AROS for 68k question
    Posts: 2720 from 2003/2/24
    OlafSch wrote:
    dropping ... datatypes makes porting applications even more complicated or impossible.
    Not a lot more complicated, and certainly not impossible; if you have enough knowledge to understand how to use datatypes for loading/saving media, it shouldn't be that much of a deal to replace it with Reggae (many well written examples exists), and it opens up a lot of possibilities as a bonus.
    Datatypes is obsolete. It should go.
    Hopefully it does.
    Andreas certainly has no "agenda"
    I meant *you*, not Andreas... ;-)
    I have explained why I think that "NG NG" is not automatically becoming successful
    The definition of "success" is kind of crucial in that statement. I think nobody is expecting MorphOS to be a general desktop competitor to Windows or Mac anytime soon, so that is probably not a goal to measure success for anyone. But today MorphOS is tied to PPC, and that platform is rapidly dying. MorphOS has already covered everything worth supporting regarding PPC HW, and MorphOS hit the Amiga legacy boundaries many years ago. MorphOS has come as far as it possibly can on PPC. The alternative to "NG NG" is stagnation and death, and because of this I think most of us will define a continued life and evolution of MorphOS on a new ISA as a success in itself.
    current community is more retro orientated and might a new platform even not use just because it is too "modern" to them.
    This may apply to the Amiga retro crowd, but hardly to the MorphOS community. I doubt any MorphOS users ever chose MorphOS for retro reasons (the same goes for OS4 I think). We all had Amigas already, what we wanted was the Next Generation, not the past. The retro segment is a completely different one. The problem with current MorphOS is that it turned out to be neither really retro, nor really modern either. It's stuck in the middle. On a sinking 2005 level PPC ship. A MorphOS NG will hopefully cure this.
    You are praising "MorphOS only" software but how much is there and how much will be developed?
    I'm praising SW that makes use of all the new features introduced by MorphOS, since this was the reason I chose MorphOS over a Workbench 3.1 based Amiga retro system in the first place. Advocating that SW should restrain itself and only use old standards goes totally against everything I want from MorphOS! SoundBankster is a shining bright example of SW that depends on things like MUI and Reggae as well as the upcoming MIDI and isochronous USB. I don't care if Amiga 68k don't have these features, I'm glad MorphOS does (will have). This is an example of how new and evolved features are enabling development of SW that wouldn't be possible otherwise. And hopefully more SW will be developed for a MorphOS that is alive and evolving, than a MorphOS that is stagnating on a dead PPC platform. Your option of just rolling over and die "because it will probably not be successful" seems less feasible to me. I'm glad the MorphOS Team is trying, and hopefully good things will come out of it.
    A number of existing PPC software propably is not available in source so cannot be changed and recompiled.
    Quite possible. So MorphOS should just roll over and die, instead of at least trying to go forward?
    MorphOS will have all important Internet applications, it will play movies and music, it will have competent text editors, gfx editors, etc, from the start. It will have a new SDK with a new IDE, and it will have new options and possibilities for non-retro oriented Amiga SW developers that simply aren't here today. Hopefully developers will appreciate this and find good use for it.
  • »02.06.16 - 14:28
    Posts: 12079 from 2003/5/22
    > using 20 year old software or program like you did 20 years ago
    Amiga software from the 1970s? ;-)
    > Most things would still be there, including the kernel.
    And the Quark kernel isn't even Amiga-ish ;-)
  • »02.06.16 - 14:29
    >PCIe-based G5 Macs, anyone? :-)
    That would be a nice addition.
  • »03.06.16 - 11:36
    Samurai_Crow
    Posts: 153 from 2009/12/10
    Re:Vampire 2 boards and Apollo core vs. 68060 cards
    It would be nice to have a 64-bit OS to take advantage of the new features of the Apollo core not present on the '060. In addition to 64-bit addressing, it has vector support also. If it ends up being "Aros 68k done right" then I'm all for it!
    Once I get my V500 baord I'm going to try to hand-compile the AHI software mixing routines for the Paula chip to take advatage of the vector ops to hopefully cut the processor overhead by 75% or so. That should be enough to bring the software mixer in line with the overhead of the other sound-card drivers.
    From there it should be possible to mix to the HDMI output once that get's implemented in the FPGA. That way there can be the possibility of surround sound and CD quality sound or better per channel.
    Does this sound like the capabilities of a stupid old '060 card to you?
  • »08.06.16 - 11:36
    ppcamiga1
    Posts: 215 from 2015/8/23
    As You may easily find Vampire with core5 in sysspeed is still slower than 68060.
    Especially in higher resolutions.
    Vampire with core5 get 95,73 MIPS while 68060 80 MHz get 106,10 MIPS.
    68k "altivec" is interesting but for now there is no software which use it.
  • »09.06.16 - 07:36
    ppcamiga1
    Yasu wrote:
    The point is that since it will be incompatible anyway, why keep all the legacy problems too?
    This is very good summary of the problems with aros x86.
    Aros x86 is not source and binary compatible and has all problems which amiga os has like lack of memory protection, resource tracking, suport for multicore.
  • »09.06.16 - 07:40
    > Aros x86 is not source [...] compatible
    As I already told you in comment #42 a week ago, AROS (no matter the ISA) is source-compatible with AmigaOS 3.1.
    As I already told you in comment #42 a week ago, that's because it is source-compatible with AmigaOS 3.1.
  • »09.06.16 - 08:54
    ppcamiga1
    AROS is not source-compatible with AmigaOS 3.1.
    You have to spend some time coding for aros x86 and You get that most functions from amiga os are not compatible with amiga os because they were never tested with 68k software.
    Especially ZUNE is worth nothing crap which is far away from MUI 3.8 from 1997.
  • »09.06.16 - 09:07
    It may not be 100% compatible at this point. Actually, it's 82% compatible with AmigaOS 3.1 according to http://aros.sourceforge.net/introduction/status/everything.php (as of 6 years ago), but it clearly aims at full source compatibility, hence the restrictions.
    I've a hard time believing this "most functions" (i.e. >50%) claim (assuming that one of the two "amiga os" occurences means "aros).
    Isn't this what OlafSch and wawa have been doing for years?
    MUI has not been part of AmigaOS 3.1, so Zune's MUI compatibility status has no bearing on AROS' source compatibility with AmigaOS 3.1.
  • »09.06.16 - 09:29
    OlafSch
    Posts: 186 from 2011/11/16
    Aros is source compatible, there are small differences on library level like missing or unimplemented fuctions but also new ones compared to 3.5 f.e. but it is very compatible. The 68k branch also is binary compatible and MUI 3.8 and even the newer one (however you call it) can be easily used by copying. Developers are indeed testing it together with Aros 68k and compatibility has improved considerably in recent time. Your posting does not sound like you having any experience with it so where do you know current state of Zune?
    [ Editiert durch OlafSch 09.06.2016 - 11:59 ]
  • »09.06.16 - 09:30
    OlafSch
    nobody (or at least almost nobody :) ) realistic expects such a solution outperforming modern hardware. I do not know where you get your numbers, the last information I had wad that it runs comparable to 68060 100 Mhz. Also it includes lots of new commands so software can be optimized and run faster on it. Yes it is a toy and I do not expect it to overrun the market, it is filling a need in the 68k community where people wanted better hardware for their aging amigas and that at least affordable. So it fills the gap there but 68k is still way faster running in UAE on modern hardware. Amiga today is a retro market mainly with at least parts of the community being interested in better software and that needs truecolor, more processing power and more ram (partly much more ram). BTW at the moment all PPC options are toys compared to modern platforms because of no up-to-date browser and no Javascript JIT even beaten by simple smartphones.
    [ Editiert durch OlafSch 09.06.2016 - 12:10 ]
  • »09.06.16 - 09:41
    >>> vampire [...] is still slower than 68060 80 MHz
    >> That's not true from what I can see from reports and videos. Vampire V2
    >> seems about as fast as an accelerator with 120 to 175 MHz 68060.
    > Vampire with core5 in sysspeed [...] get 95,73 MIPS while
    SysSpeed's MIPS "benchmark" seems flawed, as are most MIPS ratings actually. What are the results of the other SysSpeed benchmarks?
  • »09.06.16 - 09:42
    He wrote where he got (i.e. selectively chose) them from :-)
  • »09.06.16 - 09:54
    OlafSch
    I do not know how realistic all these benchmarks are. But if it now performs like 68060 80 Mhz or 100 Mhz most amiga users (here I mean the old amigas) do not own one of the rare expensive old accellerators so if you want a upgrade card that is not costing a fortune (if you find one on ebay or other sites at all) you do not have any other realistic chance. It is already offering fast processor, 128 MB and RTG, I think planned is also chipset (SAGA) and better sound.
    [ Editiert durch OlafSch 09.06.2016 - 12:08 ]
  • »09.06.16 - 10:07
    The MIPS figure for the 68060 are still pretty impressive.
    I have a project I am working on (not Amiga related) that uses a 20 MHz 68HC000 and the MIPs/MHz ratio is a fraction of the '060's figure.
    But since I need the E output clock, an overclocked 68HC000 is the best option for me.
  • »09.06.16 - 13:33
    ppcamiga1
    Sysspeed is well known, reliable benchmark.
    Sysspeed works on almost every amiga configuration.
    There ara many sysspeed results called modules on aminet.
  • »09.06.16 - 16:51
    Unless there're also ones with Vampire2/Apollo results, your answer to my question doesn't make sense.
  • »09.06.16 - 17:38
    ppcamiga1
    "Happy" users of vampire post many screenshots from syspeed working on vampire.
    Poor performance of vampire is no secret.
    You just have to find it.
  • »09.06.16 - 17:53
    > Poor performance of vampire is no secret. You just have to find it.
    Why so secretive? Just give links to some of these "many screenshots" showing also SysSpeed benchmarks other than MIPS for Vampire2/Apollo.
  • »09.06.16 - 21:53
    ppcamiga1
    It is easy to find. Just try.
  • »10.06.16 - 07:21
    I did, and what I've found shows that Vampire/Apollo is way faster than 80 MHz 68060.
  • »10.06.16 - 07:59
    OlafSch
    you completely miss the point...
    even if that would be true you are not able to get any 68060 80 Mhz accellerator out there or if only for a fortune
    if you talk about economic choices then your nick is also wrong because buying embedded hardware at price of high-powered standard hardware makes no sense either
  • »10.06.16 - 09:36
    > embedded hardware
    It's not, as I told you yesterday.
  • »10.06.16 - 10:42
    OlafSch
    Andreas_Wolf schrieb:
    > embedded hardware
    yes it is a embedded system pretending to be desktop even beaten by any smartphone
    so even if it has some features typical for desktop hardware when you look at processor, graphics and so on it is embedded class
    perhaps we can agree it is a desktop mainboard with processors designed for embedded market
    2 Core with 1.8 Ghz is nothing I would today take seriously for new hardware anymore. New PPC processors (if developed at all) are mostly targetting embedded market or you have IBM with their series. Freescale is obviously dropping PPC now.
    [ Editiert durch OlafSch 10.06.2016 - 12:57 ]
  • »10.06.16 - 10:53
