Pegasos/MorphOS graphic boards compatibility list!!!!
  • vox
    vox
    Posts: 524 from 2003/11/25
    > Hope to see onward progress to HD 6xxx and 7xxx
    Unlikely, as there are no PCI cards beyond HD 5450.
    MorphOS support for HD 7730 and beyond would be nice, indeed.
    > OS4 uses them just a bit for 2D display. Having Warp3D on them
    > would be a great achievement.
    Huh? OS4 uses cards that "most of SAM460ex/x5000 systems are equipped" with "just a bit for 2D display"? That's certainly not true. The truth is that X5000 systems have been delivered exclusively with cards that are 3D-supported (Warp3D and Warp3D Nova) by OS4.
    First of all, I wanted to extend topic to PCI-E Cards since with SAM460 and x5000 MOS systems are now PCI-E also.
    SAM460 and x1000 were all shipped with cards that never got 3D support (4xxx-6xxx) while yes, x5000 is shipped with Warp3D Nova card with no older Warp3D support (Do have Enhancer 1.3 and Radeon 7xxx and yes, you still have to buy another Warp3D driver).
    Not to mention, once you go 7xxx SI cards, you lose 3D under Linux.
    Now, back on MOS, any full PCI-E card support (with full 3D) after 9600 and X14xx (or whatever were the last PCI models) would be great 3.11+ archievement. I suppose these drivers could be legacy backported to x64 if needed, so are a must on future x64 front too (or done in x64 and backported to PPC32/64, irrelevant).
    Topic is Peg2 but also about MOS gfx cards.
    [ Edited by vox 16.08.2018 - 14:20 ]
    Lame PC with AmiKit XE
  • »16.08.18 - 13:19
    Spectre660
    Posts: 275 from 2015/6/30
    The Powerpc 3D performance bands are increasing quite significantly .
    Dont know if this will have any influence on the MorphOS powerpc graphics card support Roadmap.
    Using AmigaOS 4.1FE, Warp3D Nova and the Level 1 on the game Spencer for basic fps info .
    X5000/020
    Comparison
    ASUS R7-240 (Oland) = 22-23fps
    ASUS R7-250 (Cape Verde) = 52-55fps
    Club3D R7-370 (Pitcairn/Curaçao Pro) = 55-62fps
    PowerColor R7-250X (Cape Verde) = 64-69fps
    ASUS R9-270X (/Pitcairn/Curaçao XT)= 72-80fps
    Sapphire Rx 550 4Gb (Polaris 12) = 95-109fps
    Asus Rx 560 4GB (Polaris 11) = 128-161fps
    [ Edited by Spectre660 16.08.2018 - 10:21 ]
  • »16.08.18 - 14:19
  • ASiegel
    Posts: 1370 from 2003/2/15
    No.
    Comparison
    You can find a similar range of frame rate numbers for 3D games that run on MorphOS with older graphics cards...
    Also, with all due respect, Spencer, which certainly looks nice enough based on screenshots, is not exactly pushing the boundaries of real-time 3D graphics on the PowerPC architecture. There are plenty of games with notably more sophisticated 3D engines and graphics effects running on the PowerPC-based XBOX 360, which happens to feature an ATI / AMD GPU that is only 2 or 3 years newer than the R300-based chips as found in the vast majority of MorphOS systems out there.
  • »16.08.18 - 19:47
    Spectre660
    I keep forgetting about the current installed base .
    Any cards supporting OpenGL 3.3 or higher would advance 3D.
    If you factor in the current installed base it might not be worth a developing any though further.
  • »16.08.18 - 21:11
    Posts: 888 from 2004/1/24
    I rather think that what's implied here is that the drivers (for the cards running the Spencer game) are....not doing very well.
  • »16.08.18 - 21:24
    Spectre660
    Polite but nice speculation .
  • »16.08.18 - 21:58
    Posts: 12080 from 2003/5/22
    All cards supported by Warp3D Nova are also supported by "older Warp3D" via Warp3D-SI.
    R3xx: 9800 XT
    R4xx: X800/X850 XT
    R5xx: X1950 Pro/XT (also, there is no X14xx)
    Why not AGP?
    You mean 3.12+. 3.11 has already been released.
    I don't think any port to x64 would classify as a backport ;-)
    Chain-Q's comment you replied to and quoted twice was only about graphics cards on Pegasos II running MorphOS.
  • »16.08.18 - 23:16
    Spectre660
    The Polaris cards may not support Warp3D-SI.
    Possible solution.
    [ Edited by Spectre660 16.08.2018 - 19:36 ]
  • »16.08.18 - 23:28
  • ASiegel
    Spectre660 wrote:
    I keep forgetting about the current installed base.
    With regard to MorphOS 3.x, users with (usually non-upgradable) R2/300 GPUs outnumber users with PCI-E systems by a giant margin, which is unlikely to change unless perhaps the X5000 receives a massive price cut.
    That said, it is not like the hardware capabilities of these GPUs have been fully utilized yet. There is still room for improvements.
    That seems like a rather arbitrary statement.
    I would like to refer you to my game console example again. The PlayStation 3 and Xbox 360 were released 12 and 13 years ago. Both have had their CPU performance compared to PowerMac G5 systems. Both also feature GPUs that are more than a decade old as well. Yet, when you look at titles such as Alan Wake, Crysis 3, Forza 4 or GTA 5, they show 3D graphics effects that outclass anything running on any PowerPC desktop operating system today by far. (Or small-niche i386 operating systems for that matter.)
    This just shows it does not matter when your GPU was released but how you use it.
  • »17.08.18 - 08:29
    Andre has a really good point here.
    The progressive refining and polishing of the R200 driver yielded a big jump in performance, and our drivers don't fully utilize that hardware.
    When you consider the features in the later Terascale gpus we're adopting, and the fact that our drivers don't utilize these gpus significantly differently than the R200s, all we are really gaining is an increase in the speed of basic operations.
    So OpenGL 3.3? If the OS doesn't support that functionality, does it matter?
    [ Edited by Jim 17.08.2018 - 15:17 ]
  • »17.08.18 - 19:53
  • vox
    vox
    Again, I throught so until tried. Warp3D support needs a separate, payable driver from AmiStore that is NOT included with Enhancer
    R3xx: 9800 XT
    R4xx: X800/X850 XT
    Thanks, that was most informative. I believe X1950 has a great chances being both OS4 and MOS compatibile.
    Why not AGP?
    Because beside Peg2 only old AmigaOnes use AGP.
    Probably some Cloanto minor fix I missed.
    I ment drivers done first for x64 rel. and then backported to maintaned PPC64 release, if that is priority order.
    [ Edited by vox 17.08.2018 - 20:56 ]
  • »17.08.18 - 19:56
    outrun1978
    Posts: 28 from 2018/7/8
    Thanks, that was most informative. I believe X1950 has a great chances being both OS4 and MOS compatibile.]
    The X1950 like the X1650 I am currently using on my X5000 is compatible with both but sadly there is no Warp3D on these cards under AmigaOS 4. You can use Wazp3D but I’ll be honest this performs better in a blue shade than it does in a red one. Case in point Wipeout 2097.
    For the time being at least if you wish to run both MorphOS and AmigaOS on the X5000 you have to sacrifice Warp3D/Warp3D Nova on AmigaOS 4. I guess the deciding factor is down to ones own personal needs and desires.
    Each OS has its pluses and minuses too, striking a balance is perhaps the best option 😉
  • »17.08.18 - 20:27
  • ASiegel
    As you should be aware, the only PowerMac G5 models that are officially supported by MorphOS use AGP graphics cards... (And these systems are quite a bit faster than a Pegasos2 both in terms of CPU and GPU performance too.)
  • »17.08.18 - 20:29
    > our drivers don't utilize [Terascale] gpus significantly differently than the R200s
    At least for now there's still a significant difference: one is 3D-supported, the other isn't :-)
    > If the OS doesn't support [OpenGL 3.3] functionality, does it matter?
    At least porting more recent games (OpenGL 3.3 is from 2010) may require newer OpenGL than MorphOS currently provides.
  • »18.08.18 - 10:34
  • vox
    vox
    Yes, I am aware, but there are also dual and quad core G5s with PCI-E
    and it would be best to also support them. PCI-E card support is a must
    now with x5000 and SAM460 and x64 transition.
    I am aware and well remember how AGP was step up to PCI.
  • »18.08.18 - 11:39
    Note that what I listed are AGP cards, not PCI cards.
    Yes, just lack of 3D support on OS4 side.
    >> Why not AGP?
    ...and MorphOS-supported PowerMac G4 and PowerMac G5.
    No, you were talking about MorphOS at that point.
    That's clearly not what you meant by the quoted part. You were talking about that direction separately.
  • »18.08.18 - 11:48
    Spectre660
    If we are talking AGP cards the higher end cards Radeon supported currently up to the ATI FireGL X3 are OpenGL 2.0 . Everything in the higher series are OpenGl 3.3 .
    An observation under Linux Powerpc was that the game Torcs would not render properly with a OpenGl 2.1 video card but would with an OpenGl 3.3 card
    [ Edited by Spectre660 18.08.2018 - 08:03 ]
  • »18.08.18 - 11:57
    Good point. Earlier cards have 3D support. And the R200s even have Warp3D support.
    An update to TinyGL would be nice.
    OpenGL 3.3 would be a good target, better than OpenGL ES.
  • »18.08.18 - 13:34
  • vox
    vox
    Spectre660 wrote:
    These demos already work with Polaris cards .
    That is really nice advancement on Hans side, Kudos, but I see no point
    in it (beside game conversion) on a computer that does not have a proper
    office or a browser, for a starter.
    With only Enhancer and Gfx driver being done, and not OS 4.2, Libre and TW/newer Odyssey port OS4 will remain plausable toy to look at, forever.
    Its my belief AEON has really mixed their priorities, or decided to consiously go for easier goals that can cash in. Mind that OS 4.2, Libre and browser have been promised back at x1000 release days, 2011/2012, that is, six years ago. OS 4.2 was prepaid by x1000 users.
    At the other hand, drivers for gfx cards are advancing, but require constant cash-in, which I find embaressing so far.
    - 1.x driver purchased with x1000 just to have in WB
    - 1.x driver purchased again to have CD install (silly me, believed it will be updated for free for owners)
    - 2.x driver purchased with Enhancer to have SI 3D and better Emotion playback
    - need to purchase additional driver to have old Warp3D via AmiStore (!?!!!!)
    - We will now have 3.x driver for Polaris and some enhancements ...
    Sorry, that is starting to cost as an office suite.
    I prefer MOS approach where you buy the OS, and drivers are developed inside that price. At least for "supported hardware".
  • »21.08.18 - 18:45
    And browser is what OS4 users got (ReAction-OWB, Timberwolf, MUI-OWB, Odyssey) :-)
  • »21.08.18 - 20:14
  • vox
    vox
    Dont forget the Ibrowse bundled. Beside Odyssey that used to work quite a long time, and would if they provided updating - I cant really tell you which of mentioned is better and worse. TW had quite fair results in one OS4 version session it worked on x1000.
    Hope ranting will stop as soon MOS and Vamp setups are done :-)
  • »22.08.18 - 07:39
    Posts: 358 from 2019/5/9
    Chain-Q wrote:
    Does this answer your question? : Pega2-2GB-RadeonHD.png
    Made with an earlier beta, but the final works as well. 3.10 improved the support, so the card is now initialized properly without the OF, and works in a Pegasos II, or Efika. It didn't work with 3.8 or 3.9 at least. I still cannot wholeheartedly recommend it over an R9800 or 9200 though, for the aforementioned reasons.
    Please, are there some benchmarks to compare Radeon9800 and HD4xxx ?
    For example SDLBench and MPlayer. And please, is it PCI card?
    Or some new ideas about best card for Pegasos2?
    Just now I overclocked my Pegasos 2 to 1.33GHz and want also upgraded graphics. I take Radeom 9800Pro and wil try overclocking. But maybe HD4xxx will be better choice.
    AmigaOS4: Micro A1-C, AmigaOne XE, Pegasos II, Sam440ep, Sam440ep-flex, AmigaOneX1000
    MorphOS: Efika 5200b, Pegasos I, Pegasos II, Powerbook G4, Mac Mini, iMac G5, Powermac G5 Quad
  • »19.05.19 - 13:41
    That is an accomplishment, but I think I would have just looked for a universally keyed R360 based card. At least you'd have 3D support. Although with the R700, you do still get overlay support. I don't play a lot of games, so 3D is less important.
    And if Mark follows his progressive evolution path, the R600 and the R700 cards would be the most likely to receive 3D support first.
    Personally, I'd like to see 3D support for higher end cards.
    But the cards supported by Warp3D Nova, Radeon HD 77xx-79xx series graphics card (excluding the Radeon HD 7790), Radeon HD R7 240/240D, Radeon HD R7 250, Radeon HD R7 250E, Radeon HD 250X/265, and the Radeon HD R9 270/270X/280/280X are all getting king of dated.
    Jumping to Radeon RX, Vega, or Navi would at least give us up to date gpus.
    Although...I did like the Radeon HD 7850/7870. I sent one to Mark, but its not on the compatibility list (its a GCN card, we aren't up to those yet). GCN gen 1 and gen 2 would give us a lot of compatibility with OS4.
    [ Edited by Jim 19.05.2019 - 18:10 ]
  • »19.05.19 - 22:55
    > is it PCI card?
    Yes, it is.
    As written in comment #126, the most recent card to work in the Pegasos II should be the Radeon HD5450 (albeit no overlay support for now).
  • »20.05.19 - 10:49
