SMP for AROS
    In_Correct
    Posts: 245 from 2012/10/14
    geit wrote:
    In_Correct wrote:
    > New Functions such as SMP [...] and Multi Processor
    I meant Multi Core and Multi Processor.
    Whatever they are, MorphOS uses only one.
    Because I would break compatiblity to use more and I guess you donĀ“t want to be limited to the stuff that comes with the OS.
    Same goes for basically any other feature MorphOS lacks. It will break compatiblity with all existing software. Not only 68K.
    So it just does not make any sense to do that with PPC just to perform this last step and reach the end of the dead end, which only way out is breaking compatiblity all over again.
    Better use the last possible exit.
    If that is the best thing to do, then it is the best thing to do.
    But can software not be updated to anticipate New Functions?
    Would Bounty Help?
  • »25.08.17 - 15:01
    In_Correct
    > 3.9 is our current latest version, so instead of writing that he would
    > want it back ported to what ever was the most current PPC version,
    > I used our current "latest version", which is 3.9.
    You know very well that 3.10 for PPC (and at least the usual follow-up bugfix release which should be 3.11, if not even more releases) is supposed to be released before any x64 version, so you knew that "3.9" would be wrong. Besides, the severe changes that go with such a backport would surely warrant a version number increase for the PPC version anyway (hence "such version would be [...] the same version number as the then-current version for x64, just for PPC64"). Furthermore, I can't see how "back port to MorphOS3.9" is any shorter or easier to write than "back port to PPC".
    > you just love to find any grammar or content fault, and point it out.
    As I'm sure you have realized, I make every effort to ignore grammar faults (as well as orthographic ones), not least because I'm sure I make many of those myself when communicating in a foreign language.
    As to content faults, yes, I don't like them go unchallenged, so I point them out. And I hope everybody does so when I make those myself.
    > I guess that is one way you get your "kicks" for the day
    ...as much as you seemingly get your kicks from writing things you know are wrong.
    Since you are not typing in your primary language, I no longer consider your replies to me as rude and so let me explain why I refer to "The MorphOS Development Team" as "Morph", sometimes with a type of business next to it.
    It is very complex to type "The MorphOS Development Team" every time mention "The MorphOS Development Team". Abbreviating "The MorphOS Dev. Team" is not as efficient as "Morph".
    Many others have mentioned "MorphOS" as "MOS", while MOS is the name of a Hardware Architecture and also of a company that ceased to exist because of problem factory. Even sillier is the successor company used the same factory instead of a different factory. I do not use this abbreviation "MOS" for "MorphOS" because whenever I use "MOS", I use it as the architecture and the company that made the hardware. And "MorphOS" is not much longer, only type 4 extra letters ... On the contrary there is "The MorphOS Development Team" resembles as a long phrase or even a short sentence.
    [ Edited by In_Correct 25.08.2017 - 09:13 ]
  • »25.08.17 - 15:13
    In_Correct
    TheMagicM wrote:
    Fortunately this week has almost ended.
    It is impressive that MorphOS is fast and even faster on SSD. I also want to install MorphOS on SSD.
    But this Fast MorphOS Even Faster On SSD does not make Power Management irrelevant.
    Meanwhile Mac OS 9.2.2 has Power Management functions such as Sleep Mode, and even when use complete restart or Shut Down and Start Up, the previous things open, including the folders, are open again automatically. Even "a-Dock" seems more efficient compared with MorphOS Panels.
    One reason why I do not use MorphOS as often is because of the lack of power management. The annoyance to open everything again by myself, and the energy inefficiency.
    Perhaps Bounty Will Help.
    And perhaps the best device for people to flock to MorphOS, based on success with RISC OS, is a Pi Device. This might or might not attract new development for MorphOS if amount of MorphOS developers have been decreasing.
    [ Edited by In_Correct 25.08.2017 - 10:15 ]
  • »25.08.17 - 16:02
    Posts: 12080 from 2003/5/22
    > if it takes much time to switch to X86 64 Architecture compared with New Functions
    Porting current MorphOS to x86_64 could be done in a short time, I'm sure. It's the fact that it won't be done without adding the new functionality that makes it so time-consuming.
  • »26.08.17 - 13:11
    Being rude has never been my intention.
    It wasn't me who asked you about this in comment #43.
    Always made-up ones at that.
    > It is very complex to type "The MorphOS Development Team" [...].
    That's why I usually just type "MorphOS team" without creating any ambiguity :-)
    Just typing "M" would be even more efficient, wouldn't it? ;-) "Morph" seems to be too ambiguous for some, see comment #43, and I too think that one should at least distinguish between a product (the OS) and a group of people (its developers).
    ...and were criticized for it (never by me, mind you).
    Is it? I can't remember I heard of that.
  • »26.08.17 - 13:41
    Well, as I'm pretty sure we're all aware of, MOS Technology was the creator of the 6502 microprocessor and some of the custom chips used in Commodore computers. They were eventually bought out by Commodore International and renamed Commodore Semiconductor Group.
  • »26.08.17 - 14:34
    Of course I know the MOS company and its 6502 microprocessor/architecture, but I'm not aware that the 6502 architecture is usually referred to as 'MOS'.
  • »26.08.17 - 19:12
    In_Correct
    If not refer to the MOS Technology Hardware Architecture as "MOS", then what?
    "6502"?
    [ Edited by In_Correct 26.08.2017 - 13:47 ]
  • »26.08.17 - 19:47
    > If not refer to the MOS Technology Hardware Architecture as "MOS", then what? "6502"?
    Yes, "6502" is what both the instruction set architecture and the microarchitecture of MOS Technology's 6502 processor are usually referred to.
  • »26.08.17 - 20:05
    Now that we've settled that, generally when referring to the operating system we use the whole name, MorphOS.
    And when referring to the development team, we use that term, or 'MorphOS development team'.
    Abbreviations can lead to confusion, and are generally frowned upon in professional documents/communications.
    And if I'm not mistaken, MOS has other connotations beyond the semiconductor company.
  • »26.08.17 - 21:13
    In_Correct
    Does that also mean that MorhpOS Developers are only developers and not from a corporation?
  • »27.08.17 - 05:35
    Yes, it is not a business entity, it is a group of allied developers.
  • »27.08.17 - 14:09
    ppcamiga1
    Posts: 215 from 2015/8/23
    What endianess has to do with API?
    It is simple. Amiga Os API 1.x was designed hardware depended in a way that works on big ednian cpu only.
    CPU change to one not working in 32 bit big endian mode, twist API about 180 degrees and made not compatible with old 68k apps.
    Why AROS x86 is shit?
    AROS x86 is shit beacuse cpu change to to one not working in 32 bit big endian mode, made API not compatible with old 68k apps.
    What should be first thing to do after API change to compatible with old 68k apps?
    Of course adding memory protection.
    Unfortunatelly AROS developer where to stupid to get this.
    20+ years passed and AROS x86 still has not memory protection.
    No memory protection and no binary compatibility with 68k apps - thats why AROS x86 is shit.
  • »27.08.17 - 14:36
    > team'. Abbreviations can lead to confusion
    As said, I use the term "MorphOS team" and while shorter than the official term, I don't think this can be confusing to anyone.
    Absolutely. 'MOS' is an abbreviation for many things in the broader technology field and in the related computing field, among them even two other specific operating systems:
    https://en.wikipedia.org/wiki/MOS#Technology
  • »28.08.17 - 22:50
    'Soviet UNIX clone', hmm...I'll have to remember that one.
  • »28.08.17 - 23:09
    >>> Change to cpu working in 32 bit low endian mode made API not compatible with
    >>> old 68k amiga software.
    >> What does API have to do with endianness here?
    No, the API has not been twisted.
    No, it's not the AROS API that is incompatible with m68k apps but the AROS/x86 ABI. ABI and API are different things. You can google and read up on the difference between them. If you do this, you'll know why an API doesn't have anything to do with endianness, whereas an ABI has.
    You already said this and it's still false. And it will remain false no matter how often you will repeat it (not that this has stopped you in the past...).
    To make AROS/x86 compatible with m68k apps, the required ABI must be provided. On MorphOS and OS4 this is done by means of the integrated m68k emulation. On AROS/x86, this would indeed be problematic because of opposing endianness between host OS and guest binaries (Emumiga failed for a reason).
    Try AROS/m68k.
  • »28.08.17 - 23:25
    Interestingly, a later derivative of this even ran on 68020:
    https://en.wikipedia.org/wiki/DEMOS
  • »28.08.17 - 23:34
    ppcamiga1
    API was twisted.
    Oryginal Amiga OS API 1.x was 32 bit big endian only.
    No matter how You call it.
    First thing to do after breaking compatibility with 68k apps should be adding memory protection.
    20+ years plus passed and shitty AROS x86 still has not memory protection.
  • »24.09.17 - 19:35
    > API was twisted.
    I call the things what they are. You do not.
    Try AROS/m68k.
  • »25.09.17 - 11:50
    Funny, memory protection is not as high on my list as some other functions.
  • »25.09.17 - 13:13
    ppcamiga1
    > API was twisted.
    If oryginal Amiga OS API 1.x will be not 32 bit big endian only, it should be easy to use qemu/petunia/trance to run 68k Amiga Os apps on x86 AROS.
    Like it is easy to run ppc/68k apps on x86 linux unser qemu, or 68k apps under MOs/Amiga Os 4.
    There is not something like that fully working it means oryginal Amiga OS API 1.x is 32 bit big endian only.
  • »01.11.17 - 07:42
    No, because ABI and API are different things. You can google and read up on the difference between them. If you do this, you'll know why an API doesn't have anything to do with endianness, whereas an ABI has.
    The reason big-endian Linux binaries can run via QEMU on little-endian Linux (whereas big-endian AmigaOS binaries cannot run on x86 AROS) is that Linux has memory protection (whereas AmigaOS and AROS are singular address space operating systems which are based on message passing concept).
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7183&start=261
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=6775&start=148
  • »01.11.17 - 13:23
    TheMagicM
    Posts: 1217 from 2003/6/17
    @amigadave
    I agree with your comment on leaving PPC. Once MorphOS goes x86, I wouldnt go back either. No back porting.. just a "final release" and walk away from that. Concentrate efforts on x86 as I'm sure that will bring much newer set of dev tools/software to MorphOS.
  • »02.11.17 - 02:40
    TheMagicM wrote:
    @amigadave
    Well, as we continue to advance in the coming releases, I think I may be tempted to stay for awhile after this transition/fork.
    Each coming release promises to address issues we are currently facing, and who know when we we will see an X64 fork, or what that will bring.
    So, I'm just enjoying what we're getting now with PPC MorphOS.
    I have a case for an X5000, some DDR 3 memory, an OWC SSD, and a VIA ENVY24 based sound card stashed away (I can't decide whether to fork over the cash for an X5000/20 or wait for the X5000/40, but if we see the latter before the next AmiWest, I'll go with that).
    Unfortunately, the 'Radeon HD 8490' I recently ordered turned out to be an R5 240 when it showed up (apparently the seller couldn't tell the difference). We can't use those yet, as 3.10 will only support up to the R5 235X (which is basically what an HD 8490 is).
    Which reminds me, I already have an R4 240 from a previous purchase that I need to ship to Mark (as he needs an 'Oland' based card). As he already has HD 7770 and 7850 cards (as well as an R7 260X), this will give him a few options when he has time to work on GCN drivers.
    I think where ever this ends up, our terminus in this long running PPC OS will provide some nice improvements in functionality.
    When I first started using MorphOS, the highest level cards supported were R200 cards like the Radeon 8500, 9000 and 9200. Soon after the R300s were supported, later even before G5 support was introduced work on R400 support began. We have R500 support now. And despite the grousing about the lack of GCN drivers, this next update covering everything from the R600s up to the Terascale families is pretty impressive (its a LOT of gpus).
    So, once you guys are ready to rocket off to X64, I'll hopefully have a quad core PPC system, with a nice VIA Envy24 sound card and an advanced AMD video card to use.
    New equipment...and not a bad upgrade from the last hardware available new, the Peg2.
    And if in the future zero updates to MorphOS PPC means an eventual switch to the 'dark side' (at least for this system), no big deal.
    As to X64, I'm exploring Minix 3 right now, and if development of that picks up, I may move to that eventually.
    Its another microkernel OS, like MorphOS, but with support for BSD applications.
    It definitely needs an improved user interface though.
    [ Edited by Jim 02.11.2017 - 08:29 ]
  • »02.11.17 - 14:25
    The Efika 5200B came way after that ;-) And the Sam460cr was available in homeopathic doses after MorphOS added support for it.
    It only uses IA-32, though :-)
    Interesting. Any details on that?
  • »02.11.17 - 20:50
