Pegasos/MorphOS graphic boards compatibility list!!!!
    Chain-Q
    Posts: 347 from 2003/10/12
    I've got a HD4350 PCI, which I tested in my Pegasos II. OF obviously doesn't work, but MorphOS 3.10 should. Sadly, the performance is compromised by the PCI bridge of this card, and the 33Mhz PCI slot, so the available bandwidth to the HD Radeon is a magnitude slower than to an AGP card, so overall the experience is not really improved compared to an R200 or R300 Radeon.
    Would be fun if someone could try an AGP to 3.3V PCI passive converter (similarly what the Efika has, but the "other way around"), and try the PCI Radeon HD in the AGP slot, but I couldn't find such a piece of hardware.
    [.Hosting AmigaSpirit.hu.]
  • »02.04.18 - 10:43
    Posts: 12085 from 2003/5/22
    > I would not broadly classify graphics cards as "unusable with a Pegasos"
    > for not showing me "SmartFirmware(tm)"
    Until now I thought that an OS running on the Pegasos II would inherit this firmware limitation. Good to learn that this is not the case and that from a user perspective it works similar to using an AtomBIOS-based graphics card in a PowerMac G5.
  • »02.04.18 - 12:05
    Should or does/did? Initial HD4350 support was added with MorphOS 3.8.
    > Would be fun if someone could try an AGP to 3.3V PCI passive converter [...],
    Yes, as the weakest link determines the total speed, PCIe <-> 66 MHz PCI <-> AGP should be twice as fast as PCIe <-> 66 MHz PCI <-> 33 MHz PCI.
  • »02.04.18 - 12:27
    Chain-Q
    Does this answer your question? : Pega2-2GB-RadeonHD.png
    Made with an earlier beta, but the final works as well. 3.10 improved the support, so the card is now initialized properly without the OF, and works in a Pegasos II, or Efika. It didn't work with 3.8 or 3.9 at least. I still cannot wholeheartedly recommend it over an R9800 or 9200 though, for the aforementioned reasons.
  • »03.04.18 - 21:33
    > [...] the card [...] works in a Pegasos II, or Efika.
    Wow, that's seriously cool :-) Thank you for posting this.
  • »03.04.18 - 23:51
    Wow, that‘s seriously cool :-) Thank you for posting this.
    Yes, that IS very nice.
    Until now, your best choice was a universally keyed Radeon 9800Pro.
    Of course the Radeon still has the advantage of 3D acceleration.
    But these HD PCI cards should eventually receive 3D support.
    The PCI bus is comparatively slow, but the superior power of these gpus should help compensate for that.
    And these PCI cards could be used on other AGP systems, since our AGP support tops out at the X1950Pro (and the Apple X800XT actually performs better since it isn't limited by 1X bus transfer rates).
    I know it was Marks decision, but I still wish we'd received support for the AGP variants of the HD 3850 and the 4650/70. They would have been transfer rate limited as well, but an HD 3850 or 4670 should be a match for the 5450.
    In any case, our future really depends on adopting PCIe systems.
    There are no high end HD based PCI cards, and running a PCIe card in a PCI slot (as some SAM440 OS4 users do), just seems too limiting.
    Still, I'm distracting from the main point, Peg users can now upgrade to cards beyond the Radeon 9800, and that's cool.
  • »04.04.18 - 06:24
    I still think this depends on the use case.
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=9&topic_id=12232&start=52
    > running a PCIe card in a PCI slot [...] just seems too limiting.
    Is that because "the superior power of these gpus" cannot "help compensate for" the "comparatively slow" "PCI bus"? ;-)
  • »04.04.18 - 10:34
    BSzili
    Posts: 559 from 2012/6/8
    Here's one, but it's a home-made project, and I don't think it was ever mass-produced:
    http://extreme.pcgameshardware.de/tagebuecher/233982-projekt-agp-1-0-pci-adapter.html
    [ Edited by BSzili 04.04.2018 - 11:47 ]
  • »04.04.18 - 10:46
    Posts: 1246 from 2004/2/8
    Now where are them, benchmarks, mate? ;)
  • »04.04.18 - 11:11
    > Here's one [...]
    Looks like the wrong direction (AGP card in PCI slot) to me.
  • »04.04.18 - 15:05
  • vox
    vox
    Posts: 524 from 2003/11/25
    I am glad HD 4xxx series support is on. Hope to see onward progress to HD 6xxx and 7xxx, which is what most of SAM460ex/x5000 systems are equipped now, and could be a great leap forward from older cards. Too bad OS4 uses them just a bit for 2D display. Having Warp3D on them would be a great achievement.
    Lame PC with AmiKit XE
  • »07.07.18 - 19:23
    Unlikely, as there are no PCI cards beyond HD 5450.
    1. PCIe cards are completely irrelevant for the Pegasos.
    2. HD 6350 to 7670 (except 69xx) PCIe cards are already supported by MorphOS.
    3. Almost no Sam460/X5000 systems used for OS4 are equipped with a HD 6350 to 7670 card due to OS4's lack of 3D support for cards before HD 7730 (i.e. pre-GCN).
    MorphOS support for HD 7730 and beyond would be nice, indeed.
    Huh? OS4 uses cards that "most of SAM460ex/x5000 systems are equipped" with "just a bit for 2D display"? That's certainly not true. The truth is that X5000 systems have been delivered exclusively with cards that are 3D-supported (Warp3D and Warp3D Nova) by OS4.
  • »07.07.18 - 23:55
    I'm surprised that no owners of Peg2 systems complained about the voltage issues that make the R600 and R700 AGP variants incompatible with that system.
    A voltage mod for these boards would be useful.
    I'm not sure the firmware would recognize an R400, but using AGP variants of the R600 and R700 wouldn't require firmware support.
    BTW - Sorry, but no benchmarks on the new AGP cards from me as everything except my iBook is in some state of disassembly.
    I'd really love to hear how the HD3650-HD4670 AGP cards work (and yes, I know there are 2600 AGP variants, but really, why would you bother with one).
    I may just have to replace the old 7,2 model I've got as I can't track down the problem.
  • »08.07.18 - 15:19
    ...same as with AGP cards based on R400 and R500, right?
    R4xx is the last series that contains real AGP GPUs, namely R420 and R481.
    > [...] I'd really love to hear how the HD3650-HD4670 AGP cards work
    As far as I understand the MorphOS 3.11 release notes, Radeon HD AGP support has been extended to R600 series (HD2350 to HD3870) but does not include R700 (HD4xxx).
  • »09.07.18 - 00:16
    Yep, in fact,if you want to use an R300 you usually need a universally keyed video card. I have found some 9800XT core equipped cards based on 9800Pro designs (a clocked at that speed) that are universally keyed (but running at a higher/XT speed would probably require a better cooler on most of them, they don't have temp or fan speed sensors, would require a bios mod to run the gpu faster, and may be equipped with slow memory requiring that you know what speed you need to clock to gpu and memory at).
    That is cool. Of course, we are back to the voltage issue at that point, but if I had one, I'd figure out how to do it. Then again, the R300 driver on a Radeon 9800Pro might perform almost as well as an X800XT on that platform.
    And if we are modding for voltage, then why not go full bore and use an AGP HD3850?
    Oh, I thought Mark had enabled both the R600 and R700 cards. Its not that big an issue though, as the HD 3850 performs as well as the HD 46XX (with a more even frame rate).
    So we just have to pay a little more for the HD3850 cards (they seem to be more popular than the HD 46XX, and usually command a higher price).
    I'll have to take a look and see if AGP HD 3650 support has been enabled.
    These can sometimes be had at good prices, and I'd like to try one in a G4 (with pins 3 and 11 taped masked for AGP 4X compatibility).
    If we've received support for all R600s, there are 2XXX and 3XXX series cards (other than the HD 3850)that would be interesting to explore.
    Its nice to see these last AGP variants being supported, as the majority of our supported hardware is AGP, not PCI-e. And with Atom bios support (that Mark introduced with the R500 driver) we no longer have to be limited to Apple cards for G4 and G5 systems).
    These were all options Mark has been talking about for awhile.
    You all can argue about what should take priority, but you can't discount the man's commitment.
    Support for everything (except the 69XX cards) before the GCN cards, drivers that don't rely on an Apple rom to run more modern gpus, and now AGP support.
    My guess would be that Mark has figured out how to improve the transfer rate of the bridge chip (that was the Achilles heel of the X1950Pro AGP driver up until now, and even that card might be performing better now).
  • »10.07.18 - 03:11
    If it wasn't for a total renovation of my flat I would already be testing the compatibility of available AGP card variants. But I guess I can't hold myself back and I'll be digging through the boxes today afternoon. Maybe not the HD series, but I should definitely have some AGP X1900's.
  • »10.07.18 - 06:57
    Yes, I guess that R700 (HD4xxx) AGP card support will follow in MorphOS 3.12.
    Indeed, I've been wondering what "Fixed AGP support on R500 [...] cards" in the MorphOS 3.11 release notes means specifically. That might be it.
  • »10.07.18 - 18:11
    >..."Fixed AGP support on R500 [...] cards"
    I missed that note.
    Looks like we won't have to apologize for the R500's performance anymore (not that it was ever the gpu's problem, just the code needed to navigate the bridge chip).
    Cool. I'll have to secure something to experiment with, since until now, the best card I've gotten running in a G4 was R400 based.
    The big question now is R500 or R600?
  • »10.07.18 - 20:00
  • vox
    vox
    Would Radeon 4xxx work also on PCI-E dual or quad core G5, and what would be recommended MOS gfx card there, that would eventually get to be Warp3D/Goa supported? Kind of sure, next gen bet?
    I have a 7xxx 1Ghz edition in my x1000, but I dont see that coming anytime soon for more then 2D.
    Reminds of the days when 6xxx RadeonHD worked only in 2D in workbench, not so long ago.
    Hope MOS will smash the gfx parth faster, better and free to OS end users.
  • »15.08.18 - 12:46
    I wouldn't bet on PCIe G5's if I were you.
  • »15.08.18 - 13:59
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=9888&start=35
    https://www.youtube.com/watch?v=5P2HtBfVdwY
    Apart from Wazp3D with TinyGL renderer, official Warp3D/Goa support ends with ancient Radeon R2xx GPU series.
    > I have a 7xxx [...] in my x1000, but I dont see that coming anytime soon
    > for more then 2D.
    OS4 has 3D support for Radeon HD7730 and higher.
    > not so long ago.
    OS4 still has no 3D support for Radeon HD cards below HD7730.
  • »15.08.18 - 21:30
    zukow
    Posts: 643 from 2005/2/9
    My PCIe G5 had Radeon 3650 (silent) but i returned to X1950XT as it is faster and has working 3D.
  • »15.08.18 - 22:15
  • vox
    vox
    First of all, I wanted to extend topic to PCI-E Cards since with SAM460 and x5000 MOS systems are now PCI-E also.
    SAM460 and x1000 were all shipped with cards that never got 3D support (4xxx-6xxx) while yes, x5000 is shipped with Warp3D Nova card with no older Warp3D support (Do have Enhancer 1.3 and Radeon 7xxx and yes, you still have to buy another Warp3D driver).
    Not to mention, once you go 7xxx SI cards, you lose 3D under Linux.
    Now, back on MOS, any full PCI-E card support (with full 3D) after 9600 and X14xx (or whatever were the last PCI models) would be great 3.11+ archievement. I suppose these drivers could be legacy backported to x64 if needed, so are a must on future x64 front too (or done in x64 and backported to PPC32/64, irrelevant).
    Topic is Peg2 but also about MOS gfx cards.
    [ Edited by vox 16.08.2018 - 14:20 ]
  • »16.08.18 - 13:19
    Spectre660
    Posts: 275 from 2015/6/30
    The Powerpc 3D performance bands are increasing quite significantly .
    Dont know if this will have any influence on the MorphOS powerpc graphics card support Roadmap.
    Using AmigaOS 4.1FE, Warp3D Nova and the Level 1 on the game Spencer for basic fps info .
    X5000/020
    Comparison
    ASUS R7-240 (Oland) = 22-23fps
    ASUS R7-250 (Cape Verde) = 52-55fps
    Club3D R7-370 (Pitcairn/Curaçao Pro) = 55-62fps
    PowerColor R7-250X (Cape Verde) = 64-69fps
    ASUS R9-270X (/Pitcairn/Curaçao XT)= 72-80fps
    Sapphire Rx 550 4Gb (Polaris 12) = 95-109fps
    Asus Rx 560 4GB (Polaris 11) = 128-161fps
    [ Edited by Spectre660 16.08.2018 - 10:21 ]
  • »16.08.18 - 14:19
  • ASiegel
    Posts: 1370 from 2003/2/15
    No.
    Comparison
    You can find a similar range of frame rate numbers for 3D games that run on MorphOS with older graphics cards...
    Also, with all due respect, Spencer, which certainly looks nice enough based on screenshots, is not exactly pushing the boundaries of real-time 3D graphics on the PowerPC architecture. There are plenty of games with notably more sophisticated 3D engines and graphics effects running on the PowerPC-based XBOX 360, which happens to feature an ATI / AMD GPU that is only 2 or 3 years newer than the R300-based chips as found in the vast majority of MorphOS systems out there.
  • »16.08.18 - 19:47
