Saku was focused on developers. As to public or not, I'm not sure that the audience of the presentation had to sign an NDA or similar ;-)
    > consumption.
    You mean during the presentation?
  • »12.10.17 - 16:28
    >> consumption.
    No, I meant things said in confidence during the meeting.
    Sometimes when you have something you're proud of it can be hard to contain it, so you hope can only count on that info remains confidential between you and those you choose to share it with.
    I've learned from past experience that its best to wait for the developers to reveal what they will, when they will.
  • »12.10.17 - 18:12
    This thread is about what was revealed during the MorphOS 3.10 presentation at Saku. It doesn‘t need a developer for this. Anyone who was there could share I guess.
  • »12.10.17 - 20:04
    Then I guess all we need is someone who was there that cares to share their experience.
    So far it doesn't look like anyone feels so inclined.
    Hopefully there will be further presentations, or a final release so we can all familiarize ourselves with the latest revision.
  • »12.10.17 - 20:38
