Posts: 2794 from 2006/3/21
I just found and bought a dual 1.42GHz G4 CPU board that was removed from a FW800 MDD G4 PowerMac. I got it for $50 with free shipping, but without the copper heatsink. Has anyone else made this upgrade?
What things do I need to look out for in making this swap of CPU boards, if any?
I decided that I wanted to get a little extra speed and the 1.42GHz CPUs overclocked to 1.67GHz while keeping the L3 cache would probably be the best choice, instead of the 1.8GHz, or 2.0GHz third party CPU boards for the MDD model G4 PowerMacs, which are almost impossible to find and very expensive to buy.
The only Apple copper heatsinks for the 1.42GHz G4 I can currently find are on eBay for $49.95, so I will probably wait to see if I can find one cheaper and see how well the aluminum heatsink I already have will do at cooling the dual 1.42GHz cpu card, now that I have a non-stock, quieter fan in my G4 PowerMac MDD. The fan I found has good airflow, but not quite as high as the stock fan at full speed.
[ Edited by amigadave 27.10.2011 - 21:33 ]MorphOS - The best Next Gen Amiga choice.
