MorphOS on AmigaOne X5000?
    Posts: 12079 from 2003/5/22
    > that confirms my fears that the Cyrus/X5000 can't top a 12 year old PowerMac in speed
    To me, it confirms that overally it beats the 2.3 GHz PowerMac G5 in non-SIMD integer operations.
  • »29.10.16 - 20:43
    Posts: 2794 from 2006/3/21
    I thought that the first numbers were for the X5000, and second numbers were for the 2.3GHz G5, making the results that the G5 is faster in all tests? Didn't your message list the X5000 first, then the G5, before the listing of all the test results?
  • »29.10.16 - 21:09
    redrumloa
    Posts: 1424 from 2003/4/13
    Yes, 1.00 being reference means that higher numbers are faster and lower numbers are slower.
    Comparison of 2.0 GHz X5000/Cyrus/P5020 with my 2.3 GHz PowerMac G5/PPC970FX (=1.00)
    Now you completely lost me. Have you been drinking? ;-)
  • »29.10.16 - 21:10
    > for the 2.3GHz G5 [...]?
    No, the G5 is, as I wrote, scaled to 1.00. To quote from my benchmark posting which in turn quotes from my January benchmark posting (with Mac mini G4 back then, updated results) that already used the same scheme:
    "The following list shows the performance of your 2.0 GHz X5000/Cyrus/P5020 compared to my 1.5 GHz Mac mini/MPC7447A (=1.00) at the leftmost position, then the scaled per-clock performance comparison, and the name of the specific test at last position."
  • »29.10.16 - 21:38
    Of the previously posted benchmarks, the following are CPU-bound integer ones (there're probably more, but those are the ones I'm sure of):
    dnetc
    0.99 | 1.14 : KOGE 3.1 Scalar
    1.05 | 1.20 : MH 2-pipe
    0.98 | 1.13 : KKS 2-pipe
    1.10 | 1.27 : KKS 604e
    1.22 | 1.40 : MH 1-pipe
    1.20 | 1.38 : MH 1-pipe 604e
    AmigaMARK CPU
    1.30 | 1.49 : BogoMIPS ppc-assembler inline
    1.03 | 1.19 : Dhrystones
    nbench
    1.35 | 1.55 : NUMERIC SORT
    0.74 | 0.85 : STRING SORT
    1.17 | 1.34 : BITFIELD
    0.93 | 1.07 : FP EMULATION
    0.93 | 1.07 : ASSIGNMENT
    1.25 | 1.44 : IDEA
    1.04 | 1.19 : HUFFMAN
    As you can see, my 2.3 GHz PowerMac G5 is slower in 67% of cases. (And regarding per-clock non-SIMD integer performance, the PowerMac G5 is slower in 93% of cases.)
  • »29.10.16 - 22:03
    I feel comfortable enough with the benches to have decided to replace my G5s with a P5040 based X5000 (when available).
    Enough that I have parted out my 2.7 GHz system.
    I retained a 2.5 GHz quad core PCIe G5 for benchmark comparisons.
    But even that will be closely matched by the previously mentioned X5000 while drawing a fraction of the power.
    These WILL be good (if albiet expensive) systems to run MorphOS on.
  • »30.10.16 - 02:34
    Yasu
    Posts: 1724 from 2012/3/22
    Is it just me or does the benchmark differences not look all that impressive? It's faster yes, but for the most part not all that much.
    My MorphOS blog
  • »30.10.16 - 08:51
    > It's faster yes
    ...for (non-SIMD) integer operations. For floating point and memory speed, it seems to be the other way round.
  • »30.10.16 - 09:54
    Posts: 2053 from 2003/6/4
    If it wasn't that expensive it could make a nice G5 replacement system. Same speed league as the G5, but low energy uptake and new board (no leaky cooling, no dust, fresh caps, etc.). But for that price...
  • »30.10.16 - 13:12
    Posts: 2720 from 2003/2/24
    Looking at it through 2016-glasses, I'd say it's about on par with all other PPC stuff from more than a decade ago. Who cares what is slightly faster or slower in one or another area of mesurement, when the situation in total is so off the charts behind? The rest of the world moved several dimensions ahead since these performance levels were relevant in desktop computing.
    > It's faster yes
    Hm yeah, and SIMD, floating point and memory are kind of essential for many day to day things, like codex encoding/decoding and other "multimedia" situations, not to mention rendering, image processing, etc.
    Can the X5000 (single core) decode and display 1080p x.264 streams in CPU/SW?
    But *it is* that expensive! So the "if only" kind of falls flat...
  • »30.10.16 - 16:20
    > Who cares what is slightly faster or slower in one or another area of mesurement [...]?
    Some people who raised their voice in this thread certainly do.
    >> If it wasn't that expensive [...]. But for that price...
    That's exactly what Zylesea said.
  • »30.10.16 - 17:48
  • rob
    rob
    Posts: 139 from 2008/7/22
    Looking through your 2016-glasses, you should have seen that this is irrelevant today. Can any phone, tablet or low end X64 system decode video without the task being handled by dedicated hardware?
    Both OS4 and MorphOS run on systems that give access to dedicated video decoding hardware and should be moving in that direction too, regardless of how important raw CPU speed may or may not be.
    [ Edited by rob 30.10.2016 - 17:49 ]
  • »30.10.16 - 18:48
    Yeah, it was kind of rhetorical, didn't really ask for names.
    I know, that was kind of meant as rhetorical as well...
  • »30.10.16 - 19:24
    I believe so, yes.
    I remember HW addons for the A1200 that made it possible to play mp3's. While that is cool, it doesn't mean the A1200 was particular powerful or even suitable in a modern multimedia context.
    I wasn't necessarily talking about video decoding either, but about the fact that the X5000 comes as a price tag of a premium 2016 workstation, but despite that we will probably see upcoming discussions saying "...but browsing those complex web 2.0 websites should become faster once JS JIT is properly implemented".
    PPC's in the shape of used Mac HW is easy to "forgive". Like: "OK, it's not very powerful, but hey, at €100 it's still cool and fun for what it is". The X5000 will perform about the same as those 2005 Mac's (or slightly less) we use for MorphOS, but with a price tag resembling 2016 Mac Pro's.
  • »30.10.16 - 20:17
    Of course the hardware you mentioned could do that, it doesn't because that would unnecessarily waste cpu power.
    Our own hardware could assist in decoding as well, but no one has tackled that task yet.
    And our more powerful systems can decode video pretty well on cpu power alone.
    Can the X5000 decode 1080p video?
    I guess we will have to see.
    A G5 can, so it seems likely.
    GPU assisted decoding would definitely help though.
  • »30.10.16 - 20:54
  • rob
    rob
    I believe so, yes.
    The customers who will buy it just want to run OS4, MorphOS or both. All they want is a machine that runs those OSs and their applications well. It is powerful enough to run both sufficiently well and for some that's the only qualifier they need.
    All production runs of SAM440, SAM460 and the X1000 sold out despite the high price. Clearly the price to performance ratio is not as important to some as it is to you when it comes to indulging their Amiga hobby.
  • »30.10.16 - 21:05
    bigfoot
    Posts: 508 from 2003/4/11
    I'm actually slightly surprised that the X5000 beats a 2.3GHz G5 in most nbench tests, because I remember the opposite being true when testing the X5000 against my 2GHz G5. However, I just reran the tests and indeed the X5000 wins against my 2GHz G5 in most tests, and that's despite my X5000 only using single channel memory.
    However, you need to remember that the CPU core used in the X5000 is basically a G3. A highly clocked G3 with 2 cores, but still a G3. You shouldn't expect miracles from it.
  • »30.10.16 - 22:14
    redrumloa
    How big is the loss of Altivec on this Cyrus board from the perspective of a MorphOS user?
  • »30.10.16 - 22:24
    And a PPC mac would qualify just fine for this. It has worked very well for MorphOS. The X5000 offers nothing new when it comes to performance. Sure, it will be available as new (but also meaning that it's untried and unproven), it doesn't need as much cooling as a G5, and you could plug in newer gfx cards (for whatever good that may be). So at the same 2005 level performance, are those differences *really* worth 10x-20x the cost? And where are the laptops? And the minis? Or maybe the right question is: Where is the x86?
    The OS4 machine models that has been produced are each counted in the hundreds, tops. Made in sporadic batches, over almost one and a half decade. Most of the time there hasn't been anything available at all, and when it has, it has either been out of financial reach for most, or so underperforming it's hardly usable. Now there are hardly any people left. I wouldn't call this a particularly successful strategy.
  • »30.10.16 - 23:14
    I know. I just answered your insinuation that there were no such people.
    I didn't give any as you know them anyway.
    Regurgitating while purpurting to object is a rhetorical figure you just made up on the spot :-)
  • »30.10.16 - 23:15
    >"you could plug in newer gfx cards"
    Is it worth it?
    To me it is, particularly if this means I can uses something better than an X800XT.
    I was using R400 cards in my G4 before we even had G5 support and they are more than a little dated.
    And the power use of a G5 PowerMac is obscene.
    Once I switch to an X5000, I intend to keep a G4 for an AGP system, and my laptop.
    That's it, no more new systems until we support X64.
    So this will be my last PPC purchase.
    I might as well make it the best I can get.
  • »30.10.16 - 23:57
    With the nbench tests I conducted, the X5000 wins in only 40% of tests.
    Yes, with the G5 at 2.0 GHz instead of 2.3 GHz, the result should flip over to the X5000 winning in 60% of tests.
    > but still a G3.
    Can you elaborate on this classification of the e5500 core? The e500 (Book E / Book3E / Book III-E), which established the lineage the e5500 belongs to, has not been derived from the G3/PPC7xx. The series of ISAs and microarchitectures from e500 to e6500 doesn't fit in Apple's over-simplistic "Gx" scheme.
    If e5500 is a G3, then what is e6500? Is e6500 a G4 (AltiVec) or a G5 (AltiVec and 64-bit)? And what is the PA6T? If PA6T is a G5 (AltiVec and 64-bit), does that mean A-Eon's AmigaOne X series has been downgraded from a G5 to a G3?
  • »31.10.16 - 00:26
    Availability :-)
  • »31.10.16 - 00:44
    Availability :-)
    Very true.
    Obtaining Apple X800XTs has gotten harder since we adopted them, and they have become more expensive.
    We could use newer cards in PCIe G5s (if adopted), but firmware prompts would no longer be available.
    The whole system will just simplify upgrading.
    And yes, I don't think lumping the e5500 core in with the G3 is fair to it either, its a significantly better core than anything ever used in a G3 level processor. Much closer to a G4, and with some improvements over the e600 core.
  • »31.10.16 - 11:56
  • rob
    rob
    On the subject of benchmarks. Sysmon now include socres for an X5000 + R7 250X in the benchmarks section.
    Scores for Ragemen.
    The CPU speed of the X5000 is nearly are third faster.
    The X5000 has faster caches, especially L2 but gets oblitrated by the X1000 when it comes reading and writing to memory, apart frrom the "tricky write", whatever that actually means.
    Reading from VRAM is over 3 times faster on the X1000 but when writing the X5000 is over 3 times faster. I understand that faster writes to VRAM are what matters and when Amigakit posted the Cow3D results the X5000 put everythiing else to shame.
    Scores for SDL Bench.
    My X1000 has an R9 280 vs the R7 250X in the reference X5000 setup.
    X5000 wins in most tests althought the X1000 streaks ahead in the hardware rectfil test at 320X240. Not sure why this is.
  • »02.11.16 - 00:37
