GLUT crash
  • MDW
    MDW
    Posts: 488 from 2003/7/25
    I don't use GLUT but now I want to create an example as simple as possible. In this case GLUT is very useful. Unfortunately I noticed that each application which uses GLUT crashes at exit. I have an old example which was working correctly in past. Now crashes always. I have no idea how to correctly implement a GLUT application without the crash. :(
    Is it a bug in GLUT?
    [ Edited by MDW 13.07.2023 - 17:44 ]
  • »13.07.23 - 13:44
    bigfoot
    Posts: 510 from 2003/4/11
    It might be my bug. With the TinyGL updates I did, I also made a fresh MorphOS port of FreeGLUT to go with the example applications I made, so things have definitely changed on the MorphOS side. Can you show me a log of the crash you get?
  • »14.07.23 - 08:25
  • MDW
    MDW
    I have sent you mail with (subject “glReadPixels again”) with attached simple example program which after build with the latest SDK always crashes after press Esc. I also noticed that now glReadPixels saves black screen instead of screenshot. This is the same test which was working well after your fix of the function in March 2022.
  • »14.07.23 - 09:44
    bigfoot
    Ah, I didn't realise those two were related.
    I've found the problem. I'll fix it soon. In the meanwhile, you can work around the bug by modifying your linking. Either link libglut before libGL, or completely omit libGL, ie, change the following:
    -lGL -lglut
    To
    -lglut -lGL
    That should avoid the crash until I get this issue sorted out.
  • »14.07.23 - 11:10
  • MDW
    MDW
    -lGL -lglut
    To
    -lglut -lGL
    Yes, it works. Now the test application doesn't crash at the end. Thank you for the solution!
    The crash still occurs if I use:
    glutDestroyWindow(glutGetWindow());
    or just:
    exit(0);
    However from my test point of view it is not a problem.
  • »14.07.23 - 13:41
    bigfoot
    That's weird. That's not happening for me. Any chance I could get you to supply me with a log? :P
  • »14.07.23 - 13:57
  • MDW
    MDW
    [ Edited by MDW 18.07.2023 - 21:50 ]
  • »18.07.23 - 17:24
