Price of MorphOS license
    Posts: 12085 from 2003/5/22
    > It is a hosted on Linux version of AROS, so I don't see why it wouldn't be stable.
    > It should be as stable as the Linux distro it is hosted on top of
    Why shouldn't AROS be able to crash when running on top of Linux? Of course, due to Linux' memory protection, AROS won't be able to crash the underlying Linux or any other Linux task running in parallel to AROS, but that's a different thing.
  • »08.06.16 - 21:18
    redrumloa
    Posts: 1424 from 2003/4/13
    ASiegel wrote:
    @ FerociousAmiga
    TheMagicM was referring to people who had previously made fun of MorphOS for supporting only "smelly old used computers" and implied that the OS would be much more interesting if it ran on (more expensive) hardware that was new (but does not offer major performance gains compared to pre-owned Apple hardware, hence seems "outdated" to some).
    Yup, which is why IMO the MorphOS Team should stop trying to court the OS4 crowd and just make the platform jump. 5 new users on Sam460 and maybe 10-15 on X5000 really worth it? Abandon the X5000 port and focus on X86-64. Send the development boxes back to A-Eonkit and wash your hands of the whole situation.
    JMHO, YMMV
  • »08.06.16 - 21:33
    FerociousAmiga
    Posts: 8 from 2016/6/6
    Well sorry guys & gals... I over reacted....
    PS
    Does MorphOS have Guru Mediation screen? I crashed my Rune Audio on my Raspberry Pi and my surprise it gave me a Guru Mediation screen. Good Old memories! :D
    [ Edited by FerociousAmiga 09.06.2016 - 11:20 ]
    MorphOS 3.9 (Licensed!)
    Mac Mini G4 (1,5GHz, 64MB VRam, 1GB Ram, 32GB Kingspec PATA SSD)
    Amiga 1200, 68020
    Amiga 500
    Amiga 1000
  • »09.06.16 - 15:14
    redrumloa wrote:
    ASiegel wrote:
    @ FerociousAmiga
    JMHO, YMMV
    "Abandon the X5000 port.."
    Say what?!
    I'm counting on that to run the X5000 I intend to buy.
    Otherwise, why buy one? ;)
  • »09.06.16 - 15:24
    No.
  • »09.06.16 - 15:54
    Posts: 1033 from 2004/9/23
    No it doesen´t.
    We removed the crash part, so no need for a Guru Meditation.
    Say what?!
    Just relax. The X5000 port was shown with MorphOS the first time over a year ago. - Working! -.
    So no need to abandon anything. The whole Sam460 port only exists because of the X5000. If the X5000 board would have been available earlier, there probably would not be a Sam port at all. The Sam460 and the X5000 are quite similar, so the SAM was used to adapt MorphOS years before the X5000 was available (for developers).
    At the end the MorphOS got (and gets) tons of changes when the X5000 finally is available for the masses, which will probably still take a while as Hyperion is probably busy with the next project (tabor) already.
    I personaly have no clue why they sit on an stack of high priced boards and not selling them.
    However they will have to compete with MorphOS once again and - unlike the Pegasos2 - on their playfield. Yes, there is the Sam, too. But since the MorphOS Team is supporting graphic boards one by one, supporting 2d and 3d Hyperion or who ever develops drivers is jumping to insane high end models mostly supported partly. So just a limited number of boards supported by both systems at the same time.
  • »09.06.16 - 15:55
    Thanks for the insight. Would you please explain these similarities between the Sam460 and the X5000 (or alternatively, have some lowlevel developer like bigfoot do it)?
    > (for developers)
    According to bigfoot, the P5020DS (available from Freescale since September 2012) was used before the X5000 was available for developers.
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=11137&start=167
    http://www.nxp.com/webapp/search.partparamdetail.framework?PART_NUMBER=P5020DS-PB
    > Hyperion is probably busy with the next project (tabor) already. I personaly
    > them. However they will have to compete with MorphOS once again
    Strangely, this reads as if you see A-Eon and Hyperion as a single entity.
    The compatible "Southern Islands" GPUs also include entry-level variants.
    And there's still the audio problem with MorphOS on the Sam460cr, isn't it?
  • »09.06.16 - 17:18
    Thanks for the insight. Could you please explain these similarities between the Sam460 and the X5000 (or alternatively, have some lowlevel developer like bigfoot do it), please?
    I am out here. This is what I was told about the reasons the x1000 was off the list, as it is completly different.
    Well, Hyperion is the company composing the OS. No clue what their relationship with A-Eon is, but I would insist in finishing the X5000 port to avoid money rotting in the basement, where stacks of X5000 are stored.
    The Sam460cr has no audio, so no problem at all. The other SAM460s are fully supported by MorphOS.
    You probably can stuff in some Envy-Card to get sound. No clue about the limitations/number of the board and the pci slots.
    USB Audio would be a solution here, but USB-iso transfer would be required for that.
  • »09.06.16 - 17:46
    Nope, the Envy driver is broken.
    I sold my Envy based card because of that.
  • »09.06.16 - 19:09
    Posts: 2794 from 2006/3/21
    I often write less in my posts than what I am thinking of regarding the answers (which is surprising considering how long winded too many of my forum posts are), and I should have added that AEROS should be just as stable as all other versions of AROS.
    I haven't read any complaints regarding AROS being prone to crashing often, so I don't think it is a common problem, but I don't read AROS forums, so I could be assuming too much and it might be less stable than I imagine. My point was that I don't think AEROS is any less stable than any other version of AROS.
    [ Edited by amigadave 09.06.2016 - 14:51 ]
  • »09.06.16 - 20:44
    Well, no clue about 3.9, but the driver should work.
    Even if not you seemed to mixed up "selling" with "bugreporting".
    [ Edited by geit 10.06.2016 - 00:20 ]
  • »09.06.16 - 21:19
    Yasu
    Posts: 1724 from 2012/3/22
    Well, it's a research OS, open source and free as in free beer. I don't think people demand as much as over here. My experience is that AROS is much more stable now than 4 years ago.
    My MorphOS blog
  • »09.06.16 - 22:02
    > I am out here.
    Too bad. I hope bigfoot (or someone else in the know) will find the time to explain this to us mortals. I'm sure I'm not the only one with an interest.
    > Hyperion is the company composing the OS. [...] I would insist in finishing the X5000
    Yes, but the rotting money is A-Eon's, not Hyperion's. And it's A-Eon who "sit on an stack of high priced boards and not selling them", not Hyperion.
    No, you can't with MorphOS.
    http://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11256&forum=11&start=18
  • »10.06.16 - 00:08
    According to cyfm, the reason why MorphOS doesn't support such card in the PCIe x1 slot of the Sam460 is that MorphOS can't currently see PCIe cards with PCI-based chipsets connected via (on-card) bridge chip to the PCIe x1 slot.
    http://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11256&forum=11&start=20
  • »10.06.16 - 00:17
    You may want to read the AEROS review linked there:
    http://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11709&forum=3
  • »12.06.16 - 13:26
    OlafSch
    Posts: 186 from 2011/11/16
    You do the same mistake as the author... generalizing Aros
    it is one distribution on one hardware platform 6 months ago
  • »12.06.16 - 13:54
    No, I don't. amigadave and me have been discussing the stability of AEROS for Raspberry Pi 2, and the review is about AEROS for Raspberry Pi 2. Where is the generalization on my part?
    Yes, the distribution and hardware platform amigadave and me have been discussing.
    > 6 months ago
    Indeed, there have been updates to AEROS for Raspberry Pi 2 after the review was published. It would be nice to know whether the problems mentioned by the reviewer have been addressed.
  • »12.06.16 - 20:27
    phoenixkonsole
    Posts: 140 from 2010/8/4
    You can grab the demo. It is the version which was tested in this article.
    It is 2 major releases behind. It doesn't work on a pi3 for instance and i386 emulation has seen also a big version jump.
  • »12.06.16 - 22:24
    Posts: 6 from 2016/6/11
    I'm new here and the high price really scares me. I am one of those people who just like to try out different OS and hardware, and happened to have a powerbook laying around for the past few years so the other day I loaded morph onto it to try it out. I really like that it is something different but what really scare me is lack of software, among other stability issues. First of I am new the the whole Amiga thing so I don't have too many retro expectations, all I know is compared to other systems the amount of software seems low and the usability is very different. I have had to relearn how to use this system as nothing is the same as anything else I have ever used. I have had many performance and usability issues that would not make me want to spend $125. Many times the whole system randomly locks up on me or crashes and Im forced to reboot. This combined with the bleak future outlook (How long can we continue using outdated powerpc hardware that apple stopped making 10+ years ago? and is this very feasible). youtube videos in the lowest quality stutter and major web services fail to load at all without any flash support. Basic HTML pages run the CPU up to 100% for a good 20 seconds and im using the 1.67GHz powerbook 2GB DDR2 ram fastest one ever made. ATI RAGE stopped hitting the mark 10 years ago....
  • »13.06.16 - 04:22
    Sam460 and AmigaOne X5000 to the rescue ;-)
    http://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11710&forum=3&start=3
    That's not "basic HTML" then but JavaScript overload.
    Huh?
  • »13.06.16 - 08:54
    Yasu
    @Ozfer
    Welcome to the blue camp :-)
    Yes, Amiga is very different from everything else so you have a pretty steep learning curve here. You are spot on that we have a terrible lack of modern software, which is sadly not likely to improve anytime soon. But there are still a lot of useful software out there if you just know where to look.
    Any OS friendly app that doesn't bang the Amiga hardware should work with only minor bugs in MorphOS. Just ask what kind of software you need and chances are there is a working clone of it somewhere.
    As for the crashes, it does sound like a hardware problem as MorphOS don't crash by doing nothing. My guess is the RAM.
    There is a roadmap to change to another CPU and update the OS so it will have all modern features needed. But the Team don't have shedules as they never know if they can deliver on time. They usually just tell about upcoming features when it's 100% sure it will come.
    MorphOS is a hobby OS, and the Team makes very little money out of it. If you find it too expensive for you then that is fine. Just play around with the free version instead. And if you change your mind you can pay whenever you want.
    If you want some tips you can visit my blog: www.morphosuser.wordpress.com. I made it with beginners in mind.
    Once again, welcome!
    My MorphOS blog
  • »13.06.16 - 09:47
    Intuition
    Posts: 1110 from 2013/5/24
    It's definitely your RAM. I have the same model of PowerBook and the second RAM slot is faulty. It's an extremely common manufacturing fault with these machines.
    Remove the second ram stick and the random lock ups will vanish.
  • »13.06.16 - 10:38
    I don't understand why morphos doesnt just get based on linux or something, port the whole mui ambient thing to linux where it could run flawlessly, and with the jit emulator it would be 99% identical to what exists now but better in many ways.
  • »16.06.16 - 15:52
    m68k programs also need the presence of the AmigaOS API, which "linux or something" doesn't provide.
  • »16.06.16 - 16:19
    Posts: 2994 from 2003/3/5
    What fun would that be? :)
  • »16.06.16 - 18:17
